May 18, 2013, 09:00:12 PM *
Members: 6609  •  Posts: 178187  •  Topics: 18099
Please welcome TargY, our newest member.
Author Topic: Graph Display  (Read 990 times)
weather13
« on: March 26, 2009, 01:29:34 PM »
Hello.
I'm running VWS v14.00 p73.
Is it possible to have the vertical numbers (x plot) display on the right side of the graph vs the left side?
As the graph plots it's data from left to right, it would seem logical to have them appear on the right.
(enough of the eye exercise already) Smile
Thanks for the help.
Anthony
Moderator
« Reply #1 on: March 26, 2009, 01:33:06 PM »
No
Anthony
WB8YUE
SLOweather
Administrator
« Reply #2 on: March 26, 2009, 01:34:46 PM »
If you add a second plot, those Y values get plotted on the right side. I don't believe you can have a graph, with only a second plot, though.
SLOweather
Administrator
« Reply #3 on: March 26, 2009, 01:53:20 PM »
You might be able to plot the same parameter as the second plot, which would then place the units on bots sides of the graphs.
Or, in the brute force and awkwardness method, you could rearrange the image with a little PHP. I wrote a script for a fellow on the VWS forum that rearranges the wind direction plot from south in the middle to north in the middle:
From this:
to this:
JOE
« Reply #4 on: March 26, 2009, 02:21:54 PM »
That should work.  Not at home in front of it now, but here's some with X axis numbers on both sides.  Using second plot feature.  Just make sure to set units and low and highs the same on both graphs.
Like some of these:
http://www.centraliaweather.com/graphs.htm
Joe
DW1376
KILCENTR2
K9RJN
weather13
« Reply #5 on: March 26, 2009, 02:26:37 PM »
Like a charm.
Just added the second plot being the same as the first.
Page created in 0.123 seconds with 19 queries.
