Author Topic: Food for Thought  (Read 782 times)
Offline AWL
    • Ardmore Weather Live
Food for Thought
« on: July 26, 2019, 02:16:45 PM »
From LifeScience:
       Is there order in chaos?
Physicists can't exactly solve the set of equations that describes the behavior of fluids, from water to air to all other liquids and gases. In fact, it isn't known whether a general solution of the so-called Navier-Stokes equations even exists, or, if there is a solution, whether it describes fluids everywhere, or contains inherently unknowable points called singularities. As a consequence, the nature of chaos is not well understood.  Physicists and mathematicians wonder, is the weather merely difficult to predict, or inherently unpredictable? Does turbulence transcend mathematical description, or does it all make sense when you tackle it with the right math?
Doug
« Last Edit: July 26, 2019, 02:20:06 PM by AWL »
Offline SFX
  • Still on my rocker
  • Safe to approach
Re: Food for Thought
« Reply #1 on: November 04, 2019, 12:49:52 PM »
So far weather is unpredictable.
To be concluded
Offline Aardvark
« Reply #2 on: November 05, 2019, 09:14:13 AM »
Order in Chaos.   Ask any teacher about the last hour of class before vacation.
Davis VP2 Plus; 24h  FARS; Extra Temp Humid sensor (2); Extra Temp Station (2); Soil Moisture/Temp  https://www.weatherlink.com/embeddablePage/show/1c484adbfa914d1aa10a58ad53ccd563/summary;Weatherlink IP;USB; MAC Catalina
; Webcam;
Offline diviningweather
  • The Ol' Prognosticator
    • Freehand Weather Forecasting
« Reply #3 on: March 18, 2020, 05:10:49 PM »
My thought is that fluids such as atmosphere should be looked at from a spongy point of view where fluids under pressure are going to act more like solids and when decompressed will act more like gas.   an easy way of looking at this would be testing the variables of a pool full of hard rubber balls versus a pool full of nerf balls.   the results of conditions and movement will be quite different  even tho they are made from the same material.
So the big picture is not to judge the whole of the area of any fluid but to give judgement to each area according to its pressure conditions.
Freehand Forecasting: The ability to observe your surroundings, your physical state, taking note of internal and external changes, understanding your geological area from local to continental. All leading to a close prognostication of upcoming weather.
