May 21, 2013, 01:31:51 AM *
Members: 6615  •  Posts: 178459  •  Topics: 18110
Please welcome Christea, our newest member.
Author Topic: Switching from VWSaprs to Weather Display for CWOP reporting  (Read 3526 times)
lddaly
Plano, Texas - USA
« on: January 28, 2010, 11:34:22 AM »
I will be switching my update application for CWOP data. Do I need to contact them? Anything else I should be aware of?
ocala
« Reply #1 on: January 28, 2010, 01:56:24 PM »
I don't think it matters what software you use to upload your data. Just that you do it.
That is if I understand your  question correctly.
Also they do request that your updates are offset. By that I mean instead of uploading at 12.00, upload at 12.03, 12:18, 12:33 etc.
Their servers get very taxed when everyone does it at the top of the hour.
Weather Display
Online Online
« Reply #2 on: January 28, 2010, 02:11:47 PM »
WD sends the data at the minute that corresponds to the last number in your CWOP number
so thats OK
W Thomas
Welcome To My World Of Dishes
In Loving Memory Of Hooker The Weather Dog !
« Reply #3 on: January 28, 2010, 09:58:51 PM »
I just done this a while back and can tell you that it does not matter as far as the system goes, it will auto detect what you are updating with and the station type from the  information string sent by the software. In a hour or so you should see the change from VWS to Weather Display on your intro page at CWOP.
Enjoy !  Dancing
     Best Regards
     Wayne
CW8217
CoCoRaHS VA-SM-1
KVAMARIO3 Wunderground
VWS 14.00 P45   OS WMR 968 &  Davis Vantage VUE / Dedicated Server
lddaly
Plano, Texas - USA
« Reply #4 on: January 28, 2010, 10:08:17 PM »
Thanks everyone. I will make the switch when the weather is a little less interesting here.
92merc
BismarckWeather.net
BismarckWeather.net
« Reply #5 on: January 29, 2010, 09:34:06 AM »
I switched from VWS to VPLive with no issues.  It just picked it up and went.
BismarckWeather.net
mackbig
« Reply #6 on: January 30, 2010, 08:18:13 AM »
I made the same switch... was painless. I am sure you thought of this, just remember to take vwsaprs out of your startup...
Andrew
W Thomas
« Reply #7 on: January 30, 2010, 06:13:21 PM »
I went the VPLive route first as I wanted to do but for some reason it had a terrible time locating my station comport.
And I changed things in a hurry so I didn't mess around with it too much at that time and just let WD handle that part of the show.
May go back and play around with it some more later just to be sure.
I need to add VirtualVP so maybe that will be a good time to implement the change..
Steve definitely has some excellent products.
     Best Regards
     Wayne
CW8217
CoCoRaHS VA-SM-1
WXMoab
« Reply #8 on: February 15, 2010, 10:22:40 PM »
On the subject of upload offset, does anyone know if there is a way to set VP Live up with an offset? I don't see any options for this. Mine is running on the hour (every 10 min) right now. It hasn't always done this. I have seen it much of the time running on the 9s (09, 29, 39, etc.).
Wireless Vantage Pro 2
http://www.mark74.com/weather
George Richardson
« Reply #9 on: February 15, 2010, 10:54:12 PM »
Mark,
To the best of my knowledge, VPLive picks up its CWOP upload time from the last digit of your CWOP number. In addition to the final digit, there is a random addition of between +59 seconds and -59 seconds. This is done to limit the server burden of high volume uploads. Therefore, with my number of CW6097, my uploads are between 6:01 and 7:59 at 10 minute intervals. And Steve, if this has been revised, please accept my apologies.
FWIW
George
WXMoab
« Reply #10 on: February 15, 2010, 11:37:32 PM »
Okay, thanks. My number is 3889 so it appears that its working as you say.
Weather Display
Online Online
« Reply #11 on: February 16, 2010, 04:46:56 AM »
WD does something similar, with the minute to send data based on the last digit of your CWOP number, to help to reduce peak load on the servers
lddaly
Plano, Texas - USA
« Reply #12 on: April 27, 2010, 10:59:02 PM »
Just following up: I finally moved CWOP and Weather Underground reporting tasks over to Weather Display yesterday. No issues. I am now completely transitioned to WD Dancing.
Page created in 0.115 seconds with 19 queries.
