May 25, 2013, 04:29:50 PM *
Members: 6623  •  Posts: 178899  •  Topics: 18150
Please welcome Porchpup, our newest member.
Pages: 1 [2]   Go Down
Author Topic: Using 5V and 12V P.C. fans with FARS.  (Read 6775 times)
sam2004gp
Mount Crawford, Virginia
Weeeeeeeee!!!!
« Reply #25 on: March 24, 2009, 08:19:44 AM »
Would it be possible to just buy a couple more white plastic bowls that match pretty close and remove only the top existing one. That way you butcher only the new ones and don't change any existing ones and anything gows wrong you can go back to original config.? make sense? Question
Nope, it is the shield that Ambient Sells, the "plates" are not true circles.  They are oval with specific plastic molded in to help the stability of the screws as they pass thru each plate.
You can see their "non-circular" design best in this photo.
DanS
Chiang Mai weather
« Reply #26 on: March 24, 2009, 08:34:09 AM »
D'oh!! d'oh!  Man, that's too bad. I know how you must feel. I'd be hesitant cutting into it as well. Have you had it torn apart to see if you could reconfigure the sensor's position and squeeze a fan above it without to much modification?
Dan ThaiWx website
WS-2310/2810 WUHU WinXP 24/7
sam2004gp
Weeeeeeeee!!!!
« Reply #27 on: March 24, 2009, 08:57:19 AM »
yep, no additional room.  But the two plates on the bottom have no center hole.  So I am going to remove one, and cut a fan hole in the other.  If I decide it's no good then I will "replace" the hole that I had cut out, and put the two plates back on the bottom.
Anthony
« Reply #28 on: March 24, 2009, 12:59:09 PM »
Don't know how efficent a fan on the bottom will be?
Anthony
WB8YUE
JOE
« Reply #29 on: March 24, 2009, 03:09:48 PM »
I've decided to go ahead and get the Davis Daytime FARS setup.  It's not that expensive and I know it will fit.
My setup is not the best siting anyway.  On roof.  About my only choice without moving.
I have my solar panel facing south now.  Would it help to turn it a little more towards the west to maybe keep the fan running a little later in the day?  Or would that hurt the only panel with recharging in the morning hours?
I don't think having a fan driven wind inside is what we want, is it?  Just enough air movement to keep it "fresh".  On a day with much breeze at all, it's not even necessary to have a fan, is  it?
Does anyone know which way the Davis blows?  Up or down?  I am assuming up and drawing air from the bottom, but I haven't verified that.
Joe
www.centraliaweather.com
DW1376
KILCENTR2
K9RJN
DanS
Chiang Mai weather
« Reply #30 on: March 24, 2009, 07:56:01 PM »
Hi Joe, Since your sensor is roof mounted your idea of positioning the solar panel a little more toward the west might be a good idea. This might help counter the heat radiating off the roof from the afternoon sun. You would need it more in the afternoon than in the morning before the roof is heated.
I also agree with your statement   "I don't think having a fan driven wind inside is what we want, is it?  Just enough air movement to keep it "fresh".  On a day with much breeze at all, it's not even necessary to have a fan, is  it?"  Just enough air flow across the sensor to keep it fresh/replaced should do it. Stagnant or uncirculating air may delay accurate temp/humidity readings.
Since I don't have a Davis someone else will have to chime in to answer FARS question but from everything I've seen and from all Weather1967's tests I would imagine Davis puts them on top drawing up and out the top. Very Happy
« Last Edit: March 24, 2009, 08:08:05 PM by DanS » Logged
Dan ThaiWx website
DanS
Chiang Mai weather
« Reply #31 on: March 24, 2009, 08:13:59 PM »
Anthony, Weather1967 (Dimitris) has ran tests to try that out and got "unstable" results. He says that a fan blowing across the sensor gives inaccurate readings and the best position is at the top blowing out, drawing up across the sensor. Smile
Cheers,
Dan
Dan ThaiWx website
mackbig
« Reply #32 on: March 24, 2009, 08:47:41 PM »
Agreed on not blowing accross the sensor, but I dont think top or bottom "sucking" would matter all that much.  Yes warm air rises, but there should not be that much convection going on in there.  The size of the fan relative to the space being "sucked" is not that material.  A little flow is all you need....
From a rain design point of view bottom is easier, and also since the mount for the Ambient shield is on top also easier.  However Jim's design while not using an Ambient shield is pretty cool (see below), I am sure a large white "plate" could be added to the top of the Ambient shield to protect the fan and still allow for top
mounting...
Andrew
ps: anything I can do to make my radiation shield look more ominous, the
better...
Cheers,
Dan
DanS
Chiang Mai weather
« Reply #33 on: March 24, 2009, 09:52:42 PM »
That does look pretty cool and nicely designed. Can imagine "neighbours" staring at that. Very Happy
I've been wondering about the bottom mount fan blowing downward/out. I can't imagine where it would draw air more than 1 or 2 plates above because the fresh air would be coming in all around the sides. No suction left to reach up to the top so air up there doesn't move (with no breeze or wind). Where a fan up top would draw out rising air so all air moves.
Dan ThaiWx website
tomcj2
« Reply #34 on: March 24, 2009, 11:29:27 PM »
CORRECT, from the bottom and out the top.
Davis VP2 (6163), WL 5.9.0..  VWS 14.01 p25, Panasonic HM371A camera. WU & W4U KORCANBY3, CoCoRaHS OR-CC-27
JOE
« Reply #35 on: March 24, 2009, 11:37:56 PM »
better...
Any way you can rig up some motion sensor LED's or something?  Like only blink when "they" are out and moving? Twisted Evil
Maybe a small parabolic audio dish...
Joe
DW1376
KILCENTR2
K9RJN
mackbig
« Reply #36 on: March 25, 2009, 06:46:30 AM »
I will guinea pig it.  Worst case I end up with a fillable hole in the bottom.  The sensor pretty much sits on the bottom "plate".   Not hard to test, fire up the fan then get a stogie going, then put it beside the shield at the top and work down, if the smoke moves into the sensor near the top at all, its working....
Andrew
mackbig
« Reply #37 on: March 25, 2009, 06:49:14 AM »
Once I get 12 volt to it for the fan, the lighting possibilities are endless.  perhaps leds flashing around this sign.... Andrew
ps: is it possible to resize images to make them smaller with the bb IMG tags?
better...
DanS
Chiang Mai weather
« Reply #38 on: March 25, 2009, 05:50:44 PM »
Andrew
Your sensor being mounted near or on the bottom is ideal. I shouldn't have ass u me d it was near the top and a 12v fan should have no problem pulling air down across it being that close. It will still be interesting to hear the results of your "stogie" test if you don't mind posting when finished. Very Happy
Dan ThaiWx website
Pages: 1 [2]   Go Up
Page created in 0.201 seconds with 18 queries.
