Author Topic: Acurite Smarthub Software Forum ~ Switch it to Acurite Access Software Form?  (Read 1260 times)
Offline SkellyCA
Since the Smarthub has been replaced by the Access, should you change the forum or add a new forum for the Access?
If you're not living on the edge, you're taking up to much room.
Good call. I second that motion to append the name.
Offline BeaverMeadow
I say start a new forum for the Access but leave the Smarthub forum. There are still thousands of people using the Smarthub. Many find that it works better than the Access. The Smarthub may continue to be useable after Acurite bricks it in February (through workarounds that may not be possible with the encrypted Access).
Done.  New forum board added https://www.wxforum.net/index.php?board=140.0
Offline SkellyCA
Thank you.  :-)
