Author Topic: Acurite, Access, PWS and CWOP?  (Read 1971 times)
Offline SkellyCA
« on: September 25, 2018, 02:12:56 PM »
Now that this board is here. I can post this here. If a mod could delete my post from the Smarthub forum, that would be great.  :grin:
I'm about to order the new Atlas, I already have the Access. I have a couple software questions...
It seems like Acurite only supports uploads to Wunderground right now?
1. Are they planning on adding more upload capabilities?
2. Is there 3rd party software to upload to PWS?
3. CWOP: Is there a way I can take part in CWOP with an Acurite Atlas and Access? 3rd party software maybe?
If you're not living on the edge, you're taking up to much room.
Offline maxtpower
  • Acuparse Developer
  • Madis ID: F0115
    • Personal Website
Re: Acurite, Access, PWS and CWOP?
« Reply #1 on: September 26, 2018, 02:20:12 PM »
Acuparse currently uploads weather data from a 5n1 to PWS, CWOP, WU, and WeatherCloud using your SmartHub/Access. Acuparse should also be able to read the data from the Atlas via your Access, once I get a copy of the data string(s) it is using. At the moment, getting an Atlas to play with is way out of my reach; cost wise.
Main Website:
https://www.acuparse.com
Source:
https://github.com/acuparse/acuparse
Acuparse captures, stores, and displays data from an AcuRite‎ 5N1 weather station and towers via an Access/smartHUB. Uploads to Weather Underground, Weathercloud, PWS, and CWOP. Altas support coming soon!
Acuparse Links:
Acuparse Website
Acuparse Documentation
Acuparse Source via GitHub
Demo and Personal Weather Station via:
Golden Heights Weather Station
Offline SkellyCA
« Reply #2 on: September 26, 2018, 07:04:32 PM »
Thank you but I only have a windows machine right now.
« Reply #3 on: September 29, 2018, 03:12:31 PM »
You can do one of the following since you only have Windows:
1 - Install Oracle VirtualBox on Windows and then install and run Linux on top of Windows as a VM.
2 - You can test Windows Subsystem for Linux (WSL) if you have Windows 10 and test that environment as it may work, this runs simultaneous to Windows and is not a VM. WSL basically can run various Linux flavors simultaneously with Windows 10 using Microsoft's Linux Kernel replacement (this is not emulation).
3 = You can very cheaply (~$60) get a Raspberry Pi 3 B+ and then run Linux on that.
I'd go with the Raspberry Pi solution.
« Last Edit: September 29, 2018, 04:01:10 PM by galfert »
WS-2000 & WS-2902A | Ecowitt GW1000 | Meteobridge (WeatherBridge)
