Author Topic: Member only pages  (Read 1161 times)
Offline zmarfak
    • Matar
Member only pages
« on: July 22, 2018, 05:00:14 PM »
Hi guys,
I'm maintaining the website for our choir.
The member pages are protected by .htacces and .htpasswd files.
At the moment I do this manually but I like to automate this so that the members can change the passwd or can be send an email when they have forgotten the passwd.
As I want to keep control I would like to give the initial passwd with login because it's not the purpose that everyone can make a login (people not belonging tko the choir).
I looked  around but I don't see any satisfying solution.
Anyone has a suggestion for this or has experience with this ?
Thanks for any input.
Patrick
Davis Vantage Pro2 with a WLIP logger, Intel NUC with WL6.0.4 https://www.matar.be
Offline WeatherHost
Re: Member only pages
« Reply #1 on: July 22, 2018, 05:56:01 PM »
What type of information are you posting and in what format?
Forums like this have that function built in...  pages that only logged in members can read, or even see.  If you can use this type of format, this forum package (SMF) is free and very easy to install.  Some webhosts even have custom installers available
Banners, tags, widgets, etc. are why I have Signatures turned off.
Offline zmarfak
    • Matar
« Reply #2 on: July 23, 2018, 05:19:11 AM »
We don't use a forum.
On the member pages files are available like meeting minutes of the steering committee, music scores, member lists with addresses, a member photo album,..
So files in a directory structure, there is no discussion forum.
These files are not meant to be read by non-members.
For communication we use a "closed" mailing list.
I hope this clarify a little bit.
Patrick
Offline WeatherHost
« Reply #3 on: July 23, 2018, 09:17:33 AM »
Sounds like you COULD do all of that with a forum like this.
Minutes could be posted as Announcements.
Score should be able to be posted within a typical post, maybe as images or the way people post charts.
Member lists are easy and can be edited.
Photo albums are common in these forum packages.
Discussions could be added to most of the above as well as allowing other conversations.
Some of these have Calendars too for event scheduling.
The key is that the security and viewing rights are already handled which is what you seem to be after.
Offline zmarfak
    • Matar
« Reply #4 on: July 23, 2018, 03:00:47 PM »
Thanks for the advice
I will look into it.
Patrick
Offline WeatherHost
« Reply #5 on: July 23, 2018, 04:11:08 PM »
Install it and play with it.
https://download.simplemachines.org/
You might like it.
Offline dupreezd
« Reply #6 on: July 23, 2018, 05:52:40 PM »
@zmarfak, sent you a PM with information and contact name of a person who is also in a choir and did same thing you want to do.
Dries
Davis VP2 6163 | Meteobridge
WU, PWSWeather - KTXCONRO61
CWOP - FW0717
Blitzortung 2100
