September 08, 2010, 02:34:53 AM *
Did you miss your activation email?
Members: 3178  •  Posts: 82054  •  Topics: 8381
Please welcome clpeterson, our newest member.
Problems with the forum? Please PM saratogaWX with details. Thanks!
Author Topic: VWS freezes up  (Read 523 times)
nycweatherman1
« on: January 30, 2010, 09:03:08 PM »
Hi Forum.. Hope all is well
I need your help in solving the issue that I am having with VWS.. Periodically, I have to end the program and restart it again because all readings freeze up.. (the temp, rel humidity.. everything...)
using Vista... v14.00 p 103
Let me know if you need any additional info..
Thanks for your assistance in advance,
Regards
G.A>
GBW
Online Online
« Reply #1 on: January 30, 2010, 09:38:28 PM »
what weather station type?
one thing, make sure to run it as administrator
nycweatherman1
« Reply #2 on: January 31, 2010, 07:17:21 AM »
Thanks GBW for your suggestion.. ok.. set to run as administer....
Now that I look into it more closely  Brick wall
I see that the connection between the console and the computer..stops.....
I close the program and restart it again.. Works fine for a bit and then the same thing happens.. Connection is lost
Could it be...... Brick wall The cord that I m using is from Radio Shack ---Gigaware  serial # 26-949.
Can anyone suggest a cord that is more stable?
Frankly  I m not really into buying a new cord... I have my fingers that running the program as administrator solves the problem.. I ll find out soon enough..LOL..
GBW
Online Online
« Reply #3 on: January 31, 2010, 12:17:38 PM »
also , if using a USB to serial adaptor, make sure windows is not set to power down the USB to save power
nycweatherman1
« Reply #4 on: January 31, 2010, 03:46:37 PM »
.....I m sure you guys were waiting for this: How do I make sure windows is not set to power down the USB to save power ??
Readings are still freezing up....
nycweatherman1
« Reply #5 on: January 31, 2010, 03:50:33 PM »
power plan is already set for high performance
nycweatherman1
« Reply #6 on: January 31, 2010, 04:35:20 PM »
I moved the USB to another port... and as a fail safe I purchased another cable following another members suggestion (Startech
( http://www.startech.com/item/ICUSB232-USB-to-RS-232-Serial-DB9-Adapter.aspx )-
So either way.. I hope to get this resolved...
Any suggestions are always welcomed and appreciated...
Regards
« Last Edit: February 01, 2010, 08:08:33 AM by nycweatherman1 » Logged
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
Page created in 0.213 seconds with 18 queries.
