Author Topic: Support of the "Leuven" Forecast scripts  (Read 2248 times)
Offline wvdkuil
  • Wim van der kuil
« on: March 28, 2019, 04:27:01 PM »
All the "Leuven" weather-forecast scripts are in 1 folder and in 1 download. Currently the following forecasts are available :
  • WXSIM-plaintext, WXSIM-lastret/latest.csv
  • Met.no
  • Yr.no
  • Darksky.net
  • UV from KNMI/Temnis
  • Environment Canada + weather warnings
  • NOAA/NWS plaintext type + weather warnings
  • NOAA/NWS SOAP detailed data
Index of all demo pages: https://www.weerstation-herent.be/wsfct4/
Download: https://leuven-template.eu/leuven_download2019.php?id=forecasts
Readme: https://www.weerstation-herent.be/wsfct4/readme.html
Known issues: link will be added when needed
Remarks:
Although you will receive all scripts in 1 download, I think it is unwise to use them all.
Most often 1 default forecast and 1 "back-up" forecast is all that is needed.
Positive: "A lot of settings" To adjust what contents you want, what colours a.s.o.
Negative: "A lot of settings" The output is cached, so you have to learn to clear the cache when testing a change in your settings.
These scripts can be used Stand-Alone and in the Saratoga-template.
They could be used in the Leuven-Template also, but they are not supported there! Use at your own risk.
These are very extensive and complex scripts, do not change the scripts themselves.
Change only the settings and the startpages. All as described in the readme.
Support:
When you post questions about the scripts
  • Always include the URL (=correct link)  to the script on your website
  • Check the demo scripts to see if the problem exist there also. Sometimes the forecast servers are the cause of the problem
  • Also states all other actions you already did to pinpoint the cause of your problems.
Checking those things also helps to reduce the time for answering your questions.
Wim
Support for Leuven-Template & Scripts  at this forum
Script sponsors support.leuven-template.eu/userlistScripts.php
Template sponsors support.leuven-template.eu/userlist.php
Support for the PWS_Dashboard  pwsdashboard.com
If I helped you,  feel free to donate at paypal.me/pwsdashboard  But never ever feel obligated to.
Re: Support of the "Leuven" Forecast scripts
« Reply #1 on: March 28, 2019, 05:12:22 PM »
 =D>  =D> Outstanding, Wim -- thanks for sharing these!
Offline ernstadolfbittkau
    • Die Bittkau' aus Magdeburg Ottersleben
« Reply #2 on: April 02, 2019, 06:45:04 AM »
Danke Wim Super [tup]
Offline philipgm
    • Picton Weather
« Reply #3 on: April 23, 2019, 09:26:11 PM »
Wow! What a great script. Excellent. [tup]
Offline meteosa
« Reply #4 on: May 17, 2019, 02:12:12 PM »
Hello,
I installed your Forecast scripts, but how do I set the Italian language? I put the file in the "lang" folder, set in the php file: lang: "it" but it doesn't translate it for me, why?
Thank you
Offline wvdkuil
  • Wim van der kuil
« Reply #5 on: May 17, 2019, 02:49:31 PM »
Hello,
Thank you
@ALL  PLEASE ALWAYS INCLUDE THE URL TO YOUR WEBSITE / SCRIPT
As from now, no answers if you do not include the links.
@metosa
I will use the Italian language as example, but it works the same for most western languages
To install 1 extra language, follow these steps
  • In the wsfct4/lang/ folder copy one of the current language files f.i. fctlanguage-en.txt and change the name to  fctlanguage-it.txt
  • DO NOT COPY any other language file you may have, use only a copy of an existing file in the lang folder
  • Carefully change all texts at the right to Italian
  • Change the allowed languages around line 250 in your settings file , in this case _metric_settings.php to contain your new language
That array to change is below the warnings about knowing what you are doing. Be careful.
#                              language settings
$ws_langs_supported = array ('en', 'nl', 'fr', 'de');
Change to
#                              language settings
$ws_langs_supported = array ('en', 'nl', 'fr', 'de','it');
Wim
Offline ugo71
« Reply #6 on: June 15, 2019, 10:15:48 AM »
Hi, Wim excellent script thanks.  [tup]
It could be an idea to make a yr.no script (which in my opinion is one of the most reliable) for mobile devices by putting only 3 forecasts on one line then on the line under other 3 forecasts.
Offline wvdkuil
  • Wim van der kuil
« Reply #7 on: June 15, 2019, 10:38:13 AM »
Thanks for the compliment.
I use the scripts myself also for the mobile devices.
The forecast is in a separate page with a normal forecast so users can scroll / move through all info.
Maybe next year i will have time to make a new 'responsive' version also.
Wim
Offline weatherola
« Reply #8 on: January 27, 2020, 12:45:22 PM »
Wonderful work on this Wim. And, thanks for your support on the Weather34 templates, too.
The one question I have is related to the DarkSky forecasts when used within Ken's Saratoga templates. I've followed your setup instructions and it seems to be working fine, with the exception of template width issue (looking forward to responsive templates for everything) but under the forecast header appears..."Forecast data created at Monday Jan 27 2020 - 9:26am For Station Xetc, etc." I get my Lat/Long location added  on. I really don't want the GPS location of my station shown. Is there something wrong with the way I've set this up, or is there a simple way to turn this off or comment it out?
Tim
Offline wvdkuil
  • Wim van der kuil
« Reply #9 on: January 27, 2020, 01:14:20 PM »
Tim
i am on vacation with insufficient internet. There is a setting to switch off  testing/debug and that will also remove the lat-Lon numerals.
I will be back Feb 1 and will check this out
Wim
Offline weatherola
« Reply #10 on: January 29, 2020, 01:24:59 PM »
Thanks Wim. I might be looking in the wrong place. Haven't managed to turn off the testing switch, so still seeing lat/lon.
Tim
weatherola.com
Offline wvdkuil
  • Wim van der kuil
« Reply #11 on: February 01, 2020, 12:03:31 PM »
Tim
weatherola.com
The settings files,  such  as _metric_settings.php contain the setting to switch all errors (and other debug code) off when you are finished testing.
Set $ws_errors to false and the string such as "Forecast data created at Saturday 01 February 2020 - 17:55 For: 51.904,5.69" will not be shown.
If you later on doubt if there is "a problem / error" simply add ?debug or &debug to your URL and the date/time/lat/lon will be shown with  all other "messages"
Succes, Wim
#            for ALL websites using metric units
# # #  Here you have to make the changes   # # #
# # #       for stand-alone use            # # #
#                       error messages on or off
#    always set to false for production versions
$ws_errors      = false; # false when ready testing
Offline weatherola
« Reply #12 on: February 01, 2020, 02:13:16 PM »
Thanks Wim for clarifying the location for the switch. Unfortunately, setting the switch to "false" still leaves me with the string showing. I am using the _us settings and changed it there as you suggested. I would think that would have removed it, but alas, no. All is the same. If you'd like to have a look, feel free to visit weatherola.com. Sorry to be such a pest.
Tim
Offline weatherola
« Reply #13 on: February 02, 2020, 12:05:07 AM »
Wim,
The switch seems to be working, now. Though I tried it on a couple of computers earlier, the debug code is no longer visible and switched off. Caching, I assume. All better now.
Thanks again for your help, Wim.
« Last Edit: February 02, 2020, 12:07:32 AM by weatherola »
Offline ctccbc
  • Acurite 01035, Weather Display
    • Chris Collins Morehead City, NC Weather
« Reply #14 on: February 13, 2020, 11:38:56 AM »
I posted this question to the wrong forum earlier.
I'm trying to run the Wunderground colored table history script. When I run the script, I get this error:
ERROR: no data for http://change_to_your-site_in_wsReports1part.php/WXDailyHistory.php?ID=KNCMOREH2&month=01&day=01&year=2016&format=1&graphspan=year
I have been running Weather Underground for my site KNCMOREH2 for several years now.
Any help is appreciated,
Chris
Offline wvdkuil
  • Wim van der kuil
« Reply #15 on: February 13, 2020, 12:27:46 PM »
Chris
Please be specific.
Your last post https://www.weather-watch.com/smf/index.php/topic,68752.msg555633.html#msg555633
=> is about a version 4 forecast script wsfct4/wsIncWuCreate.php
Now you are posting in the forecast topic about  the coloured table script
The general support page with all links for all Leuven scripts  is at: https://support.leuven-template.eu/
For the script you are now talking about the support topic is:
https://www.wxforum.net/index.php?topic=36473.msg374472#msg374472
This readme describing how to install the MITM scripts is included in the download and should be in the wsreports folder on your server also.  https://www.weerstation-herent.be/wsreports/WU_CSV_problems_readme.pdf
But if you post in the forum without a link to the start-page of the script,  nobody can help you as, AFAIK, none of the visitors on this forum is clairvoyant.
Wim
Offline plex
« Reply #16 on: February 16, 2020, 01:37:49 AM »
Hello weather enthusiasts and Leuven users
After spending time with other templates, I decided to do a fresh Leuven installation, because itís still a fantastic template - I really like how customizable it is. So thanks to Wim for keeping it alive.
However I need some help, because Iím struggling with some errors while debugging.
Notice: Undefined index: iconDtl in /var/www/vejrstationen.dk/public_html/weather28/wsmetno3/metnoGenerateHtml.php on line 186
Notice: Undefined index: weatherDescDtl in /var/www/vejrstationen.dk/public_html/weather28/wsmetno3/metnoGenerateHtml.php on line 189
Thanks in advance and happy windy Sunday
Sent from my iPad using Tapatalk
« Last Edit: February 16, 2020, 03:28:00 AM by plex »
Offline wvdkuil
  • Wim van der kuil
« Reply #17 on: February 16, 2020, 03:10:28 AM »
After spending time with other templates, I decided to do a fresh Leuven installation, because itís still a fantastic template - I really like how customizable it is. So thanks to Win for keeping it alive.
The link to the page: https://www.vejrstationen.dk/weather28/index.php?p=ws_metno_page&lang=en
Thanks for bringing these "notices", not "errors"  to my attention. I knew there were some changes scheduled in the 1.9 API.
I do not get these notices myself, but it seems that the time is right to start debugging.
I will use your settings for that "Data for latitude=55.899269 - longitude= 8.516578"
@ALL When switching debug to false in your settings, the notices will not be shown, nor appear in in the logs.
These are not "errors", it are "notices" to the script author that the scripts need to be enhanced.
When in  debug mode the scripts print all possible messages "notice", "strict",  "deprecated",  "warning", "error" and "fatal"
Wim
« Last Edit: February 16, 2020, 03:25:46 AM by wvdkuil »
Offline plex
« Reply #18 on: February 16, 2020, 03:24:21 AM »
When in  debug mode the scripts print all possible messages "notice", 'warning", "error" and "fatal"
Wim
Thanks for clearing this out Wim [tup]
Iím ignoring the message then, and moving on to production.
Offline wvdkuil
  • Wim van der kuil
« Reply #19 on: February 16, 2020, 04:55:02 AM »
. . . shortened . . .
Wim
The last hourly forecast seems "incomplete", but not in all cases.
I added some code to use the icon and description from the 6-hour forecast when there is no corresponding hourly data.
Could you ,please use this version for a few days?
You can always check if there are errors by adding &debug to the url
Wim
