Author Topic: PWS monitor for Android/iOS  (Read 3414 times)
Offline buffy
  • My PWS: Garni Ventus 830
    • PWS Monitor
Re: PWS monitor for Android/iOS
« Reply #50 on: April 02, 2019, 03:59:06 PM »
If I understand right, you would like to see somewhere on mainpage rose with wind direction?
That's what I was thinking. Even just an indicator arrow. Maybe in the little space left of the temp/under the station ID.
Or what about instead of text like "South" a little rose instead?
Status bar info is little bit problem, but somewhere on mainscreen I can show some little rose with actual wind direction. Also there is no much space for gust, which I'd like see there :) But yes, this feature I will try add.
Offline buffy
    • PWS Monitor
« Reply #51 on: April 02, 2019, 04:01:04 PM »
The refresh seems to work for me.
Yes it works fine.
Enjoy,
thanks a lot guys! it sounds like it's working. I have some negative review after update about autorefresh option. But it works for me on many devices. thanks a lot for feedbacks.
Offline buffy
    • PWS Monitor
« Reply #52 on: April 04, 2019, 06:50:28 AM »
I'm working on it. Look preview picture. Is it like you wish? :) I added direction rose to menu.
Offline davidmc36
    • IONOTTAW14
« Reply #53 on: April 04, 2019, 07:47:01 AM »
So that rose icon updates with the station data?
If so, That's like perfect. Quick reference graphical is easy to spot.
Offline buffy
    • PWS Monitor
« Reply #54 on: April 04, 2019, 09:43:40 AM »
Yes, it is updating with actual PWS dataset - it's wind direction info. works fine for me.
Offline NETO
« Reply #55 on: April 04, 2019, 09:53:00 AM »
OK if the "wind rose" with arrow is running ....
I think we do not need the next icon (wind) cause it all could be done by the "wind rose" with arrow.
You got more space
Offline buffy
    • PWS Monitor
« Reply #56 on: April 04, 2019, 09:56:54 AM »
You got more space
that's right. After click I have there windy.com map. But yes, I will change a wind icon for new wind rose compass.
thanks
Offline buffy
    • PWS Monitor
« Reply #57 on: April 05, 2019, 05:02:25 AM »
Update 4.0.3 and 4.0.9 Android
New feature
- Wind icon with direction rose compass
- windy widget map in Wind section (only paid version)
I also tried fix unexpected imperial unit problem in temperature chart. but I'm not sure if it's working right. I neve got wrong dataset... But sometimes it happens.
Help
Please if you will see in temperature chart units with '!', please contact me (F! or C!) with screenshot if you can. I'd like know if temperature/dew chart data shows right in imperial units. Also I have still one bad feedback with autorefresh. But you wrote me, it's OK...
Offline NETO
« Reply #58 on: April 05, 2019, 05:23:32 AM »
Hello
It seems to run OK
Meanwhile let me point other option.
Once you got in the middle an area with wind info named "WIND FROM" maybe you can use the "wind rose" in this area too and free the upper area ( where it is now).
In that way we got a visual and a descritive indication of the wind in one onle position.
That area could be also the sensitive area to call the wind page.
On the wind page I would like to see a way to get back to main page diferent from the "PWS METEO" on first row because when we have auto update selected it will reload every time we come back from wind page to main page. Hope you agree and that could be done.
Regards
JMCN
Offline davidmc36
    • IONOTTAW14
« Reply #59 on: April 05, 2019, 05:35:35 AM »
....other option.
That area could be also the sensitive area to call the wind page....
I thought of that too. It's another good option.
Offline buffy
    • PWS Monitor
« Reply #60 on: April 05, 2019, 07:45:59 AM »
thanks guys!
I can make clickable "wind from" section, but I tried put compass inside the box, but there is no space. Only without word direction. I will think about it. Anyway, compass icon in the top menu will stay there, wind section is my favorite :)
Autorefresh will be repaired, but don't know how just now. I know about problem with autorefresh if you go back to main page via app logo - page is refreshed again.
thanks for new ideas for improvements!
Offline txweather.org
    • Texas Weather
« Reply #61 on: April 05, 2019, 08:03:38 AM »
buffy,
Have you been able to figure out how to add the weather to the lock screen and the icon bar(Taskbar)?
Thanks!
Offline buffy
    • PWS Monitor
« Reply #62 on: April 05, 2019, 08:09:58 AM »
buffy,
Thanks!
I never tried it. But I can read something about it. we talk about android, right?
    • Texas Weather
« Reply #63 on: April 05, 2019, 08:14:56 AM »
buffy,
Thanks!
That is right :)
Right now is use Wunderground app because it allows me to see my temperature on my taskbar wile on my phone and also allows me to see it while the phone is locked with a lockscreen forecast.
Let me try again for pictures.
    • Texas Weather
« Reply #64 on: April 05, 2019, 08:18:15 AM »
Here is the temperature on the Taskbar...
    • Texas Weather
« Reply #65 on: April 05, 2019, 08:21:15 AM »
Lock screen
Offline buffy
    • PWS Monitor
« Reply #66 on: April 05, 2019, 08:22:27 AM »
but it must run on background... that's not good practice.
I will try learn something about this feature
Offline davidmc36
    • IONOTTAW14
« Reply #67 on: April 05, 2019, 08:33:07 AM »
If it can be selected on or off it would be a great feature.
    • Texas Weather
« Reply #68 on: April 05, 2019, 08:38:13 AM »
What he said above! :D
« Last Edit: April 05, 2019, 08:40:03 AM by txweather.org »
Offline davidmc36
    • IONOTTAW14
« Reply #69 on: April 05, 2019, 08:47:31 AM »
The choice for Wind Rose on top bar is exactly right. On top, first thing I see.
All the data is right below. This is how info apps should be made. No extra bull. The app is tiny on your phone but does a workhorse job of delivery.
Offline buffy
    • PWS Monitor
« Reply #70 on: April 08, 2019, 02:51:53 AM »
I was looking for some solution for lockscreen. And I have not good news about this. Lock screen is little bit impossible just now. Also widget :( android and Ios have another solutions of these and it's difficult for me cover both platforms. Sorry guys.
Status bar looks better. I know how can I change background color of status bar :)
but all features above need background running.
After app will be finished, I will try add these features. Now I have still so many things for repair, because of unstable WU. I have still issues with metric/imperial mesh units..
Offline buffy
    • PWS Monitor
« Reply #71 on: April 11, 2019, 01:52:38 PM »
Update 1.0.1 iOS
- Fixed imperial unit problem in temperature chart
Offline buffy
    • PWS Monitor
« Reply #72 on: April 18, 2019, 02:03:40 PM »
I'm working on new tablet version of PWS monitor app. Here is little preview.
Offline davidmc36
    • IONOTTAW14
« Reply #73 on: April 18, 2019, 02:32:27 PM »
That's a sweet looking display. My wife will like that for her tablet.
Offline buffy
    • PWS Monitor
« Reply #74 on: April 18, 2019, 02:38:52 PM »
great. maybe I will add more photo themes. Primary I'd like make app landscape lock for some old devices like my old tablet. It can run somewhere, now I have it for nothing.
