Author Topic: Opinions on WeatherFlow smart weather stations?  (Read 3744 times)
Offline Brian J
« on: October 26, 2018, 09:37:15 AM »
Hi all, I'm seeking opinions on the accuracy of and experiences regarding the WeatherFlow stations.  I know there may be issues with rainfall - of which I don't much care.  Temp, dewpoint, pressure, wind are my concerns.  How is the sonic anemometer correction doing in rainy conditions?  How high a wind have you all measured?  Any thoughts are much appreciated.  My preference is for no moving parts, which limits the list of options as far as personal stations are concerned.
Thanks!
   Brian
Offline vreihen
  • El Niño chaser
  • K2BIG
Re: Opinions on WeatherFlow smart weather stations?
« Reply #1 on: October 26, 2018, 05:36:53 PM »
Here's a live link to my custom weewx report, which plots the WeatherFlow station and my Davis VP2 on the same graphs:
http://ae3.homelinux.net:845/weewx/compare.html
As we are expecting a nor'easter here with 35+ MPH wind and 1-3" of rain tomorrow, feel free to stay tuned to that link during the day and we'll both see how it performs.....
Offline Brian J
« Reply #2 on: October 26, 2018, 06:01:51 PM »
This is awesome.  It looks pretty good.  The pressure differences are presumably just calibration.  Does your VP2 correspond well to other stations/ASOS?
Thanks for sharing this!
    • Conditions @ CW2274
« Reply #3 on: October 26, 2018, 06:06:29 PM »
Beat me to it, same question.
Offline vreihen
  • El Niño chaser
  • K2BIG
« Reply #4 on: October 26, 2018, 06:53:02 PM »
There's an ASOS (KMGJ) across town to the west, but it is in an open area with crazy wind exposure and I'm lucky to see 29 MPH peak gusts.  There's also KSWF about the same distance to the east.
WeatherFlow just added the barometer to their continuous learning (CL) algorithm in the past week or so, and I just peeked at the ASOS to see that I was reading 30.086 in the WF app when the ASOS was reading 30.07.  (weewx was reading 30.06, because I had a pre-CL adjustment hard-coded into weewx.  I have made no attempt to calibrate the Davis barometer.
https://smartweather.weatherflow.com/share/910/grid
One can never have too many weather stations...and they all basically read the same thing most of the time:
I'm even more curious than you are about if the ultrasonic is going to drop out in 20+ MPH winds and moderate/heavy rain.....
« Reply #5 on: October 26, 2018, 07:44:33 PM »
This question is not necessarily for you, but I've always wondered why some PWS have to "learn" the pressure. It's merely a measurement, like every other piece of data. Soon as power is supplied to a VP2 or Vue console the pressure reading is instantly displayed, there is no "learning".
Offline thomas
« Reply #6 on: October 26, 2018, 11:29:06 PM »
I have been happy with my WeatherFlow. It seems to read speeds a little higher than my Davis Vantage Pro on windy days.  Not sure which is correct.  Temp matches well with the Davis and I have it mounted in a box like this converted to a temp shelter.  A few weeks ago I saw these on Amazon for $25 .
https://www.gardeners.com/buy/wood-shutters-lantern-with-led-timer-candle/8592509.html
Offline nincehelser
    • nincehelser.com
« Reply #7 on: October 27, 2018, 05:30:52 AM »
With Acurite (and I think some LaCrosse systems now) "learn" a sea-level adjusted pressure by averaging pressure readings over time (e.g. 2 to 4 weeks).  This allows a reasonable setting to be achieved without the user having know or do anything.  The big disadvantage is that it is very slow method.
Acurite only uses the "learning method" for the local console display value.  Values transmitted to a computer or network are adjusted using more typical methods.
My understanding of the WeatherFlow CL system is that it uses your elevation (gained from the network or manual input) to adjust the pressure, then further "fine-tunes" using regional pressure data from the network.   It's almost like they are re-calibrating the baro sensor daily instead of yearly like you might to account for an aging sensor's drift.
While that sounds good on paper, I'm unclear what practical advantage this has.  Maybe it's because the WeatherFlow baro sensor is outside, exposed to wide temperature variations, instead of being situated in a more temperature-stable indoor environment?
« Last Edit: October 27, 2018, 05:37:40 AM by nincehelser »
« Reply #8 on: October 27, 2018, 06:27:08 AM »
Holy crap. The only thing I needed to know was my elevation MSL and select "Altimeter Setting" on the console (obviously my choice of scale). No waiting, instant, accurate pressure!
How can it be easier than that?
Offline nincehelser
    • nincehelser.com
« Reply #9 on: October 27, 2018, 09:24:40 AM »
]Holy crap. The only thing I needed to know was my elevation MSL and select "Altimeter Setting" on the console (obviously my choice of scale). No waiting, instant, accurate pressure!
By just unpacking the device and letting it figure it out on its own.
Not all consumers understand how to set a barometer, or even know what their elevation is.
Offline vreihen
  • El Niño chaser
  • K2BIG
« Reply #10 on: October 27, 2018, 10:17:50 AM »
WF is ultimately planning on having every sensor in their stations calibrated via CL, which of course requires finding/licensing global data source(s) for each reading to calibrate against.  I'm guessing that barometer was a low-hanging fruit, and think I remember reading that they had a global satellite source for high noon UV measurements to get those trimmed in via CL.
The WF station's barometer will take elevation and height inputs out of the box and do the basic corrections for the Bosch BMP-280 sensor to get a ballpark figure without CL, so there isn't an initial learning period to get at least a rough value within the BMP-280's production variances.....
Offline ValentineWeather
« Reply #11 on: October 27, 2018, 10:48:17 AM »
Interesting station. I would like rainfall comparison with manual Cocorahs gauge.
Randy
Offline Brian J
« Reply #12 on: October 27, 2018, 03:07:02 PM »
Your Northeaster high risk has turned out to be marginal - not much rain or wind, based on your 27 weather stations there.  No wind UFN but the GFS promises rain there Monday and Friday, so I'll keep watching...
Offline Brian J
« Reply #13 on: October 29, 2018, 11:26:30 AM »
Thank you all for your comments and especially for the VP2/WF comparison page which is fantastic.  With your and other's comments, I went ahead and ordered a station from WeatherFlow.  I'm a little nervous at all the sometimes long-term calibration which seems necessary but it seems like a very serious and promising hardware solution and one that I can well use (I'll take it mobile after calibration is done).  I look forward to sharing my comparisons when I have them.
  Brian
Offline MrM1
  • North Central Florida
    • Bethel Weather
« Reply #14 on: October 29, 2018, 12:36:26 PM »
There's an ASOS (KMGJ) across town to the west, but ...
Man forget about the weather stations,  I wanna know who is doing the cool sky writing in the background of you one pic,  that looks like some serious aeronautics going on back there!!    LoL  :grin: =D> \:D/
« Last Edit: October 29, 2018, 12:49:15 PM by MrM1 »
« Reply #15 on: October 29, 2018, 01:17:22 PM »
See this thread for answer with more pictures. :
https://www.wxforum.net/index.php?topic=35327.msg361984#msg361984
WS-2000 & WS-2902A | ObserverIP | WeatherBridge (Meteobridge) | Ecowitt GW1000
Offline METARMan
« Reply #16 on: October 31, 2018, 02:10:30 PM »
The continuity of the WxFlow and the VP2 seems very impressive aside from precipitation amount.   Is this correct?
« Reply #17 on: October 31, 2018, 02:16:29 PM »
Well the rainfall accuracy on the VP2 is nothing to write home about. That's why I was asking if anyone compared to 4" diameter manual Cocorahs gauge.
Randy
Offline vreihen
  • El Niño chaser
  • K2BIG
« Reply #18 on: October 31, 2018, 02:36:11 PM »
My aerocone VP2 and 4" Stratus/CoCoRaHS are within one tip of each other on most rain events, and share a mounting J-pole.....
Offline Jstx
  • Baby the Rain Must Fall
« Reply #19 on: October 31, 2018, 03:25:31 PM »
I like most everything about it, except that "haptic" rain sensor (I just commented on another thread, been meaning to here).
IMO, it will never work. Its' precip measurements are entirely software synthesized, not actually measured. Derived solely from inherently indirect haptic (and audible?) inputs incapable of sensing all the permutations of precip.
Trying to do that for such a variably 'physical' thing as rain, or precipitation of any/all types, which varies in so many properties, will never be accurate across the spectrum of precipitation encountered in actual conditions.
Offline nincehelser
    • nincehelser.com
« Reply #20 on: October 31, 2018, 03:30:43 PM »
The haptic sensor was one of big reasons I bought in (as well as the ultrasonics).
Maybe haptic rain measurement is a dead-end.  Maybe not.  We won't know until we've really given it a shot.
Personally, I'm optimistic for the tech.
Offline Jstx
« Reply #21 on: October 31, 2018, 04:32:52 PM »
That's the description I had rattling around my noggin:
"haptic rain measurement is a dead-end".
Trying to measure an infinitely variable tangible object intangibly. IMO, it just cannot be fully trusted.
Yes, I have read through much of the WeatherFlow forum pages in respect of the "rain" problems. (forgot to initially mention that)
I'm not willing to give it a $300 shot. Maybe they should offer an optional standard tipping type precip gauge. I would probably bite for that.
The ultrasonic anemometer however, I've been drooling over getting one of those for the boat for years.
The standard mast-top wind direction and speed devices, almost exactly like those of most PWS's, are prone to damage atop a 44 some-foot mast (sea gulls, salt air, etc). Corrective repairs aloft are a real PITA.
The top-end marine systems makers have offered nearly trouble-free ultrasonic true and apparent wind measurement units for mast-top mounting for a long time. Their target market is the high $pending yacht racing crowd of course, not so much the lowly cruisers.
I think that the actual devices are sourced from Airmar, then branded by B&G, Raymarine, etc., as part of their top-end navigation packages. Though you can buy just the anemometer and a GPS-driven display, still quite pricey (as is anything "marine").
http://www.airmartechnology.com/weatherstation-info.html?category=WX
BTW, the key marine difference from stationary PWS's is the derivation of true and apparent wind conditions in relation to the heading and speed of the moving vessel, which requires a log, gyro, or GPS input and some simple vector calculations. See: your typical 'storm chaser' WX nut vehicle.
Offline bdh
« Reply #22 on: November 01, 2018, 12:03:10 AM »
Weatherflow came out this morning with a firmware update to the hub and I am now tracking my Atlas within .05 hundreds of a inch of rain all day long and still going,  DSJ over there told me that the CL part is still not released yet for the rain calibration just a good old factory cal /algorithm!
Offline nincehelser
    • nincehelser.com
« Reply #23 on: November 01, 2018, 12:23:57 AM »
Weatherflow came out this morning with a firmware update to the hub and I am now tracking my Atlas within .05 hundreds of a inch of rain all day long and still going,  DSJ over there told me that the CL part is still not released yet for the rain calibration just a good old factory cal /algorithm!:
I re-mounted my SKY this evening just before a brief shower.  I'll have to check to see if I have the latest firmware.
Anyway, my Atlas and CoCoRaHS match at 0.09", but the SKY is over-reporting with 0.14.  I thought the overage might be due to my re-mounting work, but that only accounts for 0.01" according to the time graph.
Here's what I currently have for firmware:
HUB 98, AIR 20, SKY 43
It looks like my HUB rebooted about 4 hours ago, so I'm assuming that might have been the update.
Offline bdh
« Reply #24 on: November 01, 2018, 12:30:02 AM »
Yup your on the latest firmware,it seemed to miss out on the 5 hundreds of a in in a very light spurt of rain I am here in the Midwest and we are getting slammed yesterday and today.
