Author Topic: Just updated to php 7.2.16 - one problem  (Read 606 times)
Offline Johnmac
    • Westminster Massachusetts Weather
« on: April 09, 2019, 11:58:18 AM »
I just updated my php from 5.4 to 7.2.16 and my web page seems to be working fine with the exception of my wccontact.php page, it brings up a "http error 500". Any thoughts as to how I can fix this?
scannorthcounty.net/wxcontact.php
Westminster, MA USA
Online saratogaWX
Re: Just updated to php 7.2.16 - one problem
« Reply #1 on: April 09, 2019, 01:10:55 PM »
You likely have to update the wxcontact.php form set to the new one which uses Google reCaptcha instead of the old built-in captcha (which is easily solved by spammers).
https://saratoga-weather.org/scripts-contact.php#contact
Offline Murry Conarroe
    • Wildwood Weather
« Reply #2 on: April 09, 2019, 05:39:27 PM »
If you haven't updated your wxfreeze script since December 2018, you will need to update it.
http://www.wxforum.net/index.php?topic=24301.msg364940#msg364940
Murry
Offline Johnmac
« Reply #3 on: April 09, 2019, 09:12:34 PM »
Ken, I was already using ver 2.0, I updated contact-inc.php to 2.01 and still get the same error. I used my old "Sitekey" and "SecretKey". Do I need to generate new ones or did I miss something else?
Westminster, MA USA
Offline Johnmac
« Reply #4 on: April 09, 2019, 09:13:49 PM »
Murry,
Thanks for the heads-up, I will update
Westminster, MA USA
Offline Johnmac
« Reply #5 on: April 12, 2019, 11:07:56 AM »
Have not been able to resolve this issue.
If I run the contact-inc.php file, I get the contact page to show up, but no Captcha block.
I am using the latest files from Saratoga Templates. Looking for suggestions to resolve the problem. Started after updating from 5.4 to 7.2
Previous comments -
Westminster, MA USA
Online saratogaWX
« Reply #6 on: April 12, 2019, 11:45:20 AM »
You probably need to update the contact script to the one that uses Google reCaptcha (instead of the old built-in captcha which was easily solved by spambots).
Mike's original contact script used ereg() and split() functions which are deprecated(and removed) from PHP 7+
Offline Johnmac
« Reply #7 on: April 12, 2019, 12:03:37 PM »
Ken,
Unless I am missing something, I believe I have the updated files from your website. V 2.01 - Are those the ones you are referring too? If so, it does not work for me. I can send my contact.php and contact-inc.php files if that would help.
Westminster, MA USA
Online saratogaWX
« Reply #8 on: April 12, 2019, 12:14:27 PM »
Hmmm... V2.01 - 09-Aug-2018 is the current release for PHP 7+
Yes, send me your contact-inc.php and wxcontact.php to webmaster at saratoga-weather.org and I'll take a look.
Online saratogaWX
« Reply #9 on: April 12, 2019, 01:41:43 PM »
Ok, just looked at your contact-inc.php and it looks ok.
What is the error reported in your website's error_log for the page?
Offline Johnmac
« Reply #10 on: April 12, 2019, 02:38:31 PM »
http error 500
Westminster, MA USA
Online saratogaWX
« Reply #11 on: April 12, 2019, 02:49:13 PM »
Umm.. that's the result, not the actual error message from PHP in your website's error_log -- it would look something like:
[Mon Apr 08 03:45:06.632234 2019] [php7:error] [pid 9864:tid 1920] [client ::1:56236] PHP Fatal error: ...
That '...' would have the exact cause of the issue and that is what is needed to resolve the problem.
Offline Johnmac
Re: Just updated to php 7.2.16 - one problem -RESOLVED
« Reply #12 on: April 12, 2019, 05:10:36 PM »
Ken,
After reviewing the php error, I discovered some old "who's_online" settings in my settings.php that were the route of the problem. I commented those settings for whois_online (Not using Whosis_online anymore) and now the contact page is working fine. Not sure why none of the pages were not coming up with this error, at any rate it is now working. Thanks for your help in pushing me in the write direction.
Westminster, MA USA
Offline ed2kayak
  • Ed
    • Cumberland Valley Weather
« Reply #13 on: April 15, 2019, 10:23:26 PM »
John and Ken,
I have this exact problem with the contact page. http://cvweather.org/wxcontact.php
When I commented out (Thanks John), the last 2 lines highlighted below in my settings.php the wxcontact.php works.
My problem is I'd like to keep using the whos-online , at least until I can find a suitable replacement
// include the who's online functions
$C['files_path'] = '/home/cvweather/www/www/whos-online/';              // full path, always end with a slash
$C['files_url'] = 'http://cvweather.org/whos-online/'; // url, always end with a slash
//require ($C['files_path'].'include-whos-online-header.php');
//  $whos_online_records = update_whos_online();
Ed
Online saratogaWX
« Reply #14 on: April 16, 2019, 02:17:00 PM »
There are many things that have to be changed with the old whos-online script set for PHP7+
Among them are changes to calls to mysql, deprecated calls to ereg., etc.
See this thread for more info.
and this thread for downloading some changes for mysql calls.
« Last Edit: April 16, 2019, 02:18:45 PM by saratogaWX »
Offline ed2kayak
  • Ed
« Reply #15 on: April 16, 2019, 06:36:34 PM »
Thanks Ken,
I'll review those.
Ed
