Author Topic: New SSL certificate, no FTP upload. **solved**  (Read 455 times)
Offline wsNoordbergum
    • wsNoordbergum
« on: February 12, 2019, 02:06:58 AM »
Yesterday I installed a new SSL certificate.
But now my FTP upload of my meteobridge is not working.
Previous year no problems with SSL and FTP.
Guess the overlap in certificate is the problem.
As a workaround I temporarily disabled SSL.
Next week I will try again, then the previous certificate is expired.
Test upload works fine, scheduled is not.
Wsnoordbergum
« Last Edit: March 11, 2019, 04:33:59 PM by docbee »
Davis Vantage Pro 2 UV/Solar
Meteobridge nano SD
Ecowitt WS90 WH40 WH31 WH57 GW2000 HP2550_c
CumulusMX/raspberry Pi 4b
    • wsNoordbergum
Re: New SSL certificate, no FTP upload.
« Reply #1 on: March 11, 2019, 02:07:07 PM »
Solved.
Some changes with .htaccess file excluding few directories from https has solved the issue.
Not sure if meteobridge will upload if I undo the .htaccess changes.
Will try though....
wsNoordbergum
Meteobridge nano SD
