Author Topic: The mystery of the Bermuda Triangle is killer wave  (Read 936 times)
Offline Fermer05
« on: November 29, 2019, 05:30:24 PM »
The mystery of the Bermuda Triangle is killer waves.
Geofak Moscow State University. https://m.facebook.com/groups/328946357209747
A huge number of tidal waves move in the seas and oceans.
When tidal waves collide with the coastline of the continents, tides are formed.
When two tidal waves collide in the open ocean, a killer wave forms.
https://en.m.wikipedia.org/wiki/Rogue_wave
The magnitude of the killer waves can be calculated using the following formula: H = T1 • T2.
Where T is the kinetic energy of the tidal wave.
Experiment to the topic: The mystery of the Bermuda Triangle - killer waves https://youtu.be/4aTl9GQFKLo
As we see, killer waves are formed only in those seas where tidal waves are formed and the higher the amplitude of the tides, the higher the killer waves.
In seas where tides do not form, killer waves do not occur.
List of seas where tides and killer waves are formed, more than 50 cm high:
Irish Sea, North Sea, Barents Sea, Baffin Sea, White Sea, West Mediterranean, Bering Sea, Sea of ​​Okhotsk, Arabian Sea, Sargas Sea, Hudson Bay, Maine Bay, Alaska Bay, etc.
List of seas where tides and killer waves are formed, less than 50 cm high:
Baltic Sea, Greenland Sea, Black Sea, Sea of ​​Azov, Chukchi Sea, Kara Sea, Laptev Sea, Red Sea, Sea of ​​Marmara, Caribbean Sea, Sea of ​​Japan, Gulf of Mexico, etc.
In the season of abnormally high tides, abnormally high killer waves form.
The highest tides and killer waves are formed in the North Atlantic, in the Pacific Ocean in the Sea of ​​Okhotsk, etc.
You can conduct a simple experiment if two stones are simultaneously thrown into a bath of water. (the distance between the stones is 10 - 15 cm).
When a tidal wave collides, the emerging killer wave foams and a larger wave pulls through a smaller wave somewhat.
You can create a killer wave with a height of 0.3 meters and a duration of 0.5 seconds, if two divers at the same time jump "bomb" into the pond from a height of 2 meters. (distance between jumping 3 meters).
If, in a cup with water, hit simultaneously with two tablespoons and a "killer wave" is formed there.
The mechanism of formation of the tidal hump in the river, and killer waves in the oceans is similar and the height of the tidal hump in the river depends on the kinetic energy of the current in the river, and the kinetic energy of the tidal wave.
https://images.app.goo.gl/fNxSM5ZBGN5evNQi9
Tidal waves move in the open ocean in different directions, at speeds up to 100 km / h and they are called Rossby waves.
Three sisters is a tidal wave collision, with three storm waves.
Barely visible tidal waves colliding with storm waves create a killer wave and are the main cause of the wreck of ships.
https://goo.gl/images/icF4zf
The map shows the areas of the most frequent occurrence of killer waves.
In the North Atlantic, killer waves form mainly around the perimeter of the North Atlantic planetary cycle as a result of the collision of tidal waves with storm waves (three sisters).
Suloy is a throw of water on the surface of the sea.
https://ru.m.wikipedia.org/wiki/%D0%A1%D1%83%D0%BB%D0%BE%D0%B9
https://images.app.goo.gl/DZWdKoRxvJ214xWP6
The animation shows how a killer wave forms in the Bermuda Triangle area.
The clock set in the animation shows that killer waves in the Bermuda Triangle are generated twice a day at 12 and 24 hours.
Based on the animation shown, you can create a calendar for the formation of killer waves, not only for future years, but also for previous ones.
https://en.m.wikipedia.org/wiki/Bermuda_Triangle
The place of the possible occurrence of killer waves can be predicted by the tidal calendar, and accordingly, lay safe routes.
The approaching wave-killer or tsunami can be partially neutralized by creating a series of oncoming waves, torpedoes or shells.
The hypothesis that the imposition of wind waves can be the cause of the formation of killer waves is not true, since killer waves also form during calm, when there are no storm waves in the sea.
The statement that methane floating from the bottom of the ocean sharply reduces the density of water and the vessel loses buoyancy is also not true, since a decrease in the density of water cannot cause mechanical damage to ships and oil platforms.
The crews of the ships always record the impact of a huge wave, but no one has yet been able to record the methane emission.
Which the Gulf Stream creates, reflecting from itself a huge tidal wave.
The Gulf Stream is a powerful current with a width of about 100 km, a thickness of about 700 m and a speed of up to 10 km / h.
As you move, the Gulf Stream forms numerous meanders up to 200 km., And in the stream itself, cycles develop.
https://oceanservice.noaa.gov/facts/gulfstreamspeed.html
All currents that move in the seas and oceans reflect a tidal wave, and they are called tidal currents.
And the greater the kinetic energy of the currents, the greater the tidal wave.
https://science.howstuffworks.com/environmental/earth/oceanography/ocean-current4.htm
To be continued. "The mechanism of thermoregulation of the Earth."
Forum Akademgorodok Novosibirsk. The science. https://forum.academ.club/index.php?showtopic=1235578
Forum of Nizhny Novgorod State University named after N.I. Lobachevsky.
http://forum.unn.ru/viewtopic.php?f=39&t=10331&sid=cfbc49e0cf32263eff20888ca205ab15
The discovery was published in a Russian-German scientific peer-reviewed journal. “Eastern European Scientific Journal” No. 3/2015. Page 64. June
Scientific journal NBIKS-Nauka.Tehnologii No. 4/2018. Page 104.
(Nanotechnological Society of Russia).
French Maritime Forum.
http://forummarine.forumactif.com/t9357-le-flux-et-reflux-est-le-resultat-de-la-rotation-de-la-terre
English Maritime Forum. http://forummarine.forumactif.com/t9372-the-mechanism-of-thermoregulation-of-the-earth#223456
« Last Edit: February 04, 2020, 06:50:24 AM by Fermer05 »
Offline Fermer05
Re: The mystery of the Bermuda Triangle is killer wave
« Reply #1 on: January 11, 2020, 05:04:19 PM »
In the North Sea, off the coast of Norway, on the Dropner oil platform on January 1, 1995, during a 12-meter storm wave, a killer wave of 25.6 meters was formed.
https://en.m.wikipedia.org/wiki/Draupner_wave
I believe the reason for this natural phenomenon is a tidal current that moves along the coast of Norway from west to east, reflecting a tidal wave from itself, both towards the coast and towards the open sea.
Also, north of the Dropner oil platform through the Pentland Firth Strait, a current moves at a speed of 16 knots from west to east, reflecting a tidal wave north and south.
https://www.equinor.com/en/what-we-do/partner-operated-fields-in-norway/draupner.html
https://en.m.wikipedia.org/wiki/North_Sea
« Last Edit: January 12, 2020, 06:13:18 AM by Fermer05 »
Offline Intheswamp
    • Beeweather
« Reply #2 on: January 12, 2020, 09:25:04 AM »
Honestly, you don't really believe all of that, do you?  We all know it's the aliens making things disappear there...  ;)
Davis VP2, v3.12
Cumulus v1.9.4  Build 1079
www.beeweather.com
Nope, I still haven't replaced that humidity sensor...<grin>
Offline Fermer05
« Reply #3 on: February 03, 2020, 07:09:55 AM »
In the North Sea, only storm and tidal waves move.
And only, the interaction of tidal and storm waves can be the cause of the formation of killer waves.
« Last Edit: February 03, 2020, 12:24:53 PM by Fermer05 »
