May 22, 2013, 03:32:54 AM *
Members: 6617  •  Posts: 178536  •  Topics: 18117
Author Topic: V14.01 P22 problems  (Read 3034 times)
KC2TOH
« on: April 20, 2010, 11:53:10 PM »
I just updated my Virtual Weather Station to V14.01 P22 and can no longer get it to work with VirtualVP.
I have VWS connected to virtual port 16 and WeatherLink 5.9.2 connected to virtual port 17.  VirtualVP is communicating fine with my Davis Vantage Pro2 and WeatherLink but will not communicate with my new version of VWS.
The VirtualVP activity log keeps jumping from "Sent response for Wake Up Console" to "Sent response for Get Station Info" to "Sent Response for Unknown Command" to "Sent Response for Get Firmware Number" but never transfers any information.
I can however, get my new version of VWS to work fine by itself (no VirtualVP or WeatherLink running).
Anyone else have this problem?  Did they purposely make V14.01 P22 not compatible with VirtualVP?
Any help would be very appreciated!
Mike
Mark / Ohio
Live from Mars!
« Reply #1 on: April 21, 2010, 12:55:15 AM »
So far V14.01p22 is working OK for me using Virtual VP for the last 2 days.  However, I did have VWS crash once yesterday for an unknown reason with no reason showing in the logs of VWS or Windows.
What version of Virtual VP and console firmware are you using?
There was mention in another thread about someone updating the console firmware then unable to get the most current version of WeatherLink (5.9.2) to run using Virtual VP.  I'm still running 2001 firmware in the console and seem have no problem with 5.9.2 so far.
KC2TOH
« Reply #2 on: April 21, 2010, 07:22:08 AM »
I have the latest console firmware version 1.90 and I am using the latest version of Virtual VP version 1.2.3.69..  The strange part is that I updated the console firmware about a month ago and have been using it flawlessly with Virtual VP until last night.  The problem only started after I upgraded VWS to V14.01 P22 last night.  So it seems to be a problem with VWS and Virtual VP and not the Vantage PRO2 firmware.
Any ideas?
Weather Display
Online Online
« Reply #3 on: April 21, 2010, 03:12:58 PM »
there is a thread about a problem with the LOOP2 packet method
KC2TOH
« Reply #4 on: April 21, 2010, 06:05:42 PM »
I did a search for that and I can't find anything that pertains to the problem I am having..
Where did you see the thread?
There has to be someone else that is having the same problem as me?
Weather Display
Online Online
« Reply #5 on: April 21, 2010, 06:18:50 PM »
Tinplate, the author of VPlive, was part of that thread, and is aware of the problem
search for posts by him
KC2TOH
« Reply #6 on: April 21, 2010, 07:30:47 PM »
Are you talking about this thread:
http://www.wxforum.net/index.php?topic=7605.0
Tinplate did not post anything in this thread, but its the ony thread I can find about loop2..
After further examination it I looks like VWS and Weatherlink will not upload any data while using VirtualVP and the new Davis firmware 1.90.
They both work fine without VirtualVP.  However, I need the VirtualVP software to use them both at the same time
Do anyone know of a fix for this or is there anyway to roll back the firmware upgrade?
Mark / Ohio
Live from Mars!
« Reply #7 on: April 22, 2010, 12:08:25 AM »
I don't know about rolling back the firmware to a previous version but there is an option in VWS to allow Weather link to run intermittently per a user adjustable schedule to keep it's records up to date.  Depending on your WeatherLink usage might be a workaround until Steve gets the issue sorted out.
« Last Edit: April 22, 2010, 12:10:05 AM by Mark / Ohio » Logged
KC2TOH
« Reply #8 on: April 22, 2010, 11:07:44 PM »
Well after some troubleshooting I have found out the following using Davis Vantage Pro 2 with the newest Firmware 1.90 with Virtual VP:
When using the new VWS 14.01 P22,  I can not download any information from the Vantage Pro2 console while using Virtual VP .
When using the new Weatherlink 5.9.2, I could not get the APRS / CWOP data to upload while using Virtual VP.
In both cases I had to revert back to the old software to get them to work.  Back to VWS 14.00 and Weatherlink 5.8.3.
Mark / Ohio
Live from Mars!
« Reply #9 on: April 24, 2010, 11:50:44 PM »
My intermittent issues with VWS V14.01p22 continued so tonight I backed up to v14.00p101.  Not sure whether it was VVP or VWS issue but don't have time right now to troubleshoot it.
offroadjosh
Davis Vp2 Wireless- VWS 14 P90 Serial Data logger
Montana Firefighter
« Reply #10 on: June 01, 2010, 12:08:04 PM »
So i am having this issue now myself. Last ngiht I updated to 5.9.2 (weatherlink) and 14.01 P28 on VWS. Now weatherlink kinda of works with VVP and vws will not at all with vvp. alone they both work great. any ideas? VWS connects but no temps no nothing all are - - -
Josh Patten
Davis VP2 Wireless -May 2008
VWS 14.00P90\WL 5.9.9/Plus others!
Skywarn trained
CoCoRaHS member
Smith Valley Fire Dept Firefighter:)
http://josh.northwestwx.com/station/usa.htm
CWOP-DW0711
Kestrel 2000 hand held anemometer
Cocorahs 4in rain gauge
Custom co
Weather Display
Online Online
« Reply #11 on: June 01, 2010, 03:41:34 PM »
make sure you are using the latest Beta version of VVP
as its most likely that VWS is now using the new LOOP2 data
offroadjosh
Montana Firefighter
« Reply #12 on: June 01, 2010, 05:15:57 PM »
Ah ok. Is there a link? I couldn't find it.
Josh Patten
Skywarn trained
CoCoRaHS member
CWOP-DW0711
Custom co
Weather Display
Online Online
« Reply #13 on: June 01, 2010, 08:01:43 PM »
the thread to the new version is right here in this section of the forum by the author of VVP, Tinplate
Mark / Ohio
Live from Mars!
« Reply #14 on: June 02, 2010, 01:12:19 AM »
http://www.wxforum.net/index.php?topic=8010.0
offroadjosh
Montana Firefighter
« Reply #15 on: June 02, 2010, 12:27:11 PM »
awesome thank you! I will try it out today hopefully...
Josh Patten
Skywarn trained
CoCoRaHS member
CWOP-DW0711
Custom co
Page created in 0.087 seconds with 19 queries.
