tomcj2
« Reply #25 on: March 11, 2010, 10:12:07 PM » |
But can we srill keep hockey as our game?
until Canada takes second place. ( when was the America Cup last won by an American ship?)
 Davis VP2 (6163), WL 5.9.0.. VWS 14.01 p25, Panasonic HM371A camera. WU & W4U KORCANBY3, CoCoRaHS OR-CC-27
tomcj2
« Reply #26 on: March 11, 2010, 10:29:26 PM » |
definitely off topic............. but.......
I went into the local bar tonight with a hockey stick, nobody there had ever seen one before. Even I was surprised that the stick was :
made in CANADA
Bushman
« Reply #27 on: March 11, 2010, 11:03:03 PM » |
Oregon - and they don't know hockey? I call BS. BTW, you Yanks know why the White House is white, eh?
PaulMy
« Reply #28 on: March 11, 2010, 11:25:43 PM » |
After such dominance for so many years, has it been 18 years since the last win, America3?
W3DRM
« Reply #29 on: March 11, 2010, 11:45:18 PM » |
Yes, 1992 by America 3.
Don - W3DRM - Minden, Nevada --- Davis Wireless VP2, VWS 14.00 p101, StartWatch, VirtualVP, VPLive, WL 5.9.3, Win7 Ultimate-SP1 --- Logitech QuickCam Fusion webcam
vcbmoore
« Reply #30 on: March 12, 2010, 06:10:31 AM » |
Davis Vantage Pro2 w/FARS & Solar, VWS 14.01p25, Boltek Lightning, Nexstorm, StormVue, StrikeStar, Panasonic BL-C230 Webcam
tomcj2
« Reply #31 on: March 12, 2010, 07:40:55 AM » |
Oregon - and they don't know hockey? I call BS. BTW, you Yanks know why the White House is white, eh?  1) They know the game, but nobody had ever held a stick up close. 2) To cover up the smoke and fire damage caused by the British when they set it on fire during the War of 1812. There is still a lot of whitewash used in Washington these days.
Bushman
« Reply #32 on: March 12, 2010, 08:52:13 AM » |
LOL @ #2  We must have some leftover paint up here too. Lots of whitewashing in Ottawa.
Cienega32
« Reply #33 on: March 13, 2010, 12:37:03 PM » |
Same guy that made the big push for a "National ID Card" after 9-11. Probably wanted to use his CIA database software (Oracle).
mmoon
Offline
« Reply #34 on: March 31, 2010, 01:32:37 PM » |
Well, as the OP of this thread, I'm already upgrading my Logitech 9000 to an Axis 211. The Logitech is a good camera and quite good at close objects, but its focal length is too short (distant objects aren't captured with enough clarity and appear too far away) and image quality isn't quite what I want to provide my visitors. The Logitech has been running happily in its outdoor heated enclosure for now, but it will become a secondary camera for another purpose, what...I don't know yet.
Cienega32
« Reply #35 on: March 31, 2010, 04:54:03 PM » |
CritterCam!
LFWX
« Reply #36 on: September 17, 2010, 11:45:56 PM » |
I just received one of these enclosures to use with a Logitech 9000 - it has changed slightly from what is shown on eBay, the bracket now mounts to two nuts in a track running the length of the bottom, offering more flexibility when installing. Two questions: Which two terminals did you use to power the fan/heater? The directions are not very clear on this. I'll be using the 12VDC option. If anyone has their camera looking up slightly, did you angle the housing up or aim the camera up inside the enclosure (lens not parallel to the glass)? Thanks Mike
Station: Davis Vantage Pro2 Fan Aspirated Software: Virtual Weather Station V14.00p64 OS: Windows Vista Home Premium www.LFWeatherCenter.comCWOP: DW1039 CoCoRaHS: OH-BT-1 Weather Underground: KOHHAMIL7 Weather For You: DW1039 Midwestern Weather Network
linuxfreak
Hamilton Central Mountain Weather
Contributor
Offline
Wink, wink!
« Reply #37 on: September 20, 2010, 02:50:46 AM » |
I went into a computer shop 3 blocks from my house and found the same enclosure without heater or fan going for $12 CDN, guy had a box of them sitting on the floor, was expecting him to say $60!!  Only problem, in my case, is the housing is aluminum, GPS won't work through it! So I'm making a housing that'll match the Boltek housing, have both the webcam and GPS in it with a hub at the end of a Cat5 USB extender cable. Have had it running in the house here for the past 6 months with no problems other than the odd power glitch causing the GPS and camera to disappear off the hub.  A power cycle of the hub power gets it running again. George
George Davis VP2/FARS, VVP, WD, WL, WSWin, Cumulus, NexStorm, StrikeStar, NSLog, XPort(GPS), WASP2, DigitalAtmosphere, ScannerCast(WUradio), Intel Atom N330 dual-core, 2Gig ram, Windows XP Home SP3  CWOP - DW3112, PWS & WU - IONHAMIL2, AWEKAS - 5112, CWON, WML - WD01901
utahweatherbear
« Reply #38 on: September 20, 2010, 12:00:57 PM » |
I had a couple of them outside in an unheated enclosure. they worked fine through the utah winter. got into the single digits a few times, and was well below freezing almost every night for a couple months at least. had no problems...
kray1000
« Reply #39 on: September 20, 2010, 09:47:46 PM » |
Angle the housing and leave the camera flush against the glass. I bought two of these from this seller, one with a heater/blower and one without. I haven't used the HB one yet. Which two terminals did you use to power the fan/heater? The directions are not very clear on this. I'll be using the 12VDC option.
The directions aren't very clear? I'd say they are non-existent.
Kevin Ray Roanoke, VA  Wireless VP2, Stardot NetCam, ImageSalsa 2.0.12, MovieSalsa, Nexstorm, WASP2, Skymet, VWS14.01p33, WD 10.37N build 03
Mark / Ohio
« Reply #40 on: September 20, 2010, 11:37:11 PM » |
I've been keeping it a secret until now but after having Image Salsa for 5 years I finally hooked a Logitech Webcam Pro 9000 to it about 3 weeks ago and started uploading the Image to Weather Underground. Right now it is pointed out a window. I bought a $10 halogen outdoor flood lamp fixture from Lowe's Wednesday thinking I'll gut the lamp and socket and mount it in there.  It is set to run sunrise to sunset.
Mark 2002 Davis VP I Wireless, WeatherLink (Serial), VWS, ImageSalsa, GRLevel3, VirtualVP, VPLive, StartWatch, Windows XP (SP3)
LFWX
« Reply #41 on: September 21, 2010, 01:00:34 AM » |
Do you use the URL or FTP method?
The reason I ask - On the Wunderground webcam page, as of about 1:00am EDT, of the 37 cameras in Ohio, yours and mine are the only two showing very old images (5 hours ago for you, 6 hours ago for me). I'm using the URL method, the current image is available (24 hours a day), the data is current, an extra line is shown at night to explain the black scene, but it is a "live" (5 minute) image.
Mike
Mark / Ohio
« Reply #42 on: September 21, 2010, 02:09:51 AM » |
Do you use the URL or FTP method?....
I'm using URL method. They pull it from the same link as I pulled the picture above. Come tomorrow at Sunrise it will start updating. I use VWS to ftp the image to my website every 1 minute. It brings up an interesting question though as to how they could know my image is not updating from sunset to sunrise when VWS continues to upload the .jpg every one minute. Before I set the schedule I'm sure it showed black one night there when I checked. (There are no lights visible in the image after dark in that direction.)
CNYWeather
« Reply #43 on: September 21, 2010, 03:25:35 PM » |
I just received one of these enclosures to use with a Logitech 9000 - it has changed slightly from what is shown on eBay, the bracket now mounts to two nuts in a track running the length of the bottom, offering more flexibility when installing. Two questions: Which two terminals did you use to power the fan/heater? The directions are not very clear on this. I'll be using the 12VDC option. If anyone has their camera looking up slightly, did you angle the housing up or aim the camera up inside the enclosure (lens not parallel to the glass)? Thanks Mike SRY, just saw this Mike. Did you get it figured out or wanna shot of the inside of mine?
LFWX
« Reply #44 on: September 21, 2010, 04:39:46 PM » |
CNYWeather - A picture would be great, I'll be on the roof this weekend. Hopefully we have enough wind to keep things cool in the enclosure, about foot or so above a dark brown roof.
Mark - My image started showing again today around 11:00am EST (noon EDT), we'll see what happens tomorrow.
Mark / Ohio
« Reply #45 on: September 22, 2010, 12:07:11 AM » |
Which method do you use? I could easily enough set Image Salsa to send it to WU or my webiste directly. But since I'm in the early stages yet decided to use VWS to load it for now. Also if memory serves E-Rice only allows 3 simultaneous ftp connections. I already have VWS, WeatherLink, and GRL3 loading to them. I've been meaning to do some rearranging to get WeatherLink back out of doing part of the uploads. On a side note one thing I found was if I loaded the latest Logitech software which takes away some control from Image Salsa the picture did not look nearly as sharp. I found what I think are legacy drivers ( LgDrvInst setup.exe ) on the install disk and used them instead. That returned the color and sharpness controls to IS.
LFWX
« Reply #46 on: September 22, 2010, 01:56:12 AM » |
Which method do you use? I let ImageSalsa save directly to the server and then Wunderground fetches it (URL method). They are still showing on Wunderground now, well into the night. http://www.wunderground.com/weatherstation/WXDailyHistory.asp?ID=KOHHAMIL7I read a FAQ which listed system overload as reason for images not showing up - since I'm one the newest on the system, maybe I was one of the first to be skipped when the system was overloaded. I just wish the Wunderground movie could be slowed down, instead of 24 hours passing in a blink!
Mark / Ohio
« Reply #47 on: September 23, 2010, 01:19:52 AM » |
.... I just wish the Wunderground movie could be slowed down, instead of 24 hours passing in a blink!
I heard that.  At some point I want to make my own movies and to some extent store daily images so I can at least review them for any accidental lightning photos.
utahweatherbear
« Reply #48 on: September 23, 2010, 02:54:49 PM » |
just bought the new logitech HD pro webcam c910. added to my outside cams, which are microsoft HD lifecams. so far, so good. pics are similar, logitech a tad brighter it seems, but could be the sun angle difference. you can see them all here: http://weatherbear.com/the logitech is the one looking NNE, the other 3 widescreen cams are the Lifecam. the NW cam is s sharx network cam...not HD.
Mark / Ohio
« Reply #49 on: September 23, 2010, 10:44:50 PM » |
Looking good as the sun sets Weatherbear!
