May 20, 2013, 02:15:28 AM *
Members: 6609  •  Posts: 178315  •  Topics: 18104
Please welcome TargY, our newest member.
Author Topic: The Gauge  (Read 6581 times)
ocala
« on: June 27, 2009, 09:34:24 AM »
If the inner tube is full and overflowing into the outer tube check the reading on the inner tube before emptying.
I noticed the other day when this happens that the inner tube actually has 1.02 inches. Here I've been cheating my self out of .02 all this time.
wxtech
High Tech Septuagenarian
USAF Weather Equipment Maintenance Tech (retired)
« Reply #1 on: June 27, 2009, 09:44:45 AM »
CoCoRaHS put out the word last year that there are some gauges that actually hold more than exactly 1.00 inch.  The manufacturer made a new master mold and the first runs were wrong.  Later measuring cylinders are correct.
Looks like you can trim the notch down to make it contain less water.
Al Washington, Lexington, Ga., Davis VP2+ WLIP 5.9.2 w/soil temp, VP(original) serial.  Acu-Rite 1015/1010/639/1055 5-n-1/3-n-1, bridge beta test group,
NWS Coop station=LXTG1, Fischer Porter, SRG, MMTS.
CoCoRaHS=GA-OG-1 manual & electronic ET gauges. CWOP=CW2074. XP with serial port, VWS v14.01p0, laptop with Win7 and USB ports.
LarsWX
Senior Member
« Reply #2 on: June 27, 2009, 09:34:08 PM »
I noticed that on mine also, just give it a little shake while its in the outer cylinder to bring the level below 1 inch, write that down and dump, then add what remains. One of these days I will get my dremel tool out and fix mine. Cool
port1
« Reply #3 on: June 28, 2009, 06:17:17 PM »
My gauge and inner tube are accurate.  When I remove the funnel from the tube the meniscus sits exactly at one inch.  I suppose I was lucky to receive an accurate mold. Cool
KNYFLORA5
WMR968
VWS v14.00 p73
CoCoRaHS NY-NS-7
CWOP DW1891
SKYWARN 09-148
Anthony
« Reply #4 on: June 29, 2009, 08:20:24 AM »
My instructions for reading the quage when the inner tube has over flowed into the outter guage is as follows.
1 pour the water in the inner tube into the outter tube.
2 then pour the water from the outter tube into the smaller tube until it reads 1".
3 repeat until no water remains in the outter tube.
Be sure to place the funnel cap on top of the small tube. This will make pouring the water from the lage tube into the smaller tube easier.
Anthony
WB8YUE
wxtech
« Reply #5 on: June 29, 2009, 08:26:13 AM »
You'll need to put the inner cylinder in a bowl to catch any overflow.  Any spillage is lost forever.  You won't know how much is lost.
Or
Just fill the inner cylinder part full each time to prevent spillage, and add the amounts.
ocala
« Reply #6 on: June 29, 2009, 12:48:22 PM »
You know it's always a pain to empty the large gauge into the small  one after heavy rain events.
I think I'm going to mark the large gauge so I can just look at  and see the total.
I wonder why they didn't mark the outer gauge to begin with?
I know, they are probably looking for accuracy but I pretty sure it can be done accurately if I take my time.
d_l
Slide Mtn - Mt Rose
« Reply #7 on: June 29, 2009, 01:25:28 PM »
Over a period of time, say 5-10 years, the outer gauge crazes from UV which would make it virtually impossible to accurately read any measurment markings. Heck, I can't even read the inner tube rain levels through the crazing, it has gotten so bad after over a decade.
--Dave--
Wireless VP2 w/ solar, 24hr FARS, Heater, (Envoy-WLIP)*2-Meteohub, WL 6.0.0, WU & W4U=KNVRENO37 NetcamXL
People always talk about the weather, but they never do anything about it.  Not me.  I'm gonna measure it.  www.tceweather.com
ocala
« Reply #8 on: June 29, 2009, 02:31:33 PM »
You have been using it for a decade Shocked
Maybe time for a new one? Smile
wxtech
« Reply #9 on: June 29, 2009, 02:39:45 PM »
You should then specify in the precipitation report form comments that you are not using CoCoRaHS rules for measuring.  Run your ideas past your local and regional coordinators.
tomcj2
« Reply #10 on: June 29, 2009, 02:46:18 PM »
How many days a year do you get more that 1 inch of rain?
Davis VP2 (6163), WL 5.9.0..  VWS 14.01 p25, Panasonic HM371A camera. WU & W4U KORCANBY3, CoCoRaHS OR-CC-27
ocala
« Reply #11 on: June 29, 2009, 03:16:55 PM »
It averages about 10.
floodcaster
« Reply #12 on: June 29, 2009, 06:35:05 PM »
The funnel and inside tube combination help to magnify the amount to facilitate reading to the nearest hundredth of an inch. It would be difficult reading the outer gauge to this precision.
Bill
CoCoRaHS observer and regional coordinator.
Bill
Pick
Senior Member
« Reply #13 on: October 26, 2009, 04:28:42 PM »
We get quite a few rain events over 1". I am excited to have a decent, accurate gauge, when mine gets here.
Back in Ohio, where I grew up, anything over an inch could sometimes have disastrous results.
Mike
Vantage Vue
Weather Display 10.37O
CoCoRahs FL-AL-17
KFLHIGHS1
JOE
« Reply #14 on: October 28, 2009, 10:09:50 AM »
Do these gauges break or crack if they freeze?
Joe
www.centraliaweather.com
DW1376
KILCENTR2
K9RJN
wxtech
« Reply #15 on: October 28, 2009, 10:20:14 AM »
Most definitely.  They are polycarbonate.  Usually the bottom of the inner cylinder cracks and leaks.
Tomcj2 says that Weld-On #16 will repair them.  Weld-On epoxies #55, 58 are supposed to work also.
« Last Edit: October 28, 2009, 10:49:57 AM by wxtech » Logged
d_l
Slide Mtn - Mt Rose
« Reply #16 on: October 28, 2009, 10:36:26 AM »
Yes they do!  My tube gauge that predates CoCoRaHS, has a cracked outer tube base which leaks the inner tube over flow.  Heavy sun crazing over the past decade may have weakened the plastic there and helped the freeze cracking get started though.
--Dave--
port1
« Reply #17 on: October 28, 2009, 07:37:44 PM »
CoCoRaHS strongly recommends that the inner tube be remove from the outer cylinder if snow or freezing temps are expected.
Besides, you need to melt the snow to provide an equivalent precipitation measurement.  Which reminds me...I have to brush up on that stuff.  Exclamation
Henry
KNYFLORA5
WMR968
VWS v14.00 p73
CoCoRaHS NY-NS-7
CWOP DW1891
SKYWARN 09-148
JOE
« Reply #18 on: October 28, 2009, 08:16:34 PM »
I don't have a gauge.  Yet.
Thinking about getting one and joining up.
Joe
DW1376
KILCENTR2
K9RJN
port1
« Reply #19 on: October 28, 2009, 08:22:29 PM »
You will find being a member is rewarding.
I speak the truth!  Very Happy
Henry
KNYFLORA5
WMR968
VWS v14.00 p73
CoCoRaHS NY-NS-7
CWOP DW1891
SKYWARN 09-148
92merc
BismarckWeather.net
BismarckWeather.net
« Reply #20 on: October 29, 2009, 09:10:58 AM »
Yes, definitely.  One of mine did.  Storm came quicker than I thought and I forgot it out.  Inner tube busted.
BismarckWeather.net
Pick
Senior Member
« Reply #21 on: November 22, 2009, 11:43:13 AM »
Finally got some good rain here, got tired of sending the blank reports. Good news is my Vantage Vue is within 1% of the CoCoRahs gauge!!!! Dancing
Mike
Vantage Vue
CoCoRahs FL-AL-17
KFLHIGHS1
port1
« Reply #22 on: November 22, 2009, 04:40:47 PM »
 Smile I've been noticing that my OS WMR 968 has been spot on with the CoCoRaHS gauge lately.
That's been a real surprise to me.  I must have installed that tipping gauge very level originally.
 Applause
Henry
KNYFLORA5
WMR968
VWS v14.00 p73
CoCoRaHS NY-NS-7
CWOP DW1891
SKYWARN 09-148
Page created in 0.126 seconds with 18 queries.
