May 24, 2013, 11:55:45 AM *
Members: 6620  •  Posts: 178773  •  Topics: 18139
Please welcome moranbahweather, our newest member.
Author Topic: minor VirtualVP update and signed 64 bit virtual serial driver  (Read 8496 times)
tinplate
Moderator
« on: May 26, 2010, 01:36:56 AM »
I have a beta of VirtualVP, v. 1.2.4 that temporarily addresses the problem of the new Loop command in VP firmware 1.90. If a program asks the console, through VirtualVP what the firmware version is, VirtualVP simply passes along what the console says. But if it's firmware v. 1.90, then the weather program assumes it can use the new loop command, which VirtualVP does not support. This v. 1.2.4 of VirtualVP temporarily addresses this by filtering the response to the version command so it reports an earlier version so the weather program will not assume the loop2 command can be used. This problem only occurs if you have the 1.90 firmware, and use the latest VirtualWeatherStation or 5.9.x of WeatherLink, and possibly the latest PC-Wetterstation. The beta is a zip of the exe, which can be extracted and placed in the folder where VirtualVP is installed. The download is here: http://www.softwx.com/weather/virtualvp/virtualvp1.2.4.zip
I would like to add native support in VirtualVP for the new loop2 command, but have not gotten my hands on the specs for the command. If anyone has that, I would be thankful if you could email it to me (steve at softwx.com).
Also, a VirtualVP user alerted me to a virtual serial port driver I had not encountered before. It is a fully signed driver, so it can be used on 64-bit Windows without having to jump through any other hoops, and it's free. The link is on the download page at softwx.com, but to save you having to go there here is this link: http://k5fr.com/ddutilwiki/index.php?title=VSP_Manager
I have not tested it myself, but a couple VirtualVP users have been using it and report that it works well.
Steve
offroadjosh
Davis Vp2 Wireless- VWS 14 P90 Serial Data logger
Montana Firefighter
« Reply #1 on: June 03, 2010, 01:21:01 AM »
tried to do the update and  says file is there would you like to replace, i say yes then its password protected? How can i go on to updating?
Josh Patten
Davis VP2 Wireless -May 2008
VWS 14.00P90\WL 5.9.9/Plus others!
Skywarn trained
CoCoRaHS member
Smith Valley Fire Dept Firefighter:)
http://josh.northwestwx.com/station/usa.htm
CWOP-DW0711
Kestrel 2000 hand held anemometer
Cocorahs 4in rain gauge
Custom co
Mark / Ohio
Live from Mars!
« Reply #2 on: June 11, 2010, 01:00:44 AM »
Josh,
Kind of sounds like a windows password you have put in at some point.
2002 Davis VP I Wireless, WeatherLink (Serial), VWS, ImageSalsa, GRLevel3, VirtualVP, VPLive, StartWatch, Windows XP (SP3)
Choupie
« Reply #3 on: October 23, 2010, 07:53:11 AM »
I'm running seven with weatherlink and would like to use virtualVP, what would be the best solution with virtual serialport ?
thnaks a lot
jay_hoehn
« Reply #4 on: October 23, 2010, 11:05:19 AM »
Why not just use the TCP/IP connection and forget the virtual serial ports.
Jay
Davis Vantage Pro2 Plus
VVP
VWS
VP Live
Cumulus
WeatherFlash
Image Salsa
Movie Salsa
Choupie
« Reply #5 on: October 23, 2010, 11:33:23 AM »
Could you explain me how to configure these softwares weatherlink & VirtualVP and my Vantage pro 2 ? all were working fine under XP Sp2
jay_hoehn
« Reply #6 on: October 23, 2010, 01:31:12 PM »
Here are the settings for VVP, VWS, and WL.  Screenshots attached.  You will need to restart VVP.  Hope this helps.
Jay
VVP
VWS
VP Live
Cumulus
WeatherFlash
Image Salsa
Movie Salsa
Choupie
« Reply #7 on: October 23, 2010, 02:20:38 PM »
Thank you very much jay Smile
I need vws to run tcp/ip with vantage pro 2, not possible without this software ? does it possible to get free vws version ?
jay_hoehn
« Reply #8 on: October 23, 2010, 02:28:19 PM »
You do not need VWS.  Just set up Virtual Vantage Pro and Weatherlink.
Jay
VVP
VWS
VP Live
Cumulus
WeatherFlash
Image Salsa
Movie Salsa
Choupie
« Reply #9 on: October 23, 2010, 02:57:09 PM »
I don't understand how to configure weatherlink and VVP with the station  Rolling Eyes
VP2 connected via USB port to my computer and after ? I'm running seven 64 bits
« Last Edit: October 24, 2010, 02:30:57 AM by Choupie » Logged
jay_hoehn
« Reply #10 on: October 24, 2010, 01:25:08 PM »
I am not familiar with using the USB connection with Vantage Pro.  I'm not sure how VVP would connect.  Maybe someone else can help.  I did find out that VSP Manager is not available any longer.  Your only other option is to purchase a virtual port driver.  The problem is that microsoft has decided to charge a lot of money to license 64 bit drivers.  Here is a link where you can buy one if you want.  http://www.eterlogic.com/Products.VSPE.html
Hope that helps.
Jay
VVP
VWS
VP Live
Cumulus
WeatherFlash
Image Salsa
Movie Salsa
Choupie
« Reply #11 on: October 24, 2010, 02:20:16 PM »
thank you Jay for your help
 I bought windows and I don't want to give money for these drivers... excepted to Tinplate Wink
Bushman
« Reply #12 on: November 18, 2010, 01:44:35 PM »
http://tibbo.com/downloads/soi/tdst.html has the old versions of VSP
tinplate
Moderator
« Reply #13 on: January 25, 2011, 08:45:53 AM »
For a while, there was a free virtual serial port driver that was signed. But the author of that driver had to pull it from availability because of a license issue with a third party component utilized in the driver. With that gone, there were no free signed drivers. To address this issue, I have obtained the certificate necessary to do the signing process, and am donating this service to the com0com open source virtual serial port project. The author of that software has added me as a developer on that project, and I'm working with him to provide signed 64-bit versions.
He will put together the next release containing the signed drivers, but I have a version that can be used to beta test. So if a couple people that are already using com0com on 64 bits using windows test mode can email me at support at softwx.com, I will send you the signed version to try out. I'd like you to take windows out of test mode, test that the driver no longer works in normal windows, then update the driver with files I will send you, then test that the updated driver works. This test will only work if you already have com0com installed, as I don't have a whole installer package built. I only have the new signed driver, catalog, and inf file.
Steve
tinplate
Moderator
« Reply #14 on: January 25, 2011, 11:55:55 AM »
Ok, I now have the full install for the signed 64 bit version of com0com. So if there are a couple people that didn't want to the the windows test mode thing, aren't using another virtual serial port driver, and want to beta test the signed 64-bit version of com0com, send an email to support at softwx.com
Steve
Choupie
« Reply #15 on: July 10, 2011, 05:37:13 AM »
Hey Steve,
I would be interested by the the signed 64 bit version of com0com so if you could help me to get it.. ?
cheers
Page created in 0.104 seconds with 19 queries.
