I have a 15 year old Texas Weather Instruments WR-25 station connected via RS-232 @19200 to my pc, running XP Pro SP3 and VWS 12.08p11. This is mostly a very stable and reliable set up - which is why I have not changed versions of VWS (since nothing regarding my station has changed since this version).
However - twice each year I have to shut everything down to reset the clock in the WR-25, and fix VWS's databases.
I have asked Ed before (and gotten no response- I suppose because Tx Wx stations are a distinct minority of VWS users), as well as the folks at Tx Wx for a simple solution to this annoying problem.
What I am asking for here is whether anyone else who uses as Texas Weather Instruments machine has a command utility that just synchs the WR-25 clock to the pc clock.
I know you can use TWI_Log, but this has no commmand line parameters, and so cannot be used in a batch file or as a scheduled task. TWICal - a Windows based program written in VB, won't work with my old WR-25, and won't run a a scheduled task either.
Surely SOMEBODY else out there has found a clever way to fix this - after all - it's not like we are try to repair a Space Shuttle or anything
](https://www.wxforum.net/Smileys/default/eusa_wall.gif)
Thanks!
Steve
