May 23, 2013, 04:27:13 AM *
Members: 6617  •  Posts: 178631  •  Topics: 18128
Author Topic: FTP upload/webpage hangs  (Read 2520 times)
agford4x4
« on: July 25, 2009, 03:22:42 PM »
I have a recurring issue where after a couple of days, VWS stops updating my webpage.  It looks like it just fails to upload, but im not sure.
The error in the FTP log file is:
07/25/09,13:50:47,Maximum number of ftp connections already open,Login to home.comcast.net (Attempt 2)
The whole log file is filled with this error.  I have turned off 'rapid fire' as well but that hasnt fixed anything.
Any ideas?  I dont like having to restart the software every other day.
Weather Display
« Reply #1 on: July 25, 2009, 05:45:16 PM »
is it a free hosting plan?
i.e do they limit the number of ftp connections, etc?
mackbig
« Reply #2 on: July 25, 2009, 06:28:09 PM »
rapid fire does not use ftp... believe its an http send...
do you have any other programs uploading besides VWS?
You should considering consolidating all your ftp uploads with a Fling like product.  Then you should only have 1 connection at a time.
Andrew
agford4x4
« Reply #3 on: July 25, 2009, 09:45:38 PM »
Maybe i will try fling.  Its not a 'free' site, its with my ISP.  I dont have any other uploads going on that i know of.  It will work for 3 days sometimes and then just stop.
I have updated my software from p34 to p87...maybe that will fix it, i dont know.
« Last Edit: July 25, 2009, 09:52:42 PM by agford4x4 » Logged
Mark / Ohio
Live from Mars!
« Reply #4 on: July 25, 2009, 11:52:03 PM »
Checkout #3 in the list at the link below and see if any of the suggestions there might help.
http://ambientweather.wikispaces.com/FTP+Stops+Updating
port1
« Reply #5 on: July 25, 2009, 11:56:25 PM »
Exactly the reason I joined this forum!  Loads of helpful folks, and all friendly.  Cool
Henry
KNYFLORA5
WMR968
VWS v14.00 p73
CoCoRaHS NY-NS-7
CWOP DW1891
SKYWARN 09-148
agford4x4
« Reply #6 on: July 26, 2009, 12:16:55 AM »
Jackpot.
I bet that link will help!  Thanks guys!
If i end up using fling, how do i 'disable' the VWS FTP and still have all my images/webpages updated so they can be uploaded with fling?
« Last Edit: July 26, 2009, 12:30:05 AM by agford4x4 » Logged
mackbig
« Reply #7 on: July 26, 2009, 11:47:05 AM »
Under the internet menu do the following
1) FTP JPEG settings - FTP automated schedule - change "Update method" to "No update scheduled"
2) HTML Settings - Upload Files to internet - click the scheudule button next to all your htm files, change them all to "no update schedule"
Your jpg and htx processing is separate from ftp uploading. If you de-schedule your ftp jobs as above, all your processing will still occur.
Andrew
Jackpot.
agford4x4
« Reply #8 on: August 01, 2009, 01:07:29 AM »
OK, the software is still hanging.
Now i have downloaded fling and given it my vws/root folder.  What needs to get uploaded from there and how do i set up VWS to make sure everything is updated properly?  Where do i set how often the html files are updated and the jpegs are updated?
« Last Edit: August 01, 2009, 01:20:13 AM by agford4x4 » Logged
LeomaTNWX
« Reply #9 on: August 01, 2009, 09:09:09 AM »
I Fling all of the root folder. Go to properties and click the scan update tab at the top to set up the upload time. I upload mine every time the file changes.
sam2004gp
Mount Crawford, Virginia
Weeeeeeeee!!!!
« Reply #10 on: August 01, 2009, 09:09:55 AM »
The only thing that needs to be uploaded is your jpegs, and html files.
For Html Updates go to... internet > html settings and adjust the update timer.   Very Important, while there make sure your "Upload Files to Internet" schedules are turned off.
For Jpegs go to.. Settings > Jpeg File Settings and adjust the Jpeg Update Timer.   Also Very Important, then go to.. Internet > FTP Jpeg Settings > Click on FTP Automated Schedule and make sure that is off.
...then you make a "job" in Fling pointed to your html folder at 4 minute intervals to check for new ones of those.  And then do another "job" in Fling for your jpegs.
OR as mentioned above put all of the files in one folder for fling to process.
Ever since I started using fling my VWS hangups have disappeared.  I now run VWS for 35+ days without ever restarting it.  And the only reason I restarted it, was to shutdown and restart windows xp, after a disk image backup.
« Last Edit: August 01, 2009, 09:17:19 AM by sam2004gp » Logged
agford4x4
« Reply #11 on: August 01, 2009, 10:26:15 AM »
Oh wow....thanks a MILLION guys.
Its all set up....lets see how it works!
Thanks for hte help, it would have taken much longer without some guidance.
Mark / Ohio
Live from Mars!
« Reply #12 on: August 03, 2009, 12:15:23 AM »
Glad to hear your up and running!  Very Happy
Page created in 0.125 seconds with 19 queries.
