offroadjosh
« on: July 07, 2009, 02:17:17 PM » |
Decided to upgrade my computer today. So i went to our one and only computer store in town(kalispell isn't very big) I bought the following!
internal Harddrive-500GB Sea gate memory- 1gb(now will have 2 2gb) kingston
wireless network card(vs my usb stick)
Josh
Josh Patten  Davis VP2 Wireless -May 2008 VWS 14.00P90\WL 5.9.9/Plus others! Skywarn trained CoCoRaHS member Smith Valley Fire Dept Firefighter:) http://josh.northwestwx.com/station/usa.htmCWOP-DW0711 Kestrel 2000 hand held anemometer Cocorahs 4in rain gauge Custom co
Downlinerz2
« Reply #1 on: July 07, 2009, 04:41:21 PM » |
Josh, Have fun upgrading your computer!! It's always exciting waiting to see how the upgrades work together!!
port1
« Reply #2 on: July 07, 2009, 05:29:47 PM » |
Enjoy, Josh! Always fun getting inside the case.
KNYFLORA5 WMR968 VWS v14.00 p73 CoCoRaHS NY-NS-7 CWOP DW1891 SKYWARN 09-148
mackbig
« Reply #3 on: July 07, 2009, 05:32:15 PM » |
Josh, Has your pc always been wireless? Andrew wireless network card(vs my usb stick) Josh
 Andrew - Davis VP2+ 6163, serial weatherlink, wireless anemometer, running Weather Display. Boltek PCI Stormtracker, Astrogenic Nexstorm, Strikestar - UNI, CWOP CW8618, GrLevel3, (Station 2 OS WMR968, VWS 13.01p09), Windows 7-64
offroadjosh
« Reply #4 on: July 07, 2009, 05:53:51 PM » |
Got it all installed but it isnt seeing the new HD=\ idk why might have to look in the bios? Btw it has always been wireless i just wanted a card instead of the usb stick.
Josh
mackbig
« Reply #5 on: July 07, 2009, 06:14:25 PM » |
wireless-I see did not read properly
Is the drive sata? or IDE. type compmgmt.msc into run command, see if you can see the drive there....under disk management.
Andrew
offroadjosh
« Reply #6 on: July 07, 2009, 06:26:26 PM » |
got it! and its sata. i just gotta partition it and it will be good to go. So now i need advice...
I have a 160gb and this 500GB HD all my weather stuff is on the 160GB. I also have a 80GB External HD. Should i move all my weather stuff to the 500 since it is newer and then have it back up to the 80gb External or should i keep it all on the 160 and then have it back up to the 500 or the 80gb??
Josh
JOE
« Reply #7 on: July 07, 2009, 10:45:32 PM » |
I would leave all the weather stuff on the root drive. But that's just me. Use the slave drive for everything else.
offroadjosh
« Reply #8 on: July 08, 2009, 01:29:04 AM » |
I think i may do that:) Gotta say my puter is real zippy now. After a few things i need to purchase(VVP and startwatch) i may actually add another gb or ram:)
Josh
Arthurhh
« Reply #9 on: July 12, 2009, 04:48:30 AM » |
Josh
If you are 32 bit windows based remember it wont use more than 4Gb and wont install if there is more than 3Gb
offroadjosh
« Reply #10 on: July 12, 2009, 10:07:02 AM » |
So dont install more than 3gb?
Josh
Arthurhh
« Reply #11 on: July 12, 2009, 05:09:53 PM » |
Josh
Fit 3 or less to do windows install then upgrade that to 4 max once running
offroadjosh
« Reply #12 on: July 12, 2009, 06:37:25 PM » |
