Author Topic: Modbus connection WEEWX Vantage through KTA-282 module  (Read 198 times)
Offline itsokforme
« on: August 17, 2018, 04:23:09 AM »
Good morning ,
I have a Vantage Pro 2 weather station with the Envoy logger and through the serial connection a KTA-282 Modbus module from Ocean Controls.
Now I would like to access from Weewx on raspberry the Davis, but the Vantage driver have not the right access parameters to do that : there is someone that already have solved this problem ? Or someone the knows the driver could suggest the modification to do ?
The modbus module answer as a client on an local ip address and the port 502 with the mode3 ( read registers from location 40000+1).
Guido
Offline johnd
Re: Modbus connection WEEWX Vantage through KTA-282 module
« Reply #1 on: August 17, 2018, 05:01:28 AM »
You'd probably be better off asking on the weewx-users forum on Google groups.
AFAIK, KTA-282 doesn't pass through any Davis protocol so you would need a weewx driver that polls the Modbus registers. It shouldn't be too difficult to do but TBH I kind of doubt that anyone has ever done this - it's such a niche application. But someone on the weewx-users or weewx-developers groups is more likely to know for sure.
Littleport, Ely, Cambs UK
Offline itsokforme
« Reply #2 on: August 17, 2018, 05:08:49 AM »
Thanks !
