sportyjeff303
Senior Member
Offline
« on: March 24, 2009, 01:15:36 AM » |
i have a problem with my vws also my parents do too. we are both running the same setup. vws newest version, both wmr200 systems. we both will always get rain spikes. his is always 1.62 and mine is .09. The spike only shows up on the hourly rain graph it doesn't effect the total rain at all. the total rain never changes from this spike, but the hourly rain does. Because the hourly rain changes so does my wunderground website. it will say i have .09 more then I do. It doesnt graph the spike on wunderground's website tho but will show it in text .13 when it should show .04. Same with my parents station. I know the program has upper limit and lower limit. I am not sure if I should mess with those. If anyone can help me out with this i would appreciate it.
DanS
« Reply #1 on: March 24, 2009, 01:35:12 AM » |
I don't use VWS so can't help with that but have 2 questions that may be useful. Is yours and your parents systems in the same house? If so do your spikes occur at the same time when this happens? If yes then it could be outside or external interference effecting them.
sportyjeff303
Senior Member
Offline
« Reply #2 on: March 24, 2009, 01:39:08 AM » |
no its not in the same house we live 20 minutes away from each other. no the spike does not happen at the same times.
wello
Welloweather
Offline
Welloweather
« Reply #3 on: March 24, 2009, 04:11:46 AM » |
I began getting something similar after an update about a month ago. It has all but disappeared since upgrading to P72
wello
Welloweather
Offline
Welloweather
« Reply #4 on: March 27, 2009, 07:06:16 PM » |
Looks like Ed just fixed this with P76 P76. Correcting issues with spikes in data with WMR200A. This is caused by an errant archive record (not a problem with Virtual Weather Station, this is a problem with the data logger).
sportyjeff303
Senior Member
Offline
« Reply #5 on: March 27, 2009, 07:55:28 PM » |
ed and I have been talking back and forth for about a month now about this problem. we have gone thru my data left and right up and down. he told me he would create a fix for this but is still confused on how to create a fix with the weird issue. hope this new update fixes the problem!
wello
Welloweather
Offline
Welloweather
« Reply #6 on: March 27, 2009, 10:53:51 PM » |
Too short a time yet for me to determine it has worked here but I'm hopeful.
sportyjeff303
Senior Member
Offline
« Reply #7 on: March 28, 2009, 01:36:14 AM » |
were you having the same problem too?
wello
Welloweather
Offline
Welloweather
« Reply #8 on: March 28, 2009, 03:40:13 AM » |
Had a couple of times with similar symptoms. Sudden rain recording 45mm+ when no rain had fallen. Didn't add to totals but did show on Wunderground and on graphs.
sportyjeff303
Senior Member
Offline
« Reply #9 on: March 28, 2009, 05:26:07 AM » |
not fixed i just spiked
wello
Welloweather
Offline
Welloweather
« Reply #10 on: March 28, 2009, 07:46:27 AM » |
Check in Help => About and confirm that P76 has installed correctly.
sportyjeff303
Senior Member
Offline
« Reply #11 on: March 28, 2009, 05:48:04 PM » |
i did and it is
wello
Welloweather
Offline
Welloweather
« Reply #12 on: March 28, 2009, 05:55:47 PM » |
Sorry...not good news. I guess it's back to Ed.
sportyjeff303
Senior Member
Offline
« Reply #13 on: March 28, 2009, 05:59:29 PM » |
i told ed. it happened between midnight and 2am but it was weird the hour rain spiked to the same total as my total rain. i went into rainfall and set it back to 0. today had rain and it worked perfect so far.
stu-in-flag
« Reply #14 on: July 18, 2012, 10:34:14 PM » |
I just started to have this issue. Did any of these solutions for the combination of VWS, WMR200 and rain spikes work?
