Author Topic: API - missing May 20 to June 20  (Read 503 times)
Offline dport
« on: August 07, 2019, 09:50:06 AM »
Realize there have been a lot of posts here about missing data, but for some reason I am missing a full month when I pull data from the WU API (may 20 to June 20).  When I log into the WU website, the data is there.  Any idea why the API seems to be messed up but not the WU website?
Offline wvdkuil
  • Wim van der kuil
Re: API - missing May 20 to June 20
« Reply #1 on: August 07, 2019, 10:25:49 AM »
This is your "new and improved" dashboard for the month of June:
https://www.wunderground.com/dashboard/pws/KPAMEDIA25/table/2019-06-7/2019-06-7/monthly
Your data for June is there, and the TWC-api (also known as WU-api) works correct
https://api.weather.com/v2/pws/history/daily?stationId=KPAMEDIA25&format=json&units=m&startDate=20190601&endDate=20190630&numericPrecision=decimal&apiKey=__api_key__
This API only works with a maximum of 31 days
What are you using for "when I pull data from the WU API "  ?
The missing data is a problem with the .csv retrieval  but that is not  an official WU-api
https://www.wunderground.com/weatherstation/WXDailyHistory.asp?ID=KPAMEDIA25&graphspan=year&year&format=1
This one is missing May 22 - June 19
2019-5-21,22.6,18.4,14.3,12.8,8.0,3.9,67,53,38,1021,1010,21,3,31,0.00
2019-6-20,29.7,25.3,20.9,24.9,21.9,20.1,96,89,71,1006,999,16,1,26,5.64
And also all data after July 25.
But that is a known problem and yes, multiple stations are missing one or more periods. We all have to wait and see if they will upgrade the .csv retrieval or abandon it.
Wim
Offline dport
« Reply #2 on: August 07, 2019, 10:51:50 AM »
Wim
Hmm.  I must be using the wrong API key.  I'm actually using your template on my local server (thanks so much!).  Attached is where I am pulling the API key from:
Offline wvdkuil
  • Wim van der kuil
« Reply #3 on: August 07, 2019, 01:24:58 PM »
The PWS_Dashboard (aka HWS-Template WD34) uses
1. the WU/TWC-api (https://api.weather.com/v2/) for the forecast only.
2. the WXDailyHistory link s(https://www.wunderground.com/weatherstation/WXDailyHistory) for the graphs
As long as WU/IBM is still working on improving their systems we have to wait until it is clear if the will abandon or postpone the WXDailyHistory link.
Wim
Offline dport
« Reply #4 on: August 07, 2019, 03:01:04 PM »
Wim
Ok I understand now.  I was worried I was doing something wrong.  I'll wait to see how this pans out.  Thank you!
