Author Topic: Vantage Vue Rain Accuracy  (Read 17132 times)
Offline Sartori
« on: May 25, 2010, 04:02:26 PM »
Hello
I recently purchased a Vantage Vue station and am finding that the rain accuracy is quite a bit different then my cylinder gauge. This is the one I'm comparing it too:
http://www.amazon.com/All-Weather-Rain-Gauge-Official/dp/B000PHKZPS
Recently there have been three different rain storms come through here and the Vantage Vue has been consistently lower then the cylinder gauge. They are both in open areas and are about 100 feet apart. The difference varies but gets worse the more it rains, all the way from a .10 at a half inch to .20 at an inch and a half.
So, I figured I would go into the rain calibration area of the console and change the settings. I started out at -2, then went to -8, -14, and all the way to the max at -25, didn't make any difference in the readings at all....
Yes, everything is clear, clean, and its mounted spot-on level also. I did contact Davis and they are sending me a new tipping spoon assembly but thought I would post a topic here and see if anyone else has gotten or are getting a big difference in their rain readings...
Thanks for any replies!!
Offline W Thomas
  • Welcome to my area!
    • Smyth-Grayson Weather
Re: Vantage Vue Rain Accuracy
« Reply #1 on: May 25, 2010, 04:31:45 PM »
Mine has tracked really close to the CoCoRaHS collector.. usually varies .01-.04 difference between the two.
Maybe I have been really lucky :-P
     Best Regards
     Wayne
CWOP CW8217
KVAWHITE22 Wunderground   Davis VUE &  Davis Vantage Pro 2  /   Dedicated Server
Offline SLOweather
    • Weatherelement Moline IL
« Reply #2 on: May 25, 2010, 04:42:36 PM »
100' is too much distance over which to compare rain gauges. If you are going to adjust the Vue to the Stratus gauge, mount them as close together as possible. My Stratus is on the opposite side of a 6x6 post from the VP2 ISS. Both are at the top, tops level with each other to avoid rain shadow. They track very closely, within 0.02" or so in most rain events, and also closely track an 8" standard gauge about 6' away sitting on the ground.
OTOH, the wireless VP2 in the back yard, perhaps 200' away, which I use for systems development, hardly ever matches the other gauges. Both VP2s have been carefully calibrated with a NovaLynx tipping bucket calibrator. I don't know what the console adjustment is for, but IMO, if you're going to calibrate a tipping bucket/tipping spoon gauge, it's best to calibrate the mechanism itself.
« Last Edit: May 25, 2010, 06:27:32 PM by SLOweather »
Offline Sartori
« Reply #3 on: May 25, 2010, 05:21:31 PM »
Okay, will see about getting the cylinder gauge mounted a little closer.
I didn't see anywhere on the tipping mechanism where you would calibrate it on there. The only place was within the console...
Offline 4wd
    • North York Moors weather
« Reply #4 on: May 25, 2010, 05:33:55 PM »
There's a screw you can turn by hand underneath the ISS to alter it.
Are you sure it's level first?
That makes a big difference with the vue single spoon-type bucket.
Make sure it's level including after you tighten up the clamp.
Offline Sartori
« Reply #5 on: May 25, 2010, 05:56:21 PM »
Okay, I see that now won't mess with it yet though...Yes its mounted level, made sure the pole was level and the bubble was directly in the center...
I mainly thought messing with that console calibration would change it more but guess thats not the case....
I have been reading some more on the forum, it seems the wind is going to affect the reading quite a bit too as I do have it mounted quite a ways in the air. Heres a pic:
If we ever get a rainstorm without any wind I'll see how they both read then also....
« Last Edit: May 25, 2010, 06:22:15 PM by Sartori »
Offline dalecoy
    • Lee's Summit, MO
« Reply #6 on: May 25, 2010, 06:47:49 PM »
Yes, wind has quite an effect - that's the main reason to have them close together, if you're going to compare.  If there are any houses, trees, bushes, etc. around, and/or if they are mounted at different heights, then they get different breezes.
Offline north of 60
« Reply #7 on: May 25, 2010, 11:21:47 PM »
I have 4 tipping bucket rain gauges along with cocorahs gauge in a line.  My Rainwise gauge which is 7 years old is by far the best tipper for consistancy and staying calibrated over time.
Offline Sartori
« Reply #8 on: May 27, 2010, 08:15:49 AM »
Just a follow-up, and the Davis tech guy couldn't answer this....Do any of you know how much the rain calibration changes the amount on the Vantage Vue console? The amounts are in a percentage from -25 to +25 but a percentage of what amount though....of a .01, .10, 1.00, etc...
Offline 4wd
« Reply #9 on: May 27, 2010, 08:39:52 AM »
It wouldn't make any difference, it would still be the same percentage.
If you think it rained an inch but vue says 0.9inch turn it up 10%
There's going to be a bit of trial and error.
Offline Sartori
« Reply #10 on: May 27, 2010, 09:30:43 AM »
Okay, makes sense, I guess...yes already been through the trial and error, read my first post:)
Offline dalecoy
    • Lee's Summit, MO
« Reply #11 on: May 27, 2010, 10:51:12 AM »
Well, first, this (from the Vue console manual) seemed fairly clear to me:
Quote from: Book
Enter the error. Enter a negative number if your station is under reporting; enter a
positive number if it is over reporting. For example, if your station is low by 2%,
enter -2. If your station is high by 4%, enter 4. Press the + and - keys to add or
subtract from the percent amount. The Rain Error Percentage range is -25 to 25
percent. (Not all corrections are available, so you may have to choose the closest
one.)
Now, what is it that you're calibrating?
The book says: "The Rain Error in Percent refers to the measuring error of your rain collector".
What readings were you looking at?
I'm betting you were looking at daily rain, monthly rain, total rain.
I'm betting that the calibration changes the correction to what will be measured and recorded in the future..
What has already been measured and recorded in the past, can't be changed (by that method).  That's why you didn't see any "change".
You can manually change the "past" (pages 28 and 29), of course.
« Last Edit: May 27, 2010, 10:54:16 AM by dalecoy »
Offline 92merc
  • BismarckWeather.net
« Reply #12 on: May 27, 2010, 11:00:31 AM »
I see from your picture the Vue is on the roof.  Is the cylinder gauge as well?  I'm guessing not, considering you don't want to climb up to dump it all the time.  That right there can make a huge difference, depending on winds.
My father has 2 of the same gauges you have, and he has them about 100 feet apart.  One in front of the house and one in back.  He lives out in the country, so no neighbors to shield him.  But even then, he can get as much as .10 inch difference.
I moved to a new house and had reception problems with my VP1, so I bought a VP2.  I gave him my old VP1 hoping he can use it.  I'm real curious to see how the rain gauge will compare to his manual gauges.  My dad doesn't think it'll work as well.  But I have a CWOP gauge mounted to the same pole as my VP2 is, and they agree within .02 inches.
Offline Sartori
« Reply #13 on: May 27, 2010, 11:05:45 AM »
Quote from: Book
one.)
Well I'm happy that its clear for you:) I'm not worthy, I'm not worthy...
Okay, yes I know all that, I'm calibrating the rain amount! And I understand its the future amounts, that what I was looking at after I changed it and after the next storm went through. I wasn't looking at daily, past, month. I was comparing the change to the future rains! And I'm saying, changing it DID NOT change the "future rain" amounts at all comparing it too the cylinder gauge from each rain strom...
And the percentage that they are referring too in the book isn't clear on what they are comparing it too for the difference...
Offline dalecoy
    • Lee's Summit, MO
« Reply #14 on: May 27, 2010, 12:34:57 PM »
OK, sorry I misinterpreted what you wrote.  I'm still a bit curious about your exact procedure, though.
First, although you didn't say, I'm assuming that you believe that your Vue is underreporting.  That's why you would use a negative adjustment.
What was the calibration set to, when the half-inch storm happened?  What was it set to when the 1.5-inch storm happened?
And you made 4 changes for 3 storms?
How about posting just the actual data for the three storms:
Calibration setting, Vue measurement, Cylinder measurement.
I think that would be a lot easier for us to understand, and perhaps help with.
« Last Edit: May 27, 2010, 06:58:27 PM by dalecoy »
Offline Sartori
« Reply #15 on: May 28, 2010, 08:21:10 AM »
Hello
Had another rain storm come through last night with very little wind.  I have the calibration setting at -25, the cylinder showed .37 and the Vantage Vue showed .32
I still don't think that calibration setting is changing it any...
Offline dalecoy
    • Lee's Summit, MO
« Reply #16 on: May 28, 2010, 10:11:04 AM »
For the other three storms you reported:
"How about posting just the actual data for the three storms:
Calibration setting, Vue measurement, Cylinder measurement."
Offline Sartori
« Reply #17 on: May 28, 2010, 11:43:34 AM »
Okay, initial install of the Weather Vue station with no change in the rain calibration:
Calibration setting:  0
Vue Measurement:  .40
Cylinder Measurement  .54
Second Rain
Calibration Setting:  -8
Vue Measurement:  .25
Cylinder Measurement  .38
Third Rain
Calibration Setting:  -25
Vue Measurement:  1.48
Cylinder Measurement  1.70
Offline dalecoy
    • Lee's Summit, MO
« Reply #18 on: May 28, 2010, 01:54:33 PM »
Thanks for the data.
If I "back convert" the data (remove the assumed correction percentage), then the percentage differences between the Vue and the Cylinder are fairly similar, which tends to indicate that the console correction is in fact working.  Of course, the sample size is relatively small.
Notice that the percentage difference from both of the samples where the setting was -25, are virtually identical.  And the "error" on the other two samples is quite different.
And I don't know how far you are from Flaxville, but it looks like your cylinder readings are consistently lower than Flaxville.
At any rate, I don't think you're going to know anything for sure until you get the two rain gauges mounted close together, and at the same elevation.  Until then, you'll have to assume that they are each accurately measuring the rain that they catch, where they are.
Offline Sartori
« Reply #19 on: May 28, 2010, 02:39:23 PM »
Flaxville?? Where the heck did you get that from? Thats pretty funny:)
Offline dalecoy
    • Lee's Summit, MO
« Reply #20 on: May 28, 2010, 02:48:57 PM »
Well, your ISP is "North East Montana Network".  I just picked a town.  Should I have picked West Fork or Scobey or Wolf Point?   :grin:
Billings or Missoula?
« Last Edit: May 28, 2010, 03:07:20 PM by dalecoy »
Offline Sartori
« Reply #21 on: May 29, 2010, 08:33:13 AM »
There's no way that you can compare my cylinder reading's to those towns if theres going to be a big difference in two gauges 100 feet apart. I'm out in the country in the middle of nowhere and the distance to those towns you listed varies from 20 miles to 500 miles:)
We had another rain event last night, it was dead calm when it was raining so wind was not a factor at all this time. I still have the rain calibration set to -25, the Vue reported .10 and the cylinder reported .13. Yes the gauges are still in the same place, I didn't move the cylinder gauge closer yet.
I really don't think that in this rain event instance that having the gauges close together would have made an difference....
I guess I'm just going to live with the difference for now and just average the two together. I had a Vantage Pro before this station and it always undereported also and the two gauges were 10 feet apart and at the same elevation. I also previously had the data uploading to wunderground and was going to do it again but am holding off for now till I change the tipper assembly with a different one just to make sure. I refuse to upload data again if its just going to be "close"...
I shouldn't have to max that rain calibration all the way to -25 right out of the box just to get the reading's "close". If they are going to have that option in there they need to do it from -100 to +100 so it will make a bigger difference, especially if wind is going to be a factor with the unit...
Offline tomcj2
    • CanbyWeather
« Reply #22 on: May 29, 2010, 08:50:47 AM »
I recently post an interesting segment of a CoCoRaHS newsletter in another thread .  Look at http://www.wxforum.net/index.php?topic=7899.msg76618#msg76618
Davis VP2 (6163), WL 5.9.0..  VWS 14.01 p25, Panasonic HM371A camera. WU & W4U KORCANBY3, CoCoRaHS OR-CC-27
Offline 4wd
« Reply #23 on: May 29, 2010, 09:45:33 AM »
I noticed a discrepancy of about 25% due to wind one day early April
( http://www.wxforum.net/index.php?topic=7602.0 )
Take it to the extreme with wind blowing rain almost horizontally and clearly quite a lot will not fall inside the funnel.
Mind you that almost suggests a debate about where the missing rain does end up!
Offline dalecoy
    • Lee's Summit, MO
« Reply #24 on: May 29, 2010, 10:45:58 AM »
You will not know for sure, until you try it.  Until then, it's a guess.
What is the vertical distance between the two gauges?
"...one general conclusion is that measurements of rainfall constitute an unsolved problem in that rainfall measurements are corrupted with significant uncertainties that are difficult to quantify."   That's from:
http://www.iihr.uiowa.edu/~hml/people/kruger/Publications/PDF/StMauritz.pdf
« Last Edit: May 29, 2010, 11:13:37 AM by dalecoy »
