Author Topic: Weather34 and Hikvision IP Camera (DS-2CD2T55FWD-I5)  (Read 949 times)
Offline rul3zo
    • PWS
« on: October 11, 2019, 08:36:50 AM »
I try to connect hikvision camera (DS-2CD2T55FWD-I5, Firmware: V5.5.61 build 180718) to a script-based website from Weather34, but camera requires login and password. I was configure the camera ( link format to camera) for skip the login process, but did not work ...
There is a possibility in this camera or in this script  an unauthorized image from camera.
Online wvdkuil
  • Wim van der kuil
Re: Weather34 and Hikvision IP Camera (DS-2CD2T55FWD-I5)
« Reply #1 on: October 12, 2019, 03:50:48 AM »
You can add the password and loginID to the url. Example:
If this is an url   http://yourhome.ddns.net:554/cam/xyz.jpg
Add the loginID (f.i.  admin) and password  (f.i. mypass) as  http://admin:mypass@yourhome.ddns.net:554/cam/xyz.jpg
Be aware that when using such an  URL there are a lot of special characters NOT allowed in the loginID or password.
F.I. do not use characters such as & : . # or @  as they have other meanings in an URL
Wim
Support for Leuven-Template & Scripts  at this forum via https://support.leuven-template.eu/
Support for the PWS_Dashboard  pwsdashboard.com
Offline rul3zo
    • PWS
« Reply #2 on: October 12, 2019, 08:16:07 AM »
Thank you for your response Wim!
However, I tried tan record path and other ...
for example:
http://login:pass@myadress.com:8989/onvif-http/snapshot
or
http://login:pass@myadress.com:8989/ISAPI/Streaming/channels/101/picture
or
http://login:pass@myadress.com:8989/Streaming/Channels/1/picture?snapshotImageType=JPEG
... end
http://myadress.com:8989/ISAPI/streaming/channels/101/picture?auth=YWRtaW46MTIzNDU=
(coding pass and login in web adress)
Unfortunately, the script does't always see the image. When I type this adresess in browser (to check if the address is correct), always have asks for the password and login :(
Online wvdkuil
  • Wim van der kuil
« Reply #3 on: October 12, 2019, 08:35:03 AM »
for example:
. . . shortened . . .
https://ipcamtalk.com/threads/get-still-image-through-url-from-hikvision-nvr-solved.6279/
It mentions that the last link should works as
http://user:password@192.168.0.xxx/ISAPI/Streaming/channels/101/picture
There are tons of different messages when you google for   hikvision  onvif-http/snapshot
Succes, Wim
Offline rul3zo
    • PWS
« Reply #4 on: October 12, 2019, 02:13:05 PM »
Unfortunately, it still doesn't work. ..
http://pobiedziska.e-meteo.pl - mini webcam
and
http://pobiedziska.e-meteo.pl/webcam.php
Online wvdkuil
  • Wim van der kuil
« Reply #5 on: October 12, 2019, 04:32:33 PM »
and
On an iPad it works OK
On a Mac it  works OK in Safari and in FireFox
It does not work in Chrome, the inspect console shows this error:
[Deprecation] Subresource requests whose URLs contain embedded credentials (e.g. `https://user:pass@host/`) are blocked. See https://www.chromestatus.com/feature/5669008342777856 for more details.
That is a pity.
So you have to upload a jpg form the camera to your website every so many minutes and use the link to the uploaded picture in your scripts.
That only works if your camera can upload a jpg or png with always the same name.
Wim
« Last Edit: October 12, 2019, 04:37:38 PM by wvdkuil »
Offline rul3zo
    • PWS
« Reply #6 on: October 13, 2019, 03:29:24 AM »
That's right, ... additionally, it doesn't work on PC in "internet explorer 11". I will have to fasten a PHP script that changes "subsequent" file names from the server on the ftp server to one "image.jpg" - http://pobiedziska.e-meteo.pl/camera or I will still try to test the password encoding in the address - "?auth=YWRtaW46MTIzNDU=" on this website: https://www.base64encode.org/
ok, now I have encrypted the login and password in the address. Now it doesn't work in IE from Microsoft (which means nothing important) and
android mob.phones
Thank you Wim for your time and help.
« Last Edit: October 13, 2019, 08:28:51 AM by rul3zo »
Offline PaulMy
« Reply #7 on: October 13, 2019, 10:47:59 AM »
This may help  http://www.wxforum.net/index.php?topic=33009.0
Enjoy,
