Author Topic: Humidity reading suddenly reading way too low...  (Read 552 times)
Offline Tennesseestorm
« on: June 07, 2019, 09:38:50 PM »
Hi all.  So glad I found this site.  Looks like many forums on here I will really enjoy.  Anyway, to start off, I have a Davis Vantage Vue weather station, about 4 years old.  Suddenly about 2 days ago, the humidity display on my station started reading way too low.    For example, it is currently showing 37% (despite being extremely muggy outside and that is unheard of here in the southeast this time of year) and it is 90% at the airport less than 15 miles away.  Anyone know what may have happened?  Thanks.
Offline sacreyweather
  • Echo Valley Weather
Re: Humidity reading suddenly reading way too low...
« Reply #1 on: June 07, 2019, 09:47:37 PM »
Mine has been doing the same thing. I have gotten a replacement temp/hygrometer sensor from Scientific Sales. Mine is not quite 7 years old. The expected life span is 3 to 5 years from what I had read.
Saline Weather on Twitter
Blitzortung Station 1387
« Reply #2 on: June 07, 2019, 10:10:32 PM »
Thanks!  Do you have any info or a link on how to order and change it?  I thought I would have to replace the entire station, so this is good to hear.
« Reply #3 on: June 07, 2019, 11:22:33 PM »
VP2 has replacement sensor. It is my understanding that the Vue doesn't. The Vue has to be sent in for service.
Online Mattk
« Reply #4 on: June 08, 2019, 12:13:00 AM »
The Vue can be replaced but it's not just the Humidity sensor but one of the boards including other components,
Offline johnd
« Reply #5 on: June 08, 2019, 03:31:03 AM »
For the first 3 years' or so of production, the Vue did have a replaceable T/H sensor on a small PCB that also contained another sensor element - from memory (BICBW) the wind speed switch.
But from revision M onwards (somewhere around 2013 but can't recall precisely) all of the Vue ISS circuitry was made as a single wiring harness that couldn't be separated. (For early M models the solar panel was not part of the harness but it was included subsequently, so there are actually two distinct harness versions.) You can buy the complete harness as a spare but TBH it's not too much cheaper than a complete new Vue ISS, so simpler just to get a new ISS.
So for eg a 2015 Vue then get a new ISS. (I don't like this either, but it's reality.)
Littleport, Ely, Cambs UK
« Reply #6 on: June 08, 2019, 03:56:10 AM »
Damned if I'd buy another one... :evil:
Offline ValentineWeather
    • LiVE WEATHER
« Reply #7 on: June 08, 2019, 04:41:17 AM »
Just checked Scaled Instruments he is out of stock on Vue ISS. Not cheap either for replacement.
Randy
Offline johnd
« Reply #8 on: June 08, 2019, 05:41:29 AM »
But note that picture is the harness version without the solar panel. The alternative version has the solar panel included (& hardwired IIRC). It's not a big deal rewiring the panel but it does mean that it's not a simple drop-in replacement if you use the 'wrong' version.
And compare this:
https://www.scaledinstruments.com/shop/davis-instruments/sensor-suites/vantage-vue-series-sensor-suites/davis-6357-vantage-vue-wireless-integrated-sensor-suite/
Can you see why I say that you might as well buy a new ISS?
« Reply #9 on: June 08, 2019, 09:25:29 AM »
Thanks for the replies and info.  I am not very technical, so some of this is like Chinese to me.  lol.  Well whatever it is finally went completely out as now it says the humidity is 1% with a dewpoint of -36, lol.  The actual dewpoint at the airport is 70 right now, so its dead.  I am pretty sure it is only 4 years old, so I was hoping it would last a little longer, but this is the first one I have ever owned, so wasn't sure what to expect.  I guess I will just use it for temperature and maybe Santa will bring me a new one for Christmas.  :D  I am not sure what model this is, but I would like one where I can connect it online.  I do not think I could ever do that with this one.
« Last Edit: June 08, 2019, 10:14:21 AM by Tennesseestorm »
    • LiVE WEATHER
« Reply #10 on: June 08, 2019, 10:58:56 AM »
Either way, it's expensive when the sensor goes bad and eventually they all do. Just another reason among many to stay away from the Vue.  On the VP2 bad temp/humidity sensor only sets you back about $40.
Randy
« Reply #11 on: June 10, 2019, 11:01:53 PM »
Thanks.
I hate to hear that.  I thought these were some of the best.  My folks got it for me for Christmas about 4 years ago and I have enjoyed it and used it daily.  The model # is 6250.  I may just replace it with another one.  What is a good weather station that will not cost me an arm and a leg?  I would just like accurate temps/humidity and something that I can share weather online with, such as weatherunderground.
« Reply #12 on: June 10, 2019, 11:40:19 PM »
Honestly, I think you merely got a bad one. Davis certainly isn't perfect, but as a general rule, they're very reliable. My "wouldn't buy another one" comment above was strictly due to the fact that little is replaceable on the Vue unlike a VP2 where virtually everything is replaceable.
