May 24, 2013, 03:43:52 PM *
Members: 6620  •  Posts: 178793  •  Topics: 18139
Please welcome moranbahweather, our newest member.
Author Topic: virtual temp  (Read 1497 times)
offroadjosh
Davis Vp2 Wireless- VWS 14 P90 Serial Data logger
Montana Firefighter
« on: April 21, 2009, 12:59:25 AM »
if you go in to  like the alpha numeric or gauge or thermometer there's an thing called virtual temp... what is that for?
Josh
Josh Patten
Davis VP2 Wireless -May 2008
VWS 14.00P90\WL 5.9.9/Plus others!
Skywarn trained
CoCoRaHS member
Smith Valley Fire Dept Firefighter:)
http://josh.northwestwx.com/station/usa.htm
CWOP-DW0711
Kestrel 2000 hand held anemometer
Cocorahs 4in rain gauge
Custom co
Anthony
Moderator
« Reply #1 on: April 21, 2009, 08:30:34 AM »
Here you go.
Virtual temperature
From Wikipedia, the free encyclopedia
Jump to: navigation, search
The virtual temperature (Tv) of an air parcel is the temperature that dry air would have if its pressure and density were equal to those of a sample of moist air. [1] The virtual temperature allows the use of the dry-air equation of state for moist air, except with T replaced by Tv.[2] A formula for the virtual temperature Tv is
where T is the ambient temperature, r is the water vapor mixing ratio (mass of water per mass of dry air), and ε is the molar mass of water vapor divided by the molar mass of dry air (for the Earth's atmosphere this value is 0.622.) In this formula the temperature is in kelvins and the mixing ratio is dimensionless (g/g or kg/kg).
A simpler, approximate formula for virtual temperature is
An approximate formula for virtual temperature using the Celsius temperature and dimensional mixing ratio (g/kg) is
[3]
  This climatology/meteorology-related article is a stub. You can help Wikipedia by expanding it.
Anthony
WB8YUE
tomcj2
« Reply #2 on: April 21, 2009, 08:36:42 AM »
Once I figure out what language the article was written in; it certainly does not appear to be in the English that I know  Rolling Eyes
« Last Edit: April 21, 2009, 08:49:08 AM by tomcj2 » Logged
Davis VP2 (6163), WL 5.9.0..  VWS 14.01 p25, Panasonic HM371A camera. WU & W4U KORCANBY3, CoCoRaHS OR-CC-27
sam2004gp
Mount Crawford, Virginia
Weeeeeeeee!!!!
« Reply #3 on: April 21, 2009, 08:47:22 AM »
So what is Virtual Temp.  in "laymen's" terms?
92merc
BismarckWeather.net
BismarckWeather.net
« Reply #4 on: April 21, 2009, 09:17:28 AM »
It's the temperature I'd feel if I were actually at home more often...   Wink
BismarckWeather.net
TorH
« Reply #5 on: April 21, 2009, 09:18:32 AM »
I've also wondered some times what viritual temp is, is it some ordinary "term" or as sam2004gp said "So what is Virtual Temp.  in "laymen's" terms?" Rolling Eyes
Davis Vantage PRO2 wireless
VWS V14.00 p103, WD ver.10.37N, WL 5.8.2, VVP.
WeatherFlash
DW1549
WeatherUnderground: INORDLAN14
Location: Fauske, Northern Norway. N 67°15'41", E 15°24'41"
http://bjornli.net
sam2004gp
Weeeeeeeee!!!!
« Reply #6 on: April 21, 2009, 10:31:59 AM »
Here is the definition from the most current VWS manual, that I found.
offroadjosh
Montana Firefighter
« Reply #7 on: April 21, 2009, 10:44:09 AM »
lol thanks i think i kind of got an idea of what it is now.
Josh
Josh Patten
Skywarn trained
CoCoRaHS member
CWOP-DW0711
Custom co
ironton
Contributor
« Reply #8 on: April 21, 2009, 10:53:58 AM »
This may be a bit late since Sam's post above.
Just in case this definition is still confusing to some I will try to give my interpretation of what it means.  (but mostly because I had all this typed up)
 Arrow I will admit to going out on a limb here so correct me if I am off base. (always willing to learn)
We can all relate to the extra-cool feeling when the evening air is damp and we probably have also heard the expression used by folks living in the desert states "....yeah, but it's a dry heat."
Moisture gives air the ability to hold more heat per given volume.  90F air with 90% relative humidity seems hotter than 90F air with 10% humidity.  The same can be said for the cooling effect of 50F air with more or less relative humidity.
The virtual temperature calculation attempts to remove the moisture from the air and tell us what the air temperature would have to be for the "same feel" if it was at standard conditions.
To go a bit further....
The virtual temperature definition says it allows meteorologists to use the "equation of state for dry air".  The equation of state takes into account a few laws of physics - notably Boyle's Law and Charles's Law.  They simply state that (1) a volume of gas will be smaller if the pressure is increased and (2) a volume of gas will be smaller if the temperature is lower (assuming all other terms are the same).
The virtual temperature definition implies that in order to perform any type of calculation on the air, meteorologist must convert the temperature to standard conditions.  In physics this is known as STP (or Standard Temperature and Pressure).
Now, does anyone know why meteorologists might need to perform these calculations?  Perhaps to estimate the energy in a system?
Ok, not sure if I helped or not - but that is my attempt.
ironton/-ed
Davis VP2 using VWS
http://www.charlevoixweather.com using Cumulus
Bushman
« Reply #9 on: April 21, 2009, 11:30:07 AM »
"Virtual temperature is a fictitious temperature that takes into account moisture in the air. The formal definition of virtual temperature is the temperature that dry air would have if its pressure and specific volume were equal to those of a given sample of moist air. Virtual temperature allows meteorologists to use the equation of state for dry air even though moisture is present."  Now if I could only figure out the relationship of bouyancy fluctuation and adioabtic cooling...  LOL
WeatherBeacon
Chief
« Reply #10 on: April 21, 2009, 11:58:51 AM »
Adiabatic cooling --- if a parcel of air moves upward (as it flows over a hill or mountain, for example), it enters a region of lower pressure and consequently expands. Because the parcel expands, its temperature decreases (ideal gas equation of state). Thus, the parcel has cooled, not because energy (heat) was removed from it, but simply because its temp decreased by expansion. That's adiabatic cooling.
Conversely, if a parcel of air moves downward, it enters a region of higher pressure and consequently is compressed. Because the parcel is compressed, its temperature increases (ideal gas equation of state). Thus, the parcel has warmed, not because energy (heat) was added to it, but simply because its temp increased by compression. That's adiabatic heating.
Here's an example: have you ever used a can of compressed air to dust a computer or keyboard? As you spray the compressed air out, the can starts feeling very cold. That's because as gas is released from the can, the compressed gas remaining in the can expands and cools, not because energy (heat) is being removed from it, but because it is expanding, so its temp decreases.
EDIT:  Adiabatic cooling is sometimes called expansion cooling. Adiabatic heating is sometimes called compression heating.
« Last Edit: April 21, 2009, 12:31:49 PM by WeatherBeacon » Logged
Mae govannen!
Weather Display
« Reply #11 on: April 21, 2009, 03:17:11 PM »
 Applause Dancing Very Happy
Page created in 0.113 seconds with 19 queries.
