May 22, 2013, 05:09:38 PM *
Members: 6617  •  Posts: 178587  •  Topics: 18124
Please welcome TheMOX, our newest member.
Author Topic: WRM968 12vdc Current Draw  (Read 1023 times)
panamapat
« on: October 01, 2009, 02:44:34 PM »
Am interested in running the WRM968 directly off a 12vdc battery source (solar powered) and was wondering if anyone can provide a current measurement on real world (w/o backlight on).  I understand that the 120vac/12vdc adapter is rated for 300ma, but I'm assuming that is rated high enough to cover the backlight current draw and actual current draw w/o backlight is much lower.
Much appreciated if you have this info.
Pat
mackbig
« Reply #1 on: October 01, 2009, 05:14:55 PM »
if I was feeling lucky, I could unplug mine and put it in the "killawatt" to check.   I guess I just blew my ytd rain last week, so at least I know how to fix it, if I encounter a problem.
Andrew
panamapat
« Reply #2 on: October 14, 2009, 10:48:22 PM »
Andrew
Thanks Andrew - I was able to get some readings from an existing unit:
162ma with backlight
16 ma w/o backlight = =0.384 amp-hour/day
With this low a current draw, it would be no problem at all to have it powered directly with the solar powered 12vdc power source (direct wired w/o using included 110/12vdc adapter) year round .
Pat
Page created in 0.101 seconds with 19 queries.
