Author Topic: GRLevel2 Analyst Volume Table Help  (Read 986 times)
Offline BruceDeluxe
« on: January 30, 2019, 03:11:51 PM »
I have a load of volume tables that I would like to add into my GRLevel2 Analyst program.  However, whenever I go to import them through File > Import > Volume Alpha Tables I get an error message saying that there are no files found, when I know I have at least 10 or more downloaded, (see attached.)  I have never used 3rd party volume tables and mostly have made due with my own but I cannot figure out what is going wrong.  I may just be being stupid but any help would be appreciated!
Thanks in advance,
Bruce
Offline sacreyweather
  • Echo Valley Weather
Re: GRLevel2 Analyst Volume Table Help
« Reply #1 on: January 31, 2019, 04:29:24 PM »
Hi Bruce,
I never used the Import function, I just installed them into the directory. The directory is located in the Users folder, but it is hidden by default. You will have to enable Hidden Files and Folders.
The folder directory is:  Users, what your username directory is called, App Data, Roaming, GRAnalyst_2, VolumeData
Saline Weather on Twitter
Offline BruceDeluxe
« Reply #2 on: February 01, 2019, 07:36:10 AM »
TYSM!!!  You are actually a life saver!  It worked, but I don't know why I didn't of trying this before.  I tried putting it in the program files directory but never in there.
Thanks for the help,
Bruce
