Author Topic: Saratoga Base-World templates switch to DarkSky forecast before WU API shutdown  (Read 955 times)
For all the Base-World template users, make sure you switch to using DarkSky for forecasts before the planned 15-Feb-2019 shutdown of the WeatherUnderground API (at which time your WU-forecast.php scripts will cease operation).
The easiest way to switch is to use the update tool page with a query of Base-World, Plugin-*, 02-Dec-2018 to get all the needed files.  Follow the instructions in the included Settings-DarkSky-README.txt file to change your Settings.php to add the DarkSky API key and forecast locations to your site.  The ajax-dashboard.php and wxforecast.php scripts have also been updated for DarkSky support.
If you're using the ajax-dashboard6.php, please see this post for details on what to modify.  I've also updated the legacy script page with 6.95a of Scott's alternative ajax-dashboard6.php script (just the one file was updated).
WU has revealed the future API replacement and said it would be free for low-volume PWS data submitters to use, but has not offered any API keys for the new API yet -- the new API is INCOMPATIBLE with the existing WU-forecast.php, so you'll have to change to DarkSky.net forecasts before they shut off the old API.  I'll try a rewrite of WU-forecast for the new API as soon as keys are available -- right now they're only talking about a 5 day forecast period (instead of the current 7 day forecast).  DarkSky provides a 7 day forecast, but only for 24hr periods (so only 7 icons).
I'll keep you posted about developments for the WU API replacement -- in the meantime, DO update your sites to use DarkSky forecasts NOW.
Best regards,
Ken
Offline vinesweather
    • The Vines Weather
It looks like Dark Sky has some sort of issue as no confirmation or API is issued once you register\signup.
