Author Topic: WS-80 Ultrasonic Wind sensor array  (Read 22685 times)
Offline PeterH
Re: WS-80 Ultrasonic Wind sensor array
« Reply #175 on: December 27, 2020, 05:22:34 PM »
I took my WS80 down... Took in inside. Dried the unit. And now it's working again.
Strange.  :oops:
Placed it outside again, at a temporary spot and see how it will hold out.
I took multiple gusts of 70 km/h in my urban area..
Offline wardie
« Reply #176 on: December 28, 2020, 04:31:41 AM »
After some very high winds my WS80 Ultrasonic anemometer is still reporting, but the windspeed and direction has frozen.
Someone experienced this phenomenon also?
Should a reset be enough?
It was also stuck earlier this morning.
I had something similar, albeit the high wind speeds I had were all erroneous and then it froze afterwards (only for wind speed/direction). A reset with the physical button worked and it seemed to be OK for few weeks after.
Nevertheless I told Froggit and they asked I send it back to them, I’m awaiting a replacement.
The only other slight issue I’d noticed was some condensation appearing at the top of the unit inside the transparent plastic above the solar panels / light. I don’t know if that’s related. I’m also going to try the heating cable if that makes any difference. Hope occasional glitches are not a “feature” of this device, I few more experienced folks than me on here seemed to suggest ultrasonic tech in general is more flaky than wind cup etc. Still, I like new tech :-) also the low profile of the WS80.
My post:
https://www.wxforum.net/index.php?topic=40840.0
Froggit HP1000SE Pro-C console (HP2551-C)
Froggit HP1000SE Pro ultrasonic multi sensor with Ecowitt EC0002 heater (WS80)
Ecowitt Anemometer 5-in-1 array (WS68)
Froggit DP80 rain gauge (WH40) with spikes
Froggit indoor temp/humidity/pressure (WH32B)
Froggit DP50 Internal temp/humidity x2 (WH31)
Ecowitt Outdoor temp/humidity & RS-00001 shield (WH32)
Froggit DP200 PM2.5 outdoor (WH41)
Ecowitt indoor CO2 PM2.5 PM10 (WH45)
Froggit DP100 soil moisture (WH51)
Froggit DP60 Lightning detector (WH57)
Froggit DP1500 server dongle (GW1000A) x2
Raspberry Pi 4 / WeeWx-GW1000 API interface
WU: IKNEBW2
Offline Quagmire
« Reply #177 on: January 05, 2021, 06:51:08 PM »
Does anyone happen to know the update interval for the temperature and humidity sensor built into the WS80? I just added a WH32 in addition to my WS80 and the latter seems to update temp/humidity at a much slower rate.
« Reply #178 on: January 05, 2021, 07:00:28 PM »
Sensor update intervals:
https://www.wxforum.net/index.php?topic=39364.msg406206#msg406206
Even though what you say is true...just because the frequency is quicker with the WS80, the intention of that transmission speed is for wind data. The fact that you can more optimally place the WH32 where it will get you better data than what is integrated with the WS80 is reason enough to have gotten the WH32. Temperature and humidity are not measures that need to be read more frequently than every minute. You aren't going to miss anything by reading temperature and humidity every minute instead of every few seconds.
« Last Edit: January 05, 2021, 08:17:05 PM by galfert »
Offline Quagmire
« Reply #179 on: January 05, 2021, 08:00:22 PM »
Ah, so the temp and humidity are at 4.8 seconds as well?  :shock: I seemed faster but I didn't realize it updated at the same rate (guess I shoulda figured they wouldn't program separate transmission intervals). I've only had the station parts set up for a day, so I'm still in the playing around phase.
I agree with you though, temp and humidity don't need to be updated that frequently, I was just curious. Will absolutely be using the WH32 since eventually, the WS80 will be mounted on the roof and that's certainly not where I want my temp readings coming from.
Offline wardie
« Reply #180 on: January 08, 2021, 05:21:53 PM »
I just got a replacement unit WS80 back from Froggit - up and running, OK so far. I’ve got a heater lead in the post now from Ecowitt in China (along with other stuff) so will give that a go see if it helps with anything. But when my original one went crazy with wind (see other thread) there was no snow/ice, just cold wet days.
WU: IKNEBW2
Offline olicat
  • GWxx00, HPx5x1C, WN1900C, WN1980C & WS3xx0C
    • FOSHKplugin
« Reply #181 on: January 08, 2021, 05:39:02 PM »
Hi!
Please measure the connector and take a few photos of it. It would be important whether it is M12 and how far the two pins / holes are from each other.
Thanks!
Oliver
Offline wardie
« Reply #182 on: January 08, 2021, 05:50:56 PM »
Sure. Aren’t the pins on the WS80 end, from what I remember earlier of sticking the lead through the 90 degree metal pipe, and replacing the rubber cap. Forgive me (I’m a software guy!) how would I tell it’s an M12 does that refer to the screw thread size or something?
Hi!
Thanks!
Oliver
WU: IKNEBW2
Offline TheTut
« Reply #183 on: April 13, 2021, 04:11:24 PM »
Where are you all getting your WS-80 from?
Ambient claims out of stock on their much higher priced version and Ecowitt says Ambient prevents them from shipping to the US.....
Ambiant is only selling a bundle that after taxes is $400 in my state and I already learned they don't support their products.
Offline stratus13
    • My PWS
« Reply #184 on: November 07, 2021, 12:12:25 PM »
Good day!
Just found out that there's some firmware updates available on ECOWITT website for my HP2553 Wx station but I'm wondering if I should also update the WS80 firmware to fix wind spikings when raining/snowing... when this one has been issued? My station is from spring 2020.
thanks
Ecowitt HP 2553
WU: IQUEBECM21
Offline Gyvate
« Reply #185 on: November 07, 2021, 12:40:41 PM »
the WS80 firmware update is more recent (from July 2021) - so I advise to update your WS80. And you should go for the 1.7.6 console firmware. If you are using a WH57 lightning detector you will be pleased as that console firmware now keeps the last strike time stamp over a reboot/restart of the console.
Offline Gyvate
« Reply #186 on: November 07, 2021, 12:49:36 PM »
this has been said here many times - a contract between FineOffset (the Ecowitt mother company and wholesale reseller partner) and Ambient keeps Ecowitt from delivering the WS80 (Ambient WS-5000 ULTRASONIC) into the U.S.
Ambient have Fine Offset made their own firmware for their consoles and sensors.
That's why Ambient consoles will not process Ecowitt sensors, whereas Ecowitt consoles can process both Ecowitt and Ambient sensors. The only way for a U.S. based person to get an Ecowitt WS80 is to get it delivered to some partner (friend, acquaintance, ...) to another neighboring country (e.g. Canada, Mexico) and have it forward from there into the U.S.
Ambient should support their products though - whatever you mean by that. They provide e.g. firmware updates for consoles, manuals, tips and tricks etc. on their web site.
They may not always have the most qualified support staff though.
Offline stratus13
    • My PWS
« Reply #187 on: November 07, 2021, 07:39:42 PM »
Danke! Gyvate,
That's exactly the information I was looking for. And your are right, my plan is to also update the console with 1.7.6 firmware.
Stratus13
Ecowitt HP 2553
WU: IQUEBECM21
Offline stratus13
    • My PWS
« Reply #188 on: November 08, 2021, 10:09:20 AM »
Well I said yes for the 1.7.6 console firmware but ECOWITT web site mention that this upgrade is for 2550&2560 Wx stns. The most recet for 2553 is the 1.7.4
Ecowitt HP 2553
WU: IQUEBECM21
Offline olicat
    • FOSHKplugin
« Reply #189 on: November 08, 2021, 10:48:01 AM »
Hi!
The firmware v1.7.6 is for the complete HP255x series. So it should be no problem at all to install it to your device.
Oliver
Offline Gyvate
« Reply #190 on: November 08, 2021, 01:10:11 PM »
I will work as Oliver said ...
Don't confuse product names for stations (console + sensor(array)s) and consoles/sensors.
HP2551 is a product and the console  :roll: - HP2553 is a product only, a station consisting of the HP2551 console, the WH40 rain gauge and the WS80 6-in-1 sensor array with ultrasonic anemometer.
All described, by the way, in our central MUST READ ( 8-) ) thread:
https://www.wxforum.net/index.php?topic=40730.0
It can be confusing ... that's why we created that main/central thread to cover as many often unsaid things as possible
