Author Topic: VP2 Console Messages and Forecasts List  (Read 56735 times)
Offline George Richardson
    • Smith Mountain Lake Weather
Re: VP2 Console Messages and Forecasts List
« Reply #25 on: November 21, 2011, 10:38:00 AM »
"Can anyone shed light on the console's purported ability to "learn"? Does it exist? If so, how does it work?"
None of my 3 consoles have learned Jack. I look at the console forecast as a novelty. I use Wxsim for forecasts.
FWIW
George
Offline Skywatch
« Reply #26 on: November 21, 2011, 11:36:27 AM »
mcxTXaws wrote: "This is when the console is in the process of learning and adjusting to the climate and weather patterns. After a few weeks, the forecasting will be almost on the spot accurate."
Thanks.
Forecasting requires some data to be built up. No station the market that I know of can produce a forecast when first powered on. The Davis bases it's forecast on current conditions (wind temperature humidity air pressure any rain events even solar radiation on Plus models) and trends over a given period of time. Remember the forecast it gives is for the general area. Even if it says "Rain" or "Sun" thats for a large area. Give the console some time at least 3 hours the forecast will slowly become better as the console learns the weather patterns.
I am a storm chaser.
Offline d_l
  • Slide Mtn - Mt Rose
« Reply #27 on: November 21, 2011, 11:54:14 AM »
The 3 hour minimum time requirement is to allow the console to establish a 3 hour barometric trend.
--Dave--
Wireless VP2 w/ solar, 24hr FARS, Heater, (Envoy-WLIP)*3-Meteohub, plus custom VP2 @ 26', WL 6.0.3, WU & W4U=KNVRENO37 NetcamXL
Offline Skywatch
« Reply #28 on: November 21, 2011, 12:19:47 PM »
But still unless it knows the trend, like if the barometer was rising it won't say "rain"  It'll say "forecast not ready" after being powered up. Missing pressure trend is like the missing peice of the puzzle. For us when the wind is out of the south at 10-15 MPH temperature's are around 60-70 humidity is about 60% and the pressure drops like a bullet the console would display something like
"Increasing clouds and cooler, precipitation possible in 6 to 12 hr, windy with possible wind shift to W, NW or N". Without that pressure trend the console doesn't have a clear answer. The pressure trend is a vital puzzle peice.
Offline Dan Richman
« Reply #29 on: November 21, 2011, 12:36:47 PM »
A related question:
The documentation for the console says, "Your console generates a weather forecast based on the barometric reading & trend, wind speed & direction, rainfall, temperature, humidity, latitude & longitude, and time of year."
So apparently it doesn't factor in solar radiation or UV, right? I am hoping that perhaps it does, as including those would probably lead to better forecasts.
« Reply #30 on: November 21, 2011, 12:55:12 PM »
A related question:
How do you propose that UV and solar would lead to better forecasts??
Offline Skywatch
« Reply #31 on: November 21, 2011, 12:55:41 PM »
A related question:
It does if you email Davis tech support. Here's the email I got,
The solar data is used for some weather forecast predictions so it is possible that you will see different forecasts.
Eric Nickl
Technical Support
Davis Instruments
510-732-7814
support@davisnet.com
From: Matthew McGee [mailto:matthewjp-mcgee@att.net]
Sent: Tuesday, July 12, 2011 10:55 AM
To: Webmaster
Subject: Solar radiation data question.
Dear Davis, I had a question about VP2+ or a Vantage Pro with a solar radiation sensor on it. Before I added solar radiation to the station, the forecast used to confuse cloudy days saying, "clear skys" when clouds were rolling in. Since I added the solar radiation sensor, it's much more accurate on cloud conditions. Does the VP2 console put solar data into the forecasting algorithm equasion provided solar data is avalible through the solar radiation sensor?
Don't take my word for it. I'm only repeating what I was told.
« Last Edit: November 21, 2011, 12:57:26 PM by mckTXaws »
Offline Dan Richman
« Reply #32 on: November 21, 2011, 01:11:00 PM »
Great info, mckTXaws.
Thanks!
Dan
Offline meteo.quimper
« Reply #33 on: December 25, 2011, 11:53:02 AM »
Hi
I searching tips for translating (french) the firmware of the vp2 console ?
The firmware is available as single .bin file for using with the davis VP2 updater interface and as .exe file for direct updating within the davis dataloger 6510.
I opened the file VP2_1_90.exe with notepad++ and  i translated the word THANKS:
And now
« Reply #34 on: December 26, 2011, 03:37:47 PM »
i saved the file VP2_1_90.exe, stardted the upgrade, everything was ok, i restarted the console and.. the screen is freeze i can do nothing, i retry to upgrade with the original firmware, the console work now !!!
What is wrong the why the the console is was freezed ?
« Reply #35 on: January 03, 2012, 12:06:42 PM »
Maybe a checksum issue?  MERCI and Thanks are also different string lengths.  What happens if you use a string the same length as THANKS?
Offline dalecoy
    • Lee's Summit, MO
« Reply #36 on: January 03, 2012, 01:58:57 PM »
I agree it's probably a checksum issue.  However, the string that was substituted was the same length.  "MERCI "
« Reply #37 on: January 08, 2012, 11:13:57 AM »
hi
i also try with the MERCIS instead of MERCI, MERCIS had the exact number of letter than THANKS and same problem, when i put the original unmodified firmware the direct pc software say: bootloader ok, firmware: not, it's like when i want to upload the modified firmware, the console errase the instaled firmware (the bootloader stay untouched), but don't install the new translated firmware, no errors on the dialog but there is no reboot at the end, i must reboot the console myself, after the reboot the console only one beep and the display is freezed... everything goes ok if i retry to flash the console with the original firmware...
Offline dalecoy
    • Lee's Summit, MO
« Reply #38 on: January 08, 2012, 11:29:58 AM »
Just to check your process:
Take a copy of the original .bin file -
Replace "THANKS" with "MERCI " and save it.
Next edit it to replace "MERCI " with "THANKS", save it and try the console update.
If you carefully replace everything as original, and it works OK, then it is almost certainly a checksum issue.
« Reply #39 on: January 09, 2012, 09:33:47 PM »
hi
The checksums for THANKS and MERCIs are df89e795839ea42c0425275caa0e08fc and
e78dec48bcf672e3ad9042ae4191f27e respectively.  Different.  Sorry.  Maybe the .bin file will work.
What is bizarre to me is that there was  a guy in France who was able to  translate Weatherlink to French; I wrote him but never got a reply.  So it might be possible some way...
Offline DeKay
    • Mad Scientist Labs
« Reply #40 on: January 10, 2012, 01:47:03 PM »
I PM'ed C5250 on this.  He says there is no checksum in the BIN file so it would be the updater that is doing the check.  So I believe you should be able to mod the .BIN file and then use avrdude / ponyprog / whatever to get the new file on the console.  But that is just a theory.  Give it a try, and if it breaks, you get to keep both pieces.   :-)
« Reply #41 on: February 23, 2012, 05:20:03 AM »
Hi
I get the Davis VP2 updater (6311VP2) to put the modified firmware FLASH.BIN and i have the same problem that with the direct pc update, so the console made a checksum verification before flashing the new firmware...
I opened the updater and there is a ATMEGA 128L inside:
https://picasaweb.google.com/110350271154600350738/DavisVP2Updater6311VP2?authuser=0&authkey=Gv1sRgCN-Xi_-bjau61wE&feat=directlink
More infos about ATMEGA128 firmwares: http://wiki.hacdc.org/index.php/Secure_bootloader
« Last Edit: February 23, 2012, 06:36:13 AM by meteo.quimper »
Offline KF5APO
  • Active Skywarn Advanced Spotter/ Chaser.
« Reply #42 on: March 23, 2012, 07:33:24 PM »
I had been wondering about the ticker tape messages.
Thanks for Posting and Sharing them Guys!.
« Last Edit: March 23, 2012, 07:53:38 PM by KF5APO »
KF5APO
Andy
4" Stratus Rain Gauge
accurite temp station.
Future Recruit Davis VP2 model 6163 24 hr FARS.
Offline C5250
    • Local weather
« Reply #43 on: October 08, 2012, 11:40:39 PM »
Not sure if this has been documented anywhere, but I found this in the original VP firmware history doc...
if ( wind10Min >= 25 && wind10Min < 40 && currentGraph == 0)
// HOLD ONTO YOUR HAT
PushCommentNo (10);
if ( wind10Min >= 8 && wind10Min < 18 && currentGraph == 0 &&
windChill < 80 && windChill > 60 && GetRainStorm (CURRENT, 0) == 0
&& LightOutside ())
PushCommentNo (9);                   // KITE FLYING WEATHER
tmp = GetCurrentVar ();
if ( windChill <= -30 && windChill > -50 && wind10Min >=10
&& (tmp == WIND_SPEED_VAR || tmp == CHILL_VAR || tmp ==
TEMP_OUT_VAR))
PushCommentNo (1);                // LOW CHILL ADVISORY
if ( heatIndex >= 105 && heatIndex < 115 &&
(tmp == TEMP_OUT_VAR || tmp == HUM_OUT_VAR || tmp == HEAT_VAR || tmp ==
THSW_VAR) )
PushCommentNo (5);                      // HEAT ADVISORY
Dated as the 31 May 2001 version, so things might have changed since then.
Precious little in your life is yours by right and won without a fight.
Offline Bluezx636
« Reply #44 on: November 25, 2012, 07:24:31 AM »
Does the vantage vue mostly display whats in the first paragraph or is it totally different?
WIND WARNING, LOW WIND CHILL ADVISORY, WARNING, LOW WIND CHILL, DRESS WARMLY, FROSTBITE OR HYPOTHERMIA POSSIBLE, DANGEROUSLY LOW WIND CHILL,DANGER, EXTREMELY LOW WIND CHILL, RISK OF FREEZING EXPOSED SKIN, HIGH HEAT INDEX ADVISORY, WARNING, HIGH HEAT INDEX, HEATSTROKE OR HEAT EXHAUSTION POSSIBLE, DANGEROUSLY HIGH HEAT INDEX, DANGER, HIGH HEAT INDEX, HEATSTROKE OR HEAT EXHAUSTION LIKELY, KITE FLYING WEATHER, HOLD ONTO YOUR HAT, IT'S RAINING CATS AND DOGS, LAST 15 MIN. OF RAIN, LAST 24 HOUR OF RAIN, 10 MIN. AVG. WIND SPEED, LOW BATTERY ON STATION X, LOW CONSOLE BATTERIES, LOW BATTERY ON REPEATER
Offline C5250
    • Local weather
« Reply #45 on: November 25, 2012, 11:25:31 PM »
I thought I posted this before, but can't seem to find it...
Much the same, but there are some differences:
HIGH WIND WARNING
LOW CHILL ADVISORY
WARNING LOW WIND CHILL DRESS WARMLY FROSTBITE OR HYPOTHERMIA POSSIBLE
DANGEROUSLY LOW CHILL
DANGER EXTREMELY LOW WIND CHILL RISK OF FREEZING EXPOSED SKIN
HEAT INDEX ADVISORY
WARNING HIGH HEAT INDEX HEATSTROKE OR HEAT EXHAUSTION POSSIBLE
DANGEROUSLY HI HEAT IDX
DANGER HIGH HEAT INDEX HEATSTROKE OR HEAT EXHAUSTION LIKELY
KITE FLYING WEATHER
HOLD ONTO YOUR HAT
BLUE MOON
ITS RAINING CATS N DOGS
LUNAR ECLIPSE
SOLAR ECLIPSE
SPRING EQUINOX
SUMMER SOLSTICE
AUTUMN EQUINOX
WINTER SOLSTICE
LOW BATTERY TRANSMITTERn
LOW BATTERY REPEATER X
QUADRANTIDS METEOR SHWR
LYRIDS METEOR SHWR
E AQUARIDS METEOR SHWR
PERSEIDS METEOR SHWR
ORIONIDS METEOR SHWR
TAURIDS METEOR SHWR
LEONIDS METEOR SHWR
GEMINIDS METEOR SHWR
URSIDS METEOR SHWR
Offline jackman
    • Echo Pines WX Station
« Reply #46 on: January 03, 2013, 03:51:53 PM »
I got the message for the Quadrantid meteor shower on my new VVue console this morning. I went looking for how it knew and came upon this thread. Thanks for the info.
A very fun feature.
Offline TheMOX
« Reply #47 on: May 22, 2013, 09:38:48 AM »
I just bought a new Vantage Pro2 to replace my original (and weather beaten) Pro.  I plugged in the old WeatherlinkIP and got a new message (for the list)
Incompatible Datalogger
A swap replacement is on its way. Thanks to version 3.12 for checking for an "authentic" datalogger.
Offline moehoward4
  • Jack in SE MA.
« Reply #48 on: July 19, 2013, 03:17:57 PM »
'Dangerously High Heat Index'    94F temp., 81F DP 65% Humidity     and it is D*MN HOT here right now
3 Davis set-ups...which one ya wanna talk about? And I got ALL my manuals....
Offline fidsplice
« Reply #49 on: December 17, 2013, 05:52:15 AM »
Would be surprised if there is heuristic capability in the software (the ability to dynamically learn). The algorithms for weather prediction are pretty solid and accurate. Local influence doesn't change the big picture.
Re messages - there once was a wonderful entry in an IBM technical manual (when they were allowed to have a sense of humour, which said "Recursion: - see Recursion"
Chris W.
