Author Topic: Community Air Monitor from Clarity!  (Read 624 times)
Offline thehoneywarrior
    • Clarity Movement
« on: October 19, 2018, 08:29:49 PM »
Hi everyone!
We're launching a subsidized community edition of our next-generation air quality monitor in response to the urgent need for clean air action. Previously only available to governments, we are making this edition available to make sure that those most in need of reliable real-time air quality data can access it. You can learn more and purchase a device at http://order.clarity.io
Features Overview:
  • Real-time PM2.5, Temperature, & Relative Humidity data
  • Durable and weatherproof: rated IPX3, UV resistant, & FCC certified
  • Automatically uploads data to Clarity OpenMap via WiFi
  • Sensor dashboard to monitor device activity
  • Externally powered via adapter (Type A plug included)
Everything feeds into Clarity’s OpenMap portal (openmap.clarity.io) where you can view real-time air pollution levels, visualize air quality over time, and track historical data trends of hundreds of measurement points across the world on one integrated open data platform.
More technical specs, testing reports, etc. are all on order.clarity.io.
Clarity is a startup from Berkeley working on air monitoring technology. We're deployed in over 40 countries across 27 cities, working with governments and environmental agencies to deploy hyperlocal air quality networks that transform the way cities understand and tackle air pollution. (you can read about some of our past projects here: https://medium.com/clarity-movement
« Last Edit: October 19, 2018, 08:32:55 PM by thehoneywarrior »
