Author Topic: Weather34 template, block Dayligth Darkness no display data!  (Read 260 times)
Offline Rhoos
« on: January 13, 2019, 01:30:39 PM »
Greetings community of enthusiasts, recently I configured the weather34 template in a local server (NAS Synology) for testing purposes, the configuration in Meteobridge is fine, the information is updated without problems in the MariaDB 10 database, use PHP 7, Apache HTTP 2.4 and phpMyAdmin without any difficulty, I have also in test form another template "Meteotemplate" successfully.
The problem as you can see in the attached image is that the data block corresponding to "Dayligth Darkness" does not display any data for no apparent reason, I have tried several configurations of the template without solving this problem. :-(
Could some of this helpful community give me a clue that I need in my configuration to work properly.
Thank you very much for your time
Richard
