Author Topic: NOAA Weather Radio  (Read 652 times)
Offline NWROrg Team
  • Save A Life
    • NOAA All Hazards Weather Radio
NOAA Weather Radio
« on: September 13, 2018, 09:36:40 AM »
NOAA WEATHER RADIO SARATOGA TEMPLATE and STAND ALONE...
NWROrg became SSL ... Your templates and stand alone aren't working correctly...
You are not be synchronizing with the main NWROrg server databases,...
You will ALSO not be loading on your website...
UNLESS YOU MAKE THE FOLLOWING CHANGES to your scripts,
KEN will be releasing an updated version soon.
Add the "S" to the link in the following lines as shown:
NWR-radios-data.php
Line 4
//Purpose: fetch and cache the https://noaaweatherradio.org/java/NWR-radio-data.js file  Line 37
  $fileName = "https://noaaweatherradio.org/java/NWR-radios-data.js";
Line 86
    $content = str_replace('https:\\/\\/noaaweatherradio.org\\/content\\/thumbnails\\/',$imagesDir,$content);
NWR-radios-inc.php
Line 55  "NatGeo"
Make the URL "https"
NatGeo' => array(
       'name' => 'NatGeo',
         'URL' =>'http://server.arcgisonline.com/ArcGIS/rest/services/NatGeo_World_Map/MapServer/tile/{z}/{y}/{x}',
Line 165
These audio streams are graciously provided by personal weather website owners and others though <a href="https://noaaweatherradio.org/" target="_blank">NOAAWEATHERRADIO.org</a>.</p>
Line 183
see <a href="https://noaaweatherradio.org/" target="_blank">noaaweatherradio.org</a> website "How To?" page for details to submit an audio stream.
