Author Topic: WS-2000 rooftop installed pics  (Read 1644 times)
Offline Platokidd
  • top side land of Lincoln
« on: March 30, 2019, 12:02:20 PM »
 :lol: [ You are not allowed to view attachments ]
27.75 feet off the ground perfectly level [tup]
« Last Edit: March 30, 2019, 12:18:50 PM by platokidd »
Ambient
1-WS-5000 1-WS-2902A 2-WS40/RAIN 1-WH31L
1-METEOBRIDGE 1-PM2.5 (WH41B) 3-WH31 1-SRX100LX
ECOWITT
2-HP2550 2-HP2560 2-GW2000 2-GW1100
2-WS68 1-WS80 1-WH32EP 10-WH31 1-WH40
1-HP10 2-WH45 4-WH55 5-WH51
1-WN30 1-WH41
1-DAVIS 7714
1-STRATUS
1-Fisher Barometer 1436R-22
PWS at 2 locations.
1- Storm Sensor-Zelda the dog ;)
Offline Platokidd
Re: WS-2000 rooftop pics
« Reply #1 on: March 30, 2019, 12:02:52 PM »
Mounted on an old tv tripod
« Last Edit: March 30, 2019, 12:19:46 PM by platokidd »
Ambient
ECOWITT
1-WN30 1-WH41
1-DAVIS 7714
1-STRATUS
PWS at 2 locations.
Offline Platokidd
« Reply #2 on: March 30, 2019, 12:03:41 PM »
Ambient
ECOWITT
1-WN30 1-WH41
1-DAVIS 7714
1-STRATUS
PWS at 2 locations.
Offline Jim_S
Re: WS-2000 rooftop installed pics
« Reply #3 on: March 30, 2019, 02:35:53 PM »
Nice setup. Thanks for posting. Looks like you have a lot of trees to deal with like I do.
Offline daman
« Reply #4 on: March 30, 2019, 03:26:52 PM »
Looks good were you able to level it properly?
KMIBADAX38
AcuRite Iris/AcuRite Access
Offline SoMDWx
    • Southern Maryland Weather
« Reply #5 on: March 30, 2019, 03:30:58 PM »
Have fun climbing up there to clean the debris from the rain gauge......it WILL happen.....
Offline Platokidd
« Reply #6 on: March 30, 2019, 03:54:32 PM »
Perfectly level. Leveled when  the silver pole was in a lowered position. It will slide up/down by loosing the brackets on 1 side. Then I extend the pole to height, re-tighten the brackets and checked level with a mechanics mirror. Bingo still level. [tup] Using the brackets enabled me to have some much needed adjustment room.
« Last Edit: March 30, 2019, 03:57:06 PM by platokidd »
Ambient
ECOWITT
1-WN30 1-WH41
1-DAVIS 7714
1-STRATUS
PWS at 2 locations.
Offline Platokidd
« Reply #7 on: March 30, 2019, 03:58:55 PM »
Yeah, I'm sure it will be fun climbing up  on the roof  :roll:
Before winter I plan on taking it down and moving to lower location. This past winter with the snow build up  hindered the signal  #-o and at times lost it for hours. Need to keep the ice and white stuff off this bird if I can.
« Last Edit: March 30, 2019, 04:03:32 PM by platokidd »
Ambient
ECOWITT
1-WN30 1-WH41
1-DAVIS 7714
1-STRATUS
PWS at 2 locations.
Offline Platokidd
« Reply #8 on: March 30, 2019, 04:08:34 PM »
Yep, lots off mature trees to work around. Went for the best area I could to place it. Guess the nearest tree is about 35 feet away.
Ambient
ECOWITT
1-WN30 1-WH41
1-DAVIS 7714
1-STRATUS
PWS at 2 locations.
