Author Topic: PWS monitor for Android/iOS  (Read 4411 times)
Offline superduty
Re: PWS monitor for Android/iOS
« Reply #75 on: August 06, 2019, 03:29:37 AM »
I am running on Galaxy S10 and I have a problem with min/max on temps and dew.
For today I show min/max temps of 158.5 and 159.6
dew 125.2 and 127.2
Hopefully a fix is in the works.  Once that is fixed, I will go for the paid version.
Thank you
Offline buffy
  • My PWS: Garni Ventus 830
    • PWS Monitor
« Reply #76 on: August 06, 2019, 03:55:25 AM »
dew 125.2 and 127.2
Thank you
Yes, this is a problem with unexpected data unit values... Sorry for that. Please try send me PM of your PWS WU ID for testing. If there is problem in app with downloading unexpected units, you see "F!" in units place in temp chart. Is it there?
I'm trying make new data download function for elimination this error.
Offline buffy
    • PWS Monitor
« Reply #77 on: November 01, 2019, 05:21:46 AM »
PWS monitor PRO 4.0.8
- fixed MIN for temperature
- fixed MIN for dew point
- changed wind MIN to gust MAX
- added up to 10 accounts to add
Download
https://play.google.com/store/apps/details?id=com.tools4monitoring.meteo.pws.pro
Offline superduty
« Reply #78 on: November 01, 2019, 08:51:26 AM »
Is there no longer a free version?
Or are the updates only for the pro version?
Sent from my SM-G973U using Tapatalk
Offline buffy
    • PWS Monitor
« Reply #79 on: November 01, 2019, 10:11:23 AM »
free version is still available. but this update is only for PRO version. free version will be also fixed
Offline buffy
    • PWS Monitor
App is not updating actual values
« Reply #80 on: January 08, 2020, 04:36:06 AM »
Since yesterday WU stopped providing current values in XML. we are working on fix.
Offline buffy
    • PWS Monitor
« Reply #81 on: January 08, 2020, 04:46:28 AM »
FAST FIX
without app updating from store:
1. remove your PWS in settings
2. add your PWS again
3. data should be actual
Sorry for this issue. We will update app in stores ASAP.
Offline Rychu
  • Type of station: HP1001WiFi & WH2600IP (WS1400IP)
    • Check on-line measurements and forecasts of Gdansk in Poland
« Reply #82 on: January 10, 2020, 04:36:52 PM »
Unfortunately, deleting and re-entering the station ID does nothing. For example, the solar display is 0 Watt.
I purchased the APK for two smartphones.
Offline buffy
    • PWS Monitor
« Reply #83 on: January 10, 2020, 05:57:20 PM »
WU switched off one of feeds with values...
Anyway, please, try update to version 4.2.2 and let me know if this help you. I tried fix problems, but I haven't for example testing feed in imperial units.
Do you have solar sensor and you should see this value?
Sorry for this issue. I try fix what WU made...
Offline Rychu
« Reply #84 on: January 10, 2020, 06:07:50 PM »
I updated to 4.2.2. It's 0.00 - I'll check in tomorrow and let you know.
Offline buffy
    • PWS Monitor
« Reply #85 on: January 10, 2020, 06:09:31 PM »
OK. I need know about bugs. Few values are gone, but solar you should see.
thanks for feedback
Offline Rychu
« Reply #86 on: January 11, 2020, 12:59:07 PM »
I think it's ok  ;)
Offline Carne81
« Reply #87 on: January 13, 2020, 05:53:05 AM »
Good App! Are you planning to add some widgets?
Offline buffy
    • PWS Monitor
« Reply #88 on: January 14, 2020, 07:12:05 AM »
yes, I tried make some test and maybe it will be available like separate app widget. but now I made only few tests. Hope it will be possible.
