Author Topic: The mechanism of the vertical circulation of the waters of the oceans  (Read 1005 times)
Offline Fermer05
The reason for the formation of hydrogen sulfide in the Black Sea.
Institute of Oceanology, Russian Academy of Sciences https://vk.com/ioran
The wind waves enrich the water with oxygen only to a depth of several tens of meters of the seas and oceans surface, while the whirlpools deliver the water enriched with oxygen to a depth of more than 10 km. (Mariana Trench)
How does this happen:
The waters of the lakes, seas and oceans of the northern hemisphere rotate counterclockwise, and the waters of the southern hemisphere rotate clockwise, forming giant whirlpools. https://en.m.wikipedia.org/wiki/Ocean_gyre
As is known, everything that rotates, including whirlpools, has the property of a gyroscope (whirligig) to maintain the vertical position of the axis in space, regardless of the rotation of the Earth.
If you look at the Earth from the side of the Sun, the whirlpools, rotating with the Earth, overturn, due to which the whirlpools precess, resulting in a vertical movement of ocean water. http://goo.gl/AM5g1s
The presented theory can easily be verified by relation between the oxygen content and the whirlpools rotation speed.
Based on the map of the depths and currents of the seas and oceans.
The higher the current velocity, the greater the oxygen content and the lower the hydrogen sulfide content. https://youtu.be/ihM1I5r_MUg https://youtu.be/X6PavdKXIE8
List of seas with low oxygen content:
Black Sea. East of the Mediterranean. Gulf of Mexico. Norway fjords.
As we see, whirlpools are involved not only in the horizontal circulation of the sea and ocean waters, but also in the vertical. https://en.m.wikipedia.org/wiki/Dead_zone_(ecology) https://www.scientificamerican.com/article/ocean-dead-zones/
The coefficient of oxygen content can be expressed mathematically by the following formula O = V / G
V - whirlpool rotation speed, km / h.
G - depth of the reservoir, km.
Black Sea 0.2 / 1200 = 0.00016
Sea of Okhotsk 1/800 = 0.0012
Vertical movement of ocean waters can be convincingly modeled using simple experience.
For this, a half-filled vessel with a rotating liquid (bucket, tumbler, mixer) must be rotated around itself (in orbit).
If the liquid in the bucket rotates to the right, the bucket around itself (in orbit) must be rotated to the left. http://bourabai.ru/articles/black_sea.htm
Vertical and horizontal circulation is a vital fundamental law of nature, without which life in the ocean would be impossible.
During the vertical and horizontal circulation, there are also side non-vital effects of nature: ebb and flow, seasonal sea-level rise, killer waves.
Real-time sea current speed:
http://portal.esimo.ru/portal https://www.ndbc.noaa.gov
https://ru.nencom.com/spravochnik/energoresursy/globalnaya-onlayn-karta-vetrov
http://fermi.jhuapl.edu/sat_ocean.html
覧覧覧覧覧覧覧覧覧覧覧覧覧覧覧
Seasonal increase in the level of waters of the seas and oceans.
Institute of Water Problems, RAS https://vk.com/club134348321
The waters of the lakes, seas and oceans of the northern hemisphere rotate counterclockwise, and the waters of the southern hemisphere rotate clockwise, forming cyclonic gyres.
The main cause of rotation of the whirlpools are local winds, flowing into the seas and oceans of the river and the deflecting force of Coriolis.
And the higher the speed of the winds, the higher the speed of rotation of the whirlpools, and as a result, the higher the centrifugal force of the whirlpools, thereby increasing the water level of the seas and oceans.
And the lower the speed of rotation of the whirlpools, the lower the level of water, seas and oceans.
The speed of currents along the perimeter of the seas and oceans is not the same everywhere and depends on the depth of the coast.
In the shallow part of the seas and oceans, the flow moves fast, and in the deep water part of the seas and oceans the flow moves slowly ..
Seasonal rise in the water level is observed not along the entire coast of the seas and oceans, but only on those coasts where the high angular velocity of the currents and, as a result, the high centrifugal force of the water. (Centrifugal force F = mv2 / r).
On straight coasts, where currents do not have an angular velocity, the water level does not rise.
The waters of the Gulf of Finland rotate counterclockwise, forming a whirlpool in the form of an ellipse.
And when the seasonal south-westerly winds unwind the whirlpool to 5 km / h, the centrifugal force of the whirlpool rises, so that on the east coast of the Gulf of Finland the water level rises to 30 cm.
A similar pattern of seasonal increase in water levels is observed in all lakes, seas and oceans ..
The average depth of the Gulf of Finland is about 50 meters, on the east coast is about 5 meters, in the west of the bay it is about 100 meters, for this reason the linear and angular velocity of currents on the east coast of the Gulf of Finland is much higher (as much as the depth of the coast increases current velocity) ..
In the Gulf of Finland, the seasonal increase in water levels has two peaks: in August-September and in December-January and in time they coincide with the season of south-westerly winds.
The speed of the current in the Gulf of Finland reaches from 2 to 17 km / hour, and the maximum speed of the current on Earth reaches 30 km / hour, the wind speed is more than 100 km / hour.
http://goo.gl/eYVTo6
http://esimo.oceanography.ru/esp1/index.php?sea_code=1ァion=6&menu_code=1734
The waters of the North Sea rotate counterclockwise, forming a huge whirlpool.
And when seasonal northwestern storm winds unleash a whirlpool (up to 20 km / h on the southern coast), the centrifugal force of the whirlpool rises, making the level on the southern coast of the North Sea up to 5 meters.
(Storm surge 2.5 meters, centrifugal surge 2.5 meters).
https://de.m.wikipedia.org/wiki/Datei:North_Sea_Currents.svg
https://en.m.wikipedia.org/wiki/North_Sea_flood_of_1953
The waters of the Caspian Sea rotate counterclockwise, forming a whirlpool in the form of an ellipse.
And when the seasonal winds and the flood river Volga unleash a whirlpool, the centrifugal force of the whirlpool rises, making the water level up to 1 meter on the north coast of the Caspian Sea.
The average depth of the Caspian Sea is about 200 meters, on the north coast about 5 meters, on the south coast - about 500m.
Due to this, in the north of the Caspian Sea the speed of the current increases from 1 to 10 km / h.
In the Caspian Sea, the peak of the seasonal rise in water level is observed in June-August and coincides in time with the season of winds and high water of the Volga River.
During a drought over the Volga River basin, the level of the Caspian Sea does not rise.
http://tapemark.narod.ru/more/06.png
http://goo.gl/47tXq2
In the Bay of Bengal, in the season of monsoon winds, the whirlpool speed rises to 10 km / h, making the seasonal rise in water levels up to 1.2 meters.
http://www.aziya-tur.ru/bengal%27skii-zaliv.php
Seasonal increase in the level of the Black Sea (up to 40 cm) is most pronounced in the southeastern part of the sea, where in summer the angular velocity of the currents reaches its maximum value.
http://tapemark.narod.ru/more/07.html
The assumption that the cause of the seasonal rise in the water level may be the pressure of the atmosphere, the flow of the rivers, the temperature difference and the salinity of the waters do not hold water, these factors may raise the water level by a few cm, but no more.
The presented theory can be easily verified by relating the velocity of the currents to the level of the seas and oceans.
(Based on a map of depths and currents, seas and oceans).
https://en.m.wikipedia.org/wiki/Annual_cycle_of_sea_level_height
https://research.csiro.au/slrwavescoast/sea-level/sea-level-change/
http://www.okeanavt.ru/tainiokeana/1066mifosrednemurovne.html
覧覧覧覧覧覧覧覧覧覧覧覧覧覧覧
High and low tides are the result of the earth rotation and of the whirlpools.
Department of Oceanology, MSU https://vk.com/ocean_msu
There is a strict pattern - tides are formed not along the entire coast of the seas and oceans, but only on those coasts with a high current velocity, and the higher the velocity of the currents, the higher the amplitude of the tidal wave.
No tides are formed on these coasts where currents do not have a high velocity.
As is well known, everything that rotates, including whirlpools, has the property of a gyroscope (whirligig) to maintain the vertical position of the axis in space, regardless of the rotation of the Earth.
If you look at the Earth from the side of the Sun, the whirlpools, rotating with the Earth, overturn, twice a day, due to which the whirlpools precess (sway by 1-2 degrees) and reflect a tidal wave from themselves along the entire perimeter of the whirlpool. http://goo.gl/AM5g1s https://goo.gl/images/M4SJq8
The waters of the White Sea rotate counterclockwise, forming a huge whirlpool-gyroscope, which, while precessing, reflects a tidal wave along the entire perimeter of the White Sea.
A similar pattern of tides is observed in all lakes, seas, and oceans.
Sailing Directions of the White Sea https://en.m.wikipedia.org/wiki/Sailing_Directions
http://tapemark.narod.ru/more/22.png
The waters of the Mediterranean Sea rotate counterclockwise, forming tides 10-15 cm high. But in the Gulf of Gabes, off the coast of Tunisia, the height of the tides reaches three meters, and sometimes more, and this is considered one of the mysteries of nature. But at the same time, a whirlpool rotates in the Gulf of Gabes, precessing and reflecting an additional tidal wave. https://youtu.be/ihM1I5r_MUg
The tidal wave in the Amazon River is created a huge planetary whirlpool with a diameter of several thousand kilometers, rotating between South America and North Africa, covering the mouth of the Amazon River.
The pattern of tidal wave movement over the perimeter of the North Atlantic planetary whirlpool. https://youtu.be/ZEhm_ONTQKc
The tidal wave length depends on the whirlpool diameter. And the tidal wave height depends on the whirlpool rotation speed, the Earth orbital velocity, and the whirlpool tilting time (12 hours).
А = V1彪2/t
where: A - tidal wave amplitude (precession angle).
V1 - whirlpool rotation speed.
V2 - the Earth orbital velocity.
t - whirlpool tilting time (12 hours).
Table of the dependence of the amplitude of the tides on the speed of the current, on any coast.
1 km / h - 1 meter
5 km / h - 5 meter
10 km / h - 10 meter
15 km / h - 15 meter
The amplitude of the tides also depends on the size of the whirlpool, the amount of water under the whirlpool, the distance from the coast to the whirlpool and the direction of flow (north, south, west, east).
The current, which moves along the coast, reflects a tidal wave both towards the coast and towards the open sea.
The whirlpool theory of tides can easily be verified by relating the height of the tidal wave to the speed of rotation of the whirlpools.
From the height of the tides, you can determine the speed of the current along the coast, based on the atlas of sea currents in real time:
覧覧覧覧覧覧覧覧覧覧覧覧覧覧覧
Killer Waves The official group of the Institute of Earth Sciences SFU https://vk.com/ogbarannikova
A tidal wave moving across the ocean is called a soliton.
When a soliton collides with the coastline of the continent, ebbs and flows are formed. When solitons collide, two adjacent whirlpools, a killer wave is formed.
https://ru.wikipedia.org/wiki/ Killer Waves
This can be checked by throwing two stones at the same time in a bath of water. When a soliton collides, the resulting killer wave foams and a larger wave pulls a smaller wave somewhat.
You can create a half-meter-killer wave with a duration of 0.5 seconds, if two divers simultaneously jumped with a 澱omb into the reservoir from a height of 2 meters, with a distance between them of 3 meters.
If you throw two pieces of sugar into a glass of tea at the same time and a killer wave forms there.
The mechanism of formation of a tidal wave in rivers and killer waves in the oceans is similar, and the height of the tidal wave in a river depends on the speed of the flow of water in a river.
https://goo.gl/images/Tm13py
https://goo.gl/images/amdjwj
The location of the possible stoning of the killer waves can be predicted from the whirlpool charts and, accordingly, to lay routes.
An approaching killer wave or tsunami can be partially neutralized by creating a series of oncoming waves, torpedoes or projectiles.
If two waves do not collide with each other, then they freely walk on the ocean, and they are called solitons or Rossby waves.
"Three sisters are a collision of a soliton with three storm waves ..
Solitons, reflected around themselves in whirlpools, colliding with storm waves, create a killer wave and are the main cause of ships wreck.
And knowing the distribution schedule of solitons by whirlpools, one should accordingly choose the time and route of movement in the seas and oceans.
The perimeter of the seas and oceans, I believe, is the most dangerous place for anchorage and movement of ships, especially where there is a high whirlpool speed.
The center of the whirlpool, I believe, is the safest place to wait out bad weather, and it is advisable to install a buoy in the center of the whirlpool.
https://goo.gl/images/icF4zf
The map shows the areas of the most frequent occurrence of killer waves.
In the North Atlantic, killer waves form mainly along the perimeter of the North Atlantic planetary whirlpool, as a result of a collision of a tidal wave with storm waves (three sisters) ..
http://www.freegrab.net/Tide%20waves.gif
The animation shows how in the area of ​​the Bermuda Triangle, as a result of the collision of tidal waves reflected by the North Atlantic and South Atlantic planetary whirlpools, a killer wave is formed ..
The clock set on the animation shows that killer waves in the Bermuda Triangle are formed twice a day at 12 and 24 hours.
Based on the demonstrated animation, you can make a calendar of formation of killer waves not only for future years but also for previous ones.
In the season of long, eastern winds in the north of the Sea of ​​Okhotsk and floods of the rivers flowing into the Penzhinsky Bay, the current speed in the north of the Sea of ​​Okhotsk increases several times, due to which, in the north of the Sea of ​​Okhotsk, the water level, the amplitude of tides and killer waves increases.
The current, which moves along the northern coast of the Sea of ​​Okhotsk, reflects a tidal wave both towards the coast and towards the open sea. (South). https://goo.gl/images/u3AsBQ
The discovery was published in the Russian-German scientific peer-reviewed journal 摘astern European Scientific Journal No. 3/2015. Page 64. June
http://www.auris-archiv.de/journal.html
Scientific journal "NBICS-Science. Technologies" No. 4/2018. Page 104.
(Nanotechnology Society of Russia)
http://www.nanonewsnet.ru/news/2018/vyshel-chetvertyi-nomer-zhurnala-nbiks-naukatekhnologii
A positive review was also received from the Institute of Geography of the Russian Academy of Sciences.
Continued: The mechanism of the vertical circulation of the waters of the oceans.
Forum Federal Target Program "World Ocean" http://okeany.com/forum/784.htm
"Forum on the Flagship" http://vmf.net.ru/forums/viewtopic.php?f=6&t=2328
French Maritime Forum (Discussion).
http://forummarine.forumactif.com/t9357-le-flux-et-reflux-est-le-resultat-de-la-rotation-de-la-terre
« Last Edit: Today at 02:06:22 PM by Fermer05 »
Re: Whirlpool theory of ocean deadzones?
« Reply #1 on: December 22, 2018, 09:07:58 AM »
Interesting.
That third link https://youtu.be/ihM1I5r_MUghttps://youtu.be/X6PavdKXIE8 returns a 404 Not Found error.
Offline Fermer05
« Reply #2 on: December 22, 2018, 09:32:51 AM »
Interesting.
Thank you sent.
Offline Fermer05
« Reply #3 on: January 09, 2019, 06:53:42 PM »
The editorial staff is ready to annul the article if an objective critical review is written.
Scientific journal "NBICS-Science. Technology"
http://www.rusnor.org/pubs/articles/15638.htm
