Author Topic: 92.62.43.77:6667  (Read 2437 times)
Offline Axelvold
92.62.43.77:6667
« on: September 18, 2009, 05:02:45 PM »
I have a lot of these in my weblog, 92.62.43.77:6667 is there any way to prevent those visitors?
Lars Magnusson
Axelvold / Sweden
55 57' 41" N / 13 6' 1" E
Re: 92.62.43.77:6667
« Reply #1 on: September 18, 2009, 08:37:13 PM »
According to the RIPE Whois at www.ripe.net
% This is the RIPE Database query service.
% The objects are in RPSL format.
% The RIPE Database is subject to Terms and Conditions.
% See http://www.ripe.net/db/support/db-terms-conditions.pdf
% Note: This output has been filtered.
%       To receive output for a database update, use the "-B" flag.
% Information related to '92.62.43.0 - 92.62.43.255'
inetnum:         92.62.43.0 - 92.62.43.255
netname:         NO-UNDERWORLD
descr:           Underworld IRC services Trondheim, Norway
descr:           IRC Infrastructure
country:         NO
admin-c:         UWIR-RIPE
tech-c:          UWIR-RIPE
status:          ASSIGNED PA "status:" definitions
mnt-by:          ITSJEFEN-LIR
source:          RIPE # Filtered
role:            Underworld Incident Response Team
address:         PB 1275 Pirsenteret
address:         NO-7462 Trondheim
address:         Norway
remarks:         92.62.43.77 runs the PROXYSCANNER for the Quakenet IRC Network.
remarks:         It will only scan you if you connect to the IRC network.
remarks:         For More Information see: http://www.quakenet.org/openproxies.html
remarks:         If you were scanned by that IP and believe you do not connect to QuakeNet
remarks:         - We suggest you get your system checked by a Virus/Trojan Scanner.
remarks:         trouble: Our preferred contact method is e-mail!
remarks:         trouble: hostmaster@underworld.no - for technical questions.
remarks:         trouble: abuse@underworld.no - for abuse notifications.
abuse-mailbox:   abuse@underworld.no
admin-c:         HRDY-RIPE
tech-c:          AKAI-RIPE
nic-hdl:         UWIR-RIPE
% Information related to '92.62.32.0/20AS44381'
route:           92.62.32.0/20
descr:           ITsjefen networks
origin:          AS44381
so whoever they are, they're in Norway.
You can use your cPanel to put a block on that IP address, but it would show up in the error log (I think) instead of the access log.   Are you offering any content (like a webcam) using the 6667 port?
Port 6667 UDP is used mostly by Internet Relay Chat and it's also used by Zombie PCs to communicate with a bot-master system.  Not a good thing.  You aren't hosting your site on your own PC are you?
Offline sam2004gp
  • Mount Crawford, Virginia
  • Weeeeeeeee!!!!
    • Mount Crawford Weather, VA
« Reply #2 on: September 18, 2009, 08:43:05 PM »
I think he is hosting it on his own box.
Offline Axelvold
« Reply #3 on: September 19, 2009, 02:33:58 AM »
Thats correct Sam, i'm running my own webserver
I conna check with my son if he is using IRC.
Lars Magnusson
Axelvold / Sweden
