Author Topic: My latest stupid question re Nano SD **solved**  (Read 449 times)
Offline swordsmn
« on: August 02, 2019, 12:08:32 PM »
I rebooted my Vantage Pro2  with Meteobridge NanoSD
Batteries out  power off  then all ON again
I guess  their is no EEProm  as many setup tweaks  were lost  when I look at my weather34 Display
Problem  now is   I can't  get  past this:  Your Current PHP version is : 7.2.1
(PHP 5.6 or higher PHP 7+ is advised if you are not already using these versions)
Enter Your Password For Meteobridge Setup Screen Below
2015-2019 WEATHER34 Meteobridge DASHBOARD W34-MB
Obviously  I've forgotten  what I used  or somehow  it went bk to default....
So what IS  the default password  For Admin =>  Settings  when I'm looking at my weather34  on my nano?
I CAN  login to meteobridge itself  & see it's  UI
something I read  said  to look at settings1.php   on  the nanoSD   but I do not know  how  to access those  files  directly
nor what editor  to use..  You see,  I'm what you call a moron...   If you can  tell me explicitly,  I can follow directions...
so  tell me if I might be back to some default password  & I'll try that first   or  how  do I inspect  that php file?
As always  thanks  for the groups patience.    I am  enjoying  the Davis  and the Meteobridge    I just don't wanna start from scratch  but if I must   ???
Thanks,  Doug in Atlanta  KGATUCKE23
« Last Edit: September 26, 2019, 04:36:56 PM by docbee »
Pro2 (6163) Nano SD
WU: KGATUCKE23
Offline Mattk
Re: My latest stupid question re Nano SD
« Reply #1 on: August 02, 2019, 05:40:31 PM »
...So what IS  the default password  For Admin =>  Settings  when I'm looking at my weather34  on my nano?...
First time setup access and until you specifically change it, there is none, nothing, just continue through with <Enter>
Offline swordsmn
Resolved Password in wx34. re Nano SD
« Reply #2 on: August 05, 2019, 12:03:33 AM »
Matt,
Thank you, that was it...no password
Was sort of surprised it kept some settings like my keys for darksky and checkwx
But lost some little tweaks
Gonna hv to document things better before next reboot of the davis with onboard nano sd
Once again the forums saves my a**
Pro2 (6163) Nano SD
WU: KGATUCKE23
