May 25, 2013, 09:14:30 AM *
Members: 6623  •  Posts: 178865  •  Topics: 18148
Pages: 1 [2] 3   Go Down
Author Topic: WeatherLink Update 5.9.0 is available.  (Read 12236 times)
Bunty
Stillwater marks the spot.
« Reply #25 on: February 15, 2010, 10:47:22 PM »
You mean it's no longer beta?
Mark / Ohio
Live from Mars!
« Reply #26 on: February 16, 2010, 12:08:14 AM »
Looks that way..
What's new in 5.9.1
   1. Increased effectiveness in detecting a USB driver dropout. Driver will be restarted automatically and a note will be put into the View Log fie.
   2. Increased a timeout value to ensure High/Low data is received before uploading to CWOP or a personal website. Eliminates the “Data read error” when performing these uploads.
   3. Fixed Open Plot problem introduced in 5.9.0.
   4. Air density unit can now be set to “kg/cu m” or “lb/cu.ft”.
   5. Streaming Data Utility updated with a new field of "Max Effective Rain Total".
   6. Changed default values in Streaming Data Utility.
   7. .NET is not included in this web download. If needed, installation will download it from Microsoft.
http://davisnet.com/support/weather/software.asp
Cienega32
« Reply #27 on: February 16, 2010, 12:33:02 AM »
Where's the line that says:
No longer will make you pull your hair out and drink excessively if using concurrently with other weather software packages...
johnd
« Reply #28 on: February 16, 2010, 02:42:45 AM »
But would anyone ever really expect it to work _concurrently_ (unless you use VVP of course) - that's not a Weatherlink problem, it's to do with how PC hardware like serial and USB ports behaves.
Aardvark
Weatherdisplay
« Reply #29 on: February 16, 2010, 07:15:08 AM »
I downloaded and installed it and it wouldn't recognize my cfg file.  Gave me nothing but problems, so I downloaded 5.8.3 and sticking with that.  Davis' s explanation it is built for 64 bit computers yet.   that is hard to believe they haven't moved in that direction yet...
Davis VP2 Plus;Daytime FARS; Extra Temp Humid sensor (2); Extra Temp Station (2); Soil Moisture/Temp Station;Weatherlink IP; Weatherlink Serial and USB;Windows 7; Webcam
Cienega32
« Reply #30 on: February 16, 2010, 01:46:17 PM »
Using VVP goes without saying with concurrent usage, doesn't it?
It became a WLink problem to me when, only after upgrading to 5.9.x, it decided to completely revolt under VVP usage. Rolling back to 5.8.3 cured it for me (and I think some others as well). I won't run 5.9.x until everyone here has no problems with it.
dalecoy
« Reply #31 on: February 16, 2010, 02:59:00 PM »
OK, you're here, you're running 5.8.3, so that's self-fulfilling prophecy.
I sympathize - but has Davis ever said that WeatherLink is compatible with VVP?
Does VVP say that it's compatible with WeatherLink?
SLOweather
Administrator
« Reply #32 on: February 16, 2010, 03:24:27 PM »
My VVP has been running VWS, WD, WL, and a TCP/IP port for a serial-ethernet adapter for >113 days now. I doubt Davis would say WL was compatible, if only that VVP is not a Davis product and they wouldn't want to support it.
OTOH, VVP makes virtual ports LOOK like VPs or Vues over virtual ports, so any well-written program shouldn't be able to tell the difference. That's the whole point...
Mark / Ohio
Live from Mars!
« Reply #33 on: February 17, 2010, 01:04:37 AM »
...It became a WLink problem to me when, only after upgrading to 5.9.x, it decided to completely revolt under VVP usage. Rolling back to 5.8.3 cured it for me (and I think some others as well).
Same here.
I won't run 5.9.x until everyone here running VirtualVP has no problems with it.   Wink
W3DRM
« Reply #34 on: February 17, 2010, 01:10:48 AM »
Same here.
Ditto here - I gave up after several tries. Anyway, 5.8.3 is running fine for me with VVP...
Don - W3DRM - Minden, Nevada --- Davis Wireless VP2, VWS 14.00 p101,
StartWatch, VirtualVP, VPLive, WL 5.9.3, Win7 Ultimate-SP1
--- Logitech QuickCam Fusion webcam
Cienega32
« Reply #35 on: February 17, 2010, 10:45:00 AM »
Yup, that's what I meant.
Cienega32
« Reply #36 on: February 17, 2010, 11:17:38 AM »
Being that VVP has a nifty graphic of a Davis Console on it, that would impress me as being more use-specific to a Davis Console and being the data logger is bundled with WLink, I would have to conclude that compatibility is very much implied.
Removing assumption - the VVP Docs states that it "allows you to safely connect multiple weather programs to a single Vantage Pro, Vantage Pro2, or Envoy device." Illustrations thru-out include screenshots of our favorite softwares and even WeatherLink.
5.9.x sure threw a wrench into the mix and VVP is too sweet & smooth for me to worry about using that version when none of the improvements to it really affect me (as far as I know).
Bushman
« Reply #37 on: February 17, 2010, 11:21:19 AM »
Off teh softwx site:
Nov 8, 2009
Released VirtualVP v. 1.2.2
Added support for the WeatherLink 5.9.0.
dalecoy
« Reply #38 on: February 17, 2010, 12:00:16 PM »
How will you know?  You're expecting everybody running VVP to report having "no problems"?
Especially since (in general) VVP users never seem to post what version of VVP they are using.
Seriously - if whatever you are using is working, and has all the features you need, there's no reason to change.
Cienega32
« Reply #39 on: February 17, 2010, 10:34:20 PM »
Nov 8, 2009
Same version I'm using.
Mark / Ohio
Live from Mars!
« Reply #40 on: February 17, 2010, 10:37:03 PM »
....How will you know?  You're expecting everybody running VVP to report having "no problems"?
Well sure. Mr. Green People don't always come here just to complain you know.   Wink
We're lucky to know what weather station is in use on a lot of newbie posts.  At least if they are using VVP that narrows the field a bit.   Laughing
Yeah but for every piece of software I run there is at least one little nagging quirk and for me anyway it is only a matter of time before the curiosity of what new quirk maybe lurking in the upgrade gets to me and I breakdown and try it.    Anxious
I have a three day weekend coming up thanks to my work hours being cut again.   d'oh!  So I'll probably get the chance to load it on my laptop first and see if there is any improvement over the beta 5.91 I tried before going to the trouble of putting it back on the weather computer.   toast
« Last Edit: February 17, 2010, 10:38:55 PM by Mark / Ohio » Logged
Mark / Ohio
Live from Mars!
« Reply #41 on: February 17, 2010, 10:42:37 PM »
Nov 8, 2009
I'm showing version 1.2.3.69 on mine.   (In the "Help", "About VirtualVP" section)
« Last Edit: February 17, 2010, 10:45:45 PM by Mark / Ohio » Logged
Cienega32
« Reply #42 on: February 17, 2010, 10:53:56 PM »
I agree - no reason at all.
And yes, I would think that the ones who had struggles and posted in the thread as such, would report if they had gleaming success. That's how it's been in the past...
Cienega32
« Reply #43 on: February 17, 2010, 10:58:10 PM »
Nov 8, 2009
I was under the impression that 1.2.3 was a 64-bit update so I passed on it.
(1.2.2.12 in the abouts for me)
Mark / Ohio
Live from Mars!
« Reply #44 on: February 17, 2010, 11:03:57 PM »
He just fixed a bug to make it compatible in that version w/ 64 bit.  It's running fine on my 12 year old 466Mhz weather computer.
Mark / Ohio
Live from Mars!
« Reply #45 on: February 20, 2010, 11:02:16 PM »
....I won't run 5.9.x until everyone here running VirtualVP has no problems with it.   Wink
Well I tried it both on my laptop and the regular weather computer since it is tied direct to the station via serial port just to be sure of my findings.  Also tried is briefly tied into Virtual VP via tcp/ip connection rather then my usual comport.  Results the same.   Sad
My download errors went from 4/day Thursday with 5.8.3 to over 20 today with 5.9.1.  (Downloading every 15 minutes.)  Worse was I had two "connection lost" errors in which WeatherLink sets there waiting for the error to be cleared and does not seem to even attempt reconnection in the background.  (Both times it sat that way for about 6 hours before I discovered it had stopped running.)
For software that is often running unattended possibly for days at a time by it's users that's lousy coding right there if you ask me.   Rolling Eyes
dalecoy
« Reply #46 on: February 21, 2010, 12:15:27 AM »
Can we presume that all of you folks who are having problems with 5.9.x, are reporting those problems to Davis?
Reporting the problems here is great - but it won't get the problems fixed.
Mark / Ohio
Live from Mars!
« Reply #47 on: February 21, 2010, 12:21:59 AM »
I'm still trying to decide whether to report it to Davis or Tinplate @ SoftWx.   d'oh!  (Thus the poll I just posted.)  If this is truly a Virtual VP issue, reporting it to Davis would probably be little more then a waste of time.
Edit, Last time I tried to get a software issue resolved with Davis I never did get any reply.  The front line mechanical support guys (who have always been great when contacted) tried several times to get me some help from the WL software folk with no luck.  This was several years ago on a dial up issue.  Maybe they are better now?
« Last Edit: February 21, 2010, 12:27:09 AM by Mark / Ohio » Logged
Cienega32
« Reply #48 on: February 21, 2010, 01:03:39 AM »
Wasn't the 5.9.x release an update meant to included the VUE or am I "misremembering"?
Mark / Ohio
Live from Mars!
« Reply #49 on: February 21, 2010, 01:39:17 AM »
I think your right.  Seems like I read somewhere there were additional data transfers or commands going on with the firmware in the Vue console compared to the VP.
Also off hand I don't recall anyone posting using VirtualVP with a Vue yet.  That was one question I thought I could solve with the poll.  Last I heard Steve was still not transferring all of the possible commands through VirtualVP for the VP in the console settings area.  I'm sure this change has made a real headache for him.  Come to that probably for the software guy at Davis too.   Laughing
« Last Edit: February 21, 2010, 01:41:37 AM by Mark / Ohio » Logged
Pages: 1 [2] 3   Go Up
Page created in 0.229 seconds with 19 queries.
