Author Topic: uv index on saratoga template  (Read 598 times)
Offline txweather.org
    • Texas Weather
« on: May 03, 2019, 01:38:43 PM »
I just upgraded to a VP2 Plus +FARS and I change my Settings-weather to say yes to vantage pro 2.
Is there anything else I need to update?
My UV readings seem to be all over the place... from one second it says extreme than on another refresh say low, than none, etc...
Any ideas why? Is this behavior normal?
TIA!
Re: uv index on saratoga template
« Reply #1 on: May 03, 2019, 04:06:26 PM »
It seems to be reporting an invalid value via MeteoHub for 'no' UV
   -    Extreme
High: 0.8 @ 11:59am
the '-' is not a number, so the ajaxMHwx.js script seems to run off the end of the selector and report the Extreme as the interpretation.
Using my WD Clientraw parser shows that the ./MHub/clientraw.txt has
79   Davis VP UV Index   Number (Optional)   -
and the - is the issue.. it should be a number.
Since MeteoHUB generates the clientraw*.txt files itself, it would seem to be a MeteoHUB software or configuration issue.
    • Texas Weather
« Reply #2 on: May 03, 2019, 04:24:01 PM »
   -    Extreme
High: 0.8 @ 11:59am
Seems like a bug?
There is nothing to report right now.... There is no sun... We have a bad storm hitting us and almost dark ourt..
Please see attachment both my meteobridge and meteohub are reporting the same data.....
    • Texas Weather
« Reply #3 on: May 03, 2019, 04:26:05 PM »
I think I have to redo the meteohub setup as changed from vue to pro2
    • Texas Weather
« Reply #4 on: May 03, 2019, 04:40:54 PM »
@saratoga,
I re-ran my MHconfig and see it fixes it self. Please let me know.
    • Texas Weather
« Reply #5 on: May 04, 2019, 12:55:45 PM »
I migrated away from meteohub.... The "-" continue to hunt me. I am now using the nano sd.
« Reply #6 on: May 04, 2019, 01:11:33 PM »
When you change the weather software (MeteoHUB to MeteoBRIDGE), the data provided by the respective software is different.  Meteobridge does not create WD-type clientraw*.txt files, for example.  Some MeteoHUB pages may no longer work.
Just FYI...
    • Texas Weather
« Reply #7 on: May 04, 2019, 01:14:27 PM »
Just FYI...
I am learning this now. This is chaos.
