Author Topic: wxwugraphs stopped working after switching to https  (Read 168 times)
Offline CamarilloWX
  • CamarilloWX
    • Camarillo Weather
« on: February 01, 2019, 02:53:27 AM »
Hi All,
My wxwugraphs page stopped working after switching the site from http to https.  I currently have a .htaccess file redirecting http to https so you can't see the working version now.  I temporarily removed the .htaccess file to confirm the problem and wxwugraphs works when connecting with http.  The issue can be seen at https://www.camarilloweather.com/wxwugraphs.php.  Any ideas on why wxwugraphs doesn't work with https and what I can do to fix it?
Eric
« Last Edit: February 01, 2019, 02:56:16 AM by CamarilloWX »
Eric
Offline wvdkuil
  • Wim van der kuil
Re: wxwugraphs stopped working after switching to https
« Reply #1 on: February 01, 2019, 04:07:09 AM »
Hi All,
Eric
You have to go into the scrips and change all http references to scripts from http to https.
These are the first two error messages.
wxwugraphs.php:1 Mixed Content: The page at 'https://www.camarilloweather.com/wxwugraphs.php' was loaded over HTTPS,
but requested an insecure script 'http://ajax.googleapis.com/ajax/libs/jquery/1.4.2/jquery.min.js'.
 This request has been blocked; the content must be served over HTTPS.
jq-core-widget-tabs.min.js:15 Uncaught ReferenceError: jQuery is not defined   at jq-core-widget-tabs.min.js:15
Development and maintenance of Leuven-Template&Scripts  at: https://support.leuven-template.eu/
Support for the HWS-template for WD http://wd34.weather-template.com/  Demo http://wd34.weather-template.com/pwsWD/
My PWS at home https://weer.sluispark.be/
And at my daughters house https://www.weerstation-herent.be/
Offline CamarilloWX
  • CamarilloWX
    • Camarillo Weather
« Reply #2 on: February 02, 2019, 12:37:11 AM »
Thanks, that fixed the issue.  I didn't think to look for mixed content because my browser was showing a padlock.  The offending entry was in WUG-settings.php.
Eric
