May 24, 2013, 06:58:21 PM *
Members: 6620  •  Posts: 178806  •  Topics: 18140
Author Topic: Davis Weather Wizard III with Weatherlink - VB6 to VB8  (Read 2008 times)
cmgaskins
« on: December 24, 2009, 09:47:36 PM »
I have a program written in VB6 that gets the weather data from the Weather link, I am trying to convert this to VB8 and everything seems to be working except the Wind Direction is showing an 8-digit number example - 65011806 is there anyone here that has seen this problem?
Using Davis supplied - weatherlink.dll
Public Class frmMain
    Private Sub frmMain_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        Dim rc As Integer
        rc = OpenCommPort(1, 2400)
        If rc <> 1 Then
            MsgBox("Can't open com port")
            Me.Close()
        End If
        Me.lblOutSideTemp.Text = CStr(GetOutsideTemp)
        Me.lblTodayHigh.Text = CStr(GetHiOutsideTemp)
        Me.lblTodayLow.Text = CStr(GetLowOutsideTemp)
        Me.lblInSideTemp.Text = CStr(GetInsideTemp)
        Me.lblWindSpeed.Text = CStr(GetWindSpeed)
        Me.lblWindGust.Text = CStr(GetHiWindSpeed)
        Me.lblWindDir.Text = CStr(GetWindDirection)
    End Sub
End Class
Module WeatherLink
    Public Const NOT_SET = -100
    Public Const COM_ERROR = -101
    Public Const MEMORY_ERROR = -102
    Public Const COM_OPEN = -103
    'Initialization Functions
    Declare Function OpenCommPort Lib "weatherlink.dll" (ByVal comPort As Integer, ByVal baudRate As Long) As Integer
    Declare Function OpenCommPortStr Lib "weatherlink.dll" (ByVal comPort As String, ByVal baudRate As Long) As Integer
    Declare Function CloseCommPort Lib "weatherlink.dll" () As Integer
    Declare Function SetupRainCollector Lib "weatherlink.dll" (ByVal RainClickInc As Single, ByVal NativeUnit As Integer, ByVal DisplayUnit As Integer) As Integer
    'Low Level Calls
    Declare Function GetSerialChar Lib "weatherlink.dll" () As Integer
    Declare Function PutSerialChar Lib "weatherlink.dll" (ByVal s1 As Byte) As Integer
    Declare Function PutSerialStr Lib "weatherlink.dll" (ByVal s1 As String) As Integer
    'General Functions
    Declare Function GetDllVersion Lib "weatherlink.dll" () As Single
    Declare Function GetOutsideTemp Lib "weatherlink.dll" () As Single
    Declare Function GetWindChill Lib "weatherlink.dll" () As Single
    Declare Function GetInsideTemp Lib "weatherlink.dll" () As Single
    Declare Function GetModelNo Lib "weatherlink.dll" () As Integer
    Declare Function GetTotalRain Lib "weatherlink.dll" () As Single
    Declare Function GetDailyRain Lib "weatherlink.dll" () As Single
    Declare Function GetYearlyRain Lib "weatherlink.dll" () As Single
    Declare Function SetCommTimeoutVal Lib "weatherlink.dll" (ByVal ReadTimeout As Integer, ByVal WriteTimeout As Integer) As Integer
    Declare Function SendSensorImages Lib "weatherlink.dll" (ByVal n As Integer) As Integer
    Declare Function StopSendingImages Lib "weatherlink.dll" () As Integer
    Declare Function PutBarometer Lib "weatherlink.dll" (ByVal Barom As Single) As Integer
    Declare Function GetWindSpeed Lib "weatherlink.dll" () As Single
    Declare Function GetWindDirection Lib "weatherlink.dll" () As Integer
    Declare Function GetStationTime Lib "weatherlink.dll" (ByVal DateTimeStation As DateTime) As Integer
    Declare Function SetStationTime Lib "weatherlink.dll" (ByVal DateTimeStation As DateTime) As Integer
    Declare Function SetArchiveInterval Lib "weatherlink.dll" (ByVal intervalCode As Integer) As Integer
    Declare Function GetArchiveInterval Lib "weatherlink.dll" () As Integer
    Declare Function PutTotalRain Lib "weatherlink.dll" (ByVal TotalRain As Single) As Integer
    'Hi's Lows
    Declare Function GetHiLowTimesOutTemp Lib "weatherlink.dll" (ByVal DateTimeHiOutTemp As DateTime, ByVal DateTimeLowOutTemp As DateTime) As Integer
    Declare Function GetHiLowTimesInTemp Lib "weatherlink.dll" (ByVal DateTimeHiInTemp As DateTime, ByVal DateTimeLowInTemp As DateTime) As Integer
    Declare Function GetHiLowTimesOutHum Lib "weatherlink.dll" (ByVal DateTimeHiOutHum As DateTime, ByVal DateTimeLowOutHum As DateTime) As Integer
    Declare Function GetHiLowTimesInHum Lib "weatherlink.dll" (ByVal DateTimeHiInHum As DateTime, ByVal DateTimeLowInHum As DateTime) As Integer
    Declare Function GetHiLowTimesDewPt Lib "weatherlink.dll" (ByVal DateTimeHiDewPt As DateTime, ByVal DateTimeLowDewPt As DateTime) As Integer
    Declare Function GetHiInsideTemp Lib "weatherlink.dll" () As Single
    Declare Function GetLowInsideTemp Lib "weatherlink.dll" () As Single
    Declare Function GetHiOutsideTemp Lib "weatherlink.dll" () As Single
    Declare Function GetLowOutsideTemp Lib "weatherlink.dll" () As Single
    Declare Function GetHiInsideHum Lib "weatherlink.dll" () As Integer
    Declare Function GetLowInsideHum Lib "weatherlink.dll" () As Integer
    Declare Function GetHiOutsideHum Lib "weatherlink.dll" () As Integer
    Declare Function GetLowOutsideHum Lib "weatherlink.dll" () As Integer
    Declare Function GetHiDewPt Lib "weatherlink.dll" () As Single
    Declare Function GetLowDewPt Lib "weatherlink.dll" () As Single
    Declare Function GetLowTimesWindChill Lib "weatherlink.dll" (ByVal DateTimeLowWindChill As DateTime) As Integer
    Declare Function GetLowWindChill Lib "weatherlink.dll" () As Single
    Declare Function GetHiTimesWindSpeed Lib "weatherlink.dll" (ByVal DateTimeHiWindSpeed As DateTime) As Integer
    Declare Function GetHiWindSpeed Lib "weatherlink.dll" () As Single
End Module
jruys
Yo
« Reply #1 on: December 26, 2009, 11:06:33 AM »
That is odd that it is giving you that high 8 digit number.  I was looking at the documentation and it looks like the return type on GetWindDirection should be a short not an int.  That shouldn't really have really mattered, but who knows, it is worth a shot trying to change it.
cmgaskins
« Reply #2 on: December 26, 2009, 01:03:45 PM »
Thanks jruys!!!! Very Happy
That fixed it; it is always the simple things that are over looked.
jruys
Yo
« Reply #3 on: December 26, 2009, 06:59:03 PM »
Great, I am glad that it worked.  There must be some marshalling problems when you ask for an int instead of a short.
cmgaskins
« Reply #4 on: December 27, 2009, 07:46:18 PM »
Has anyone ever setup the Weatherlink to download to a database? I know Davis offers this in Excel; what I have now is that it gets the current data every minute then saves it every hour to a database by Visual Basics. The only thing is if for some reason the computer goes down I have lost data. If it were setup to download the data instead of what is current at that hour would be best that way if the computer was to go down it would catch the missed data when the computer was rest. I’m not that good with Visual Basics any help would be appreciated, I know how to call it to download but I don’t know how to put it to a database.
jruys
Yo
« Reply #5 on: December 27, 2009, 11:04:09 PM »
First you are going to need to create a couple of Types (structs):
(I have not tried this and I am more of a c# guy, but here is my shot at VB code)
Declare Function Download Lib "weatherlink.dll" (DnloadOptions As Options, ByVal DnloadFileName As String) As Integer
Declare Function GetArchiveRecord Lib "weatherlink.dll" (arcRecord As WeatherRecord, ByVal RecNo As Integer) As Integer
Type Options
 UseDialogBox As Byte
 ClearArchive As Byte
 WriteToFile As Byte
 AppendToFile As Byte
End Type
Type WeatherRecord
   month As Integer
   day As Integer
   hour As Integer
   min As Integer
   hiOutsideTemp As Single
   lowOutsideTemp As Single
   insideTemp As Single
   outsideTemp As Single
   barometer As Single
   insideHum As Integer
   outsideHum As Integer
   dewPoint As Single
   rain As Single
   windSpeed As Single
   hiWindSpeed As Single
   windChill As Single
   windDirection As Integer
End Type
Sub DownloadData
    Dim opts As Options
    Dim numRecs As Integer
    Dim fileName As String = "filename.txt" 'If you want to download to a file
    Dim i As Integer = 0
    Dim wRec As WeatherRecord
    opts.UseDialogBox = 0  'Don't use Dialog
    opts.ClearArchive = 1   'Clear the archive (You can do this so you do not have to check what your last record in the database was and then search through the downloaded records)
    opts.WriteToFile = 0     'Don't write to a file
    opts.AppendToFile = 0  'Don't append to a file
    numRecs = Download(opts, ByVal fileName)
    'Loop through the records
    Do While i < numRecs Loop
        GetArchiveRecord(wRec, ByVal i) 'Fills the wRec structure
        'Add database code here
    End Loop
End Sub
I hope that helps, just remember that I have not used VB for quite a while, so there maybe some syntax errors, but I think it is pretty close.
cmgaskins
« Reply #6 on: December 28, 2009, 06:36:37 PM »
Thanks again jruys!
Works Great.
Option Explicit
Option Private Module
Dim adoconn As New ADODB.Connection
Dim rs As New ADODB.Recordset
Public Function DoUpdate(verbose As Boolean) As Integer
   Dim openResult As Integer
   Dim updateResult As Integer
   Dim clearAfterUpdate As Boolean
   Dim str As String
    Set adoconn = Nothing
    adoconn.Open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & App.Path & "\Weather.mdb;Persist Security Info=False"
    str = "select * from Weather"
    rs.Open str, adoconn, adOpenDynamic, adLockPessimistic
   If openResult < 0 Then
      If verbose Then
         MsgBox prompt:="Unable to open station.", Title:="Error"
      End If
      CloseCommPort
      DoUpdate = openResult
      Exit Function
   End If
      updateResult = UpdateMonWizPerc(clearAfterUpdate, verbose)
End Function
Private Function UpdateMonWizPerc(clearAfterUp As Boolean, verbose As Boolean) As Integer
   Dim result As Integer
   Dim sI As SensorImage, wR As WeatherRecord
   Dim numRecs As Integer, lastRec As Integer
   Dim newRecCount As Integer
   Dim opt1 As Options
   opt1.AppendToFile = 0
   opt1.UseDialogBox = 0
   opt1.WriteToFile = 0
   opt1.ClearArchive = 1
   lastRec = Download(opt1, "")
   lastRec = lastRec - 1
   newRecCount = 0
   Dim recordDate As Date
   Dim r As Integer
   Dim today As Date
   today = Date
   For r = 0 To lastRec
      ' Load wR with the r'th record
      result = GetArchiveRecord(wR, r)
      If month(today) < wR.month Then
         recordDate = CDate(Format(wR.month) + "/" + Format(wR.day) + "/" + _
            Format(Year(today) - 1) + str(wR.hour) + ":" + Format(wR.min))
      Else
            Format(Year(today)) + str(wR.hour) + ":" + Format(wR.min))
      End If
     ' If recordDate > lastDateInDb Then ' add to the database
         ' update the new record counter
         newRecCount = newRecCount + 1
            ' transfer the data to the Database
            rs.AddNew
            rs("Date_Time") = recordDate
            rs("OutSideTemp") = GetOutsideTemp
            rs("HighOutSideTemp") = GetHiOutsideTemp
            rs("LowOutSideTemp") = GetLowOutsideTemp
            rs("WindSpeed") = GetWindSpeed
            rs("HiWindSpeed") = GetHiWindSpeed
            rs("WindDirection") = GetWindDirection
            rs("DailyRain") = GetDailyRain * 0.1
            rs.Update
   Next r
   adoconn.Close
End Function
jruys
Yo
« Reply #7 on: December 29, 2009, 09:42:36 AM »
Hi cmgaskins,
   It appears that you are still using the current data to populate your database, not the WeatherRecord struct near the bottom of your code.  Not sure if that was intentional or not.  I would have thought you would have did something like:
Code:
rs("OutSideTemp") = wR.outsideTemp
.  The way your code is written you would still have the problem of missing data if your computer was off.
cmgaskins
« Reply #8 on: December 29, 2009, 10:30:57 AM »
Jruys, you are correct. Guess that’s why I need help from the pros, I'm learning just slow........ Confused
Page created in 0.092 seconds with 19 queries.
