Author Topic: UK Met Office WOW / WOW-NL error 403. **solved**  (Read 1570 times)
Offline livefeed
    • Lusby Live!
« on: January 30, 2019, 11:19:48 PM »
My login is correct as I get green ticks but the Live data tab gives me the flooding error;
UK Met Office WOW / WOW-NL:   2019-01-30 23:16:53 ERROR 403: Forbidden. (unlimited more tries, netx in 150 secs)
Any ideas how to fix this?
« Last Edit: August 31, 2021, 04:36:30 PM by docbee »
Offline ConligWX
  • #conligwx
    • conligwx.org
Re: UK Met Office WOW / WOW-NL error 403
« Reply #1 on: January 31, 2019, 02:45:03 AM »
how many retries do you have set?
What time period is set to upload with?
Regards Simon
Offline freddie
    • Alcaston Weather
« Reply #2 on: January 31, 2019, 08:15:02 AM »
On the WOW info page (https://wow.metoffice.gov.uk/support/dataformats) the following is suggested:
It is recommended that the interval between automatic observations from your AWS is at least 5 minutes.
Freddie
Offline livefeed
    • Lusby Live!
« Reply #3 on: January 31, 2019, 01:12:11 PM »
Right now this but still get that error.
Offline ConligWX
  • #conligwx
    • conligwx.org
« Reply #4 on: January 31, 2019, 01:57:27 PM »
Retry forever???? I'm guessing wow is blocking you from constant retries.
Sent from my ONEPLUS A6003 using Tapatalk
Regards Simon
Offline livefeed
    • Lusby Live!
« Reply #5 on: January 31, 2019, 02:05:58 PM »
Thanks for the replies  - I am going to shoot them an email and see what they say.
Offline Mattk
« Reply #6 on: January 31, 2019, 03:19:42 PM »
Retry Forever, is not a good option.
Offline livefeed
    • Lusby Live!
« Reply #7 on: January 31, 2019, 03:22:54 PM »
ok changed it to 50
Offline Mattk
« Reply #8 on: January 31, 2019, 03:29:19 PM »
For now since there is an apparent issues with retries I would be setting it to None.
Offline JayMacofOz
« Reply #9 on: January 02, 2021, 02:52:34 AM »
I found this post useful as I was having a similar error on the website (error 400).
I set the retries to zero, but noted that only 10mins upload interval would work. Could not do 5mins.
Hope someone else finds this helpful.
Offline Mattk
« Reply #10 on: January 02, 2021, 04:33:27 AM »
Have been using both 10 and 5 minute upload intervals without any issues for quite some time now
Offline azchrisf
« Reply #11 on: August 17, 2021, 02:59:00 PM »
I just started doing Met Office and I'm getting the 403 too...I am set at 10 minutes/5 retries.
Also doing Soil and Leaf 4x
My setup:
https://www.wxforum.net/index.php?topic=41867.0
Offline saltddirk
« Reply #12 on: August 23, 2021, 03:32:41 AM »
had the same issue,
the ID you have to put in is your station ID and not your user ID.
on the WOW site go to your dashboard and select your station. the id is shown just below the little map with your location.
the pin is the one you have created when you created your site
hope this helps
Dirk
Offline azchrisf
« Reply #13 on: August 26, 2021, 03:58:48 PM »
I got it fixed.
Thanks though :-)
My setup:
