Author Topic: How do I listen to weather band on Worldstar multiband?  (Read 985 times)
Offline marrowhlp
« on: November 13, 2018, 04:49:33 PM »
Just picked up an old Worldstar MG-6600 for weather purposes, and when I have the band set to between 162 and 163 MHz, where weather bands usually are, I hear nothing. AM/FM works just fine. I hope this is the correct forum to ask this type of question.
Re: How do I listen to weather band on Worldstar multiband?
« Reply #1 on: November 13, 2018, 05:32:26 PM »
Does it actively scan the range from 162 to 163?  If not, you need the specific NOAA freqs for your area.  http://www.nws.noaa.gov/os/marine/wxradio.htm
Offline WeatherHost
« Reply #2 on: November 13, 2018, 05:55:06 PM »
They're also very low power, so if you're not relatively close to one, you may not get anything.
ICDHost, Webhosting:  https://www.icdsoft.com/c/webhost
« Reply #3 on: November 14, 2018, 08:54:36 AM »
There are coverage maps at http://www.nws.noaa.gov/nwr/Maps/index.php You should be able to see the expected reception for your area. I recommend the maps by county (e.g Michigan, select your state).
Here is mine:
