Author Topic: How Critical Is Bubble Level?  (Read 424 times)
Offline radioman61
« on: October 08, 2018, 01:24:17 PM »
I've mounted my new Atlas on a 3/4" pipe attached to the eave of my home.  This spot was home to a 5 in 1 for the past five years.  Apparently the bubble level on the 5 in 1 was more forgiving because while it showed the bubble within the black circle, the Atlas is just outside the circle.  It's close, but not quite perfect.  Does this make a big difference?
Re: How Critical Is Bubble Level?
« Reply #1 on: October 08, 2018, 02:17:48 PM »
Makes a difference for rain cup accuracy. Sounds like your margin of error is close enough though. But I don't have an Acurite so I'll let someone else have the final say.
This is one of the biggest reasons I'm procrastinating and putting off my new pole installation. I'm nervous of pouring concrete and not doing it right. I've never worked with concrete before.
« Last Edit: October 08, 2018, 02:24:48 PM by galfert »
WS-2000 & WS-2902A | Ecowitt GW1000 | Meteobridge (WeatherBridge)
Online nincehelser
« Reply #2 on: October 08, 2018, 02:48:14 PM »
It affects rain accuracy, but Iíve never heard of anyone doing a study that addresses how much.  Obviously the more level the better.
I would try to press down a bit on the bubble level to be sure it is properly seated.  I once had one that wasnít fully snapped in.
Offline radioman61
« Reply #3 on: October 08, 2018, 02:52:48 PM »
I will check the bubble level...thank you!
Getting on the roof to access the station isn't too difficult....getting at the mounting location is not so easy.
Offline daman
« Reply #4 on: October 08, 2018, 07:55:01 PM »
I would try to get it spot on
AcuRite 01057RM Pro+ 5-in-1 Color w/ Accsess
Michigan
Offline Mirwin275
« Reply #5 on: October 08, 2018, 08:11:21 PM »
You should have nothing to worry about if the whole bubble is anywhere inside the black circle. Of course the more centered inside the black circle the better. My whole bubble looks like this and my rain readings are very close to surrounding stations.  [ You are not allowed to view attachments ]
« Last Edit: October 08, 2018, 08:24:31 PM by Mirwin275 »
Offline radioman61
« Reply #6 on: October 08, 2018, 09:35:24 PM »
Thanks for the suggestions
My OCD will overcome my disdain for the ladder if I let it bug me long enough...
