Author Topic: SuperCap failure - Update  (Read 846 times)
Offline youngros
    • Sans Souci Weather
« on: November 16, 2019, 05:27:12 PM »
After it flatline a few weeks ago I replaced the battery again. Then I noticed that it flatlined a couple of days ago. Now tonight I notice once it started to drop from 100% I had a low battery warning ticker tape, never noticed it before but it wasn't there earlier today.
Now down to 90% but it should still be sending data, but it isn't. It has already flatlined.
Is this the supercap or the whole board failing?
Will buy a couple of new batteries to try and keep it going until I either replace the supercap or the board.
Just feel it might be easier to change the board, despite the cost. Any thoughts please.
« Last Edit: December 06, 2019, 02:19:09 PM by youngros »
Online galfert
Re: SuperCap failure
« Reply #1 on: November 16, 2019, 09:30:27 PM »
VP2 or Vue?
If Vue then I've been told super cap is epoxyed and is not really removable.
EDIT: Nevermind, I see now from your website it is a VP2. You are good whatever you decide.
« Last Edit: November 16, 2019, 09:34:08 PM by galfert »
« Reply #2 on: November 17, 2019, 12:12:50 AM »
Offline youngros
« Reply #3 on: November 17, 2019, 05:27:09 AM »
Sorry, forgot to add in it was a VP2.
Being a Sunday not found anywhere open who has the batteries. Fortunately it is sunny so is back working.
Thanks for the link to how to replace the supercap. Is it possible to just remove the board without removing the whole assembly?
What difference does it make putting the console in setup mode? I have never done it before, just unplugged the links to replace the temp/humidity sensor as the wind and rain would still have been working.
Going to try soldering first as having new supercaps sent out will come normal post from the UK. Anything bigger ends up stuck in Lisbon and then put on a boat. (Royal Mail and GLS nightmare). Also will get caught up in Christmas post.
Online galfert
« Reply #4 on: November 17, 2019, 05:59:11 AM »
It prevents erroneous data being sent to the console as you do maintenance. An alternative is to change the SIM ID.
« Reply #5 on: November 17, 2019, 10:05:14 AM »
With care, one could probably solder the supercap without removing the board at all.  Just remove the battery and the white cover and clip the leads.
Offline youngros
« Reply #6 on: November 19, 2019, 01:14:27 PM »
Slight lack of electricity down by the weather station! It's a balancing act to put a new battery in, although I could rotate it all, which is what I might have to do rather than get a set of step ladders down there.
In the pictures it shows the white cover being removed before removing the board, is it possible to remove the board with that in place so as to avoid losing the screws?
Offline youngros
Re: SuperCap failure - Update
« Reply #7 on: December 06, 2019, 02:18:27 PM »
Today was the day to remove the ISS and replace the super cap. Definitely died from the corrosion around the terminal.
New one soldered in place and all reinstalled. Only time will tell if the soldering was up to scratch.
It was easier to take apart than I thought it would be.
Offline Aardvark
« Reply #8 on: December 06, 2019, 04:16:03 PM »
I think you will be happy that you fixed it.   I don't know if anyone has figured out why they go bad.
Davis VP2 Plus; 24h  FARS; Extra Temp Humid sensor (2); Extra Temp Station (2); Soil Moisture/Temp  https://www.weatherlink.com/embeddablePage/show/1c484adbfa914d1aa10a58ad53ccd563/summary;Weatherlink IP;USB; MAC Catalina
; Webcam;
« Reply #9 on: December 06, 2019, 04:49:18 PM »
I say heat. https://www.avx.com/docs/techinfo/whitepapers/AVX-Whitepaper-Reliability-of-SuperCapacitors-Paper1.pdf
« Reply #10 on: December 06, 2019, 04:50:07 PM »
It may well be "exercise". Mine will be 13 next year, obviously it gets abundant sunshine.
« Reply #11 on: December 06, 2019, 04:50:49 PM »
I say heat.
Then mine would have failed loooong ago.
« Reply #12 on: December 07, 2019, 03:37:36 AM »
It's officially attributed the fact that supercaps tend not to be as mechanically robust as other components. This is why particular care is needed during board assembly and subsequent use, including replacement supercaps, eg being very careful not to bend the leads anywhere near the supercap body. It's also why the supercaps are restrained in some way on the PCBA with glue or a tie to lessen the effects of vibrations, mechanical knocks etc where the leads enter the supercap body.
Littleport, Ely, Cambs UK
Online 92merc
  • BismarckWeather.net
« Reply #13 on: December 07, 2019, 11:00:00 AM »
My VP2 is now 11 years old on original CAP.  It's been through temp extremes here in ND.  Over 100's and -30F.
But I do have a CAP in my closet read to go, just in case.  I may be lucky, but I ain't stupid!
