Author Topic: wxquake fatal error  (Read 769 times)
Offline cirrus
  • Kevin Hough
  • Davis Vantage Pro2 Plus
    • Mid-Columbia Weather
wxquake fatal error
« on: June 25, 2018, 07:30:33 PM »
I just started getting this error when opening wxquake.php:
Fatal error: Allowed memory size of 33554432 bytes exhausted (tried to allocate 4096 bytes) in /home/rkcrk201/public_html/quake-json.php on line 471
I'm using the latest $Version = 'quake-json.php V2.00 - 10-May-2018';
Any ideas how to fix?
--Kevin Hough  http://midcolumbiaweather.com
The Dalles, OR USA
Offline lddaly
Re: wxquake fatal error
« Reply #1 on: June 25, 2018, 09:36:42 PM »
32 MB seems like a low PHP memory_limit. Depends on your webhost, but I would look into increasing it in your PHP configuration and testing again.
Ours is currently set to 256M.
PHP Directive - memory_limit     Information - This sets the maximum amount of memory in bytes that a script is allowed to allocate. This helps prevent poorly written scripts from eating up all available memory on a server. Note that to have no memory limit, set this directive to -1.     Setting - 256M
Offline Intheswamp
    • Beeweather
« Reply #2 on: June 26, 2018, 08:11:39 AM »
I notice that mine isn't working, either.  But, I'm running v1.09 from back in 2016 and honestly don't know how long it hasn't worked.  :oops:
Davis VP2, v3.12
Cumulus v1.9.4  Build 1079
www.beeweather.com
Tried to lift one of vreihen's gold stars but wasn't smart enough to do it....<grin>
Offline cirrus
  • Kevin Hough
Re: wxquake fatal error [Resolved]
« Reply #3 on: June 27, 2018, 02:18:33 AM »
Okay....I looked into your sugestion and now I don't get the memory error...but now I get:
The USGS feed for earthquakes was not available at this time #-o :roll:
Guess I'll see what happens for a few days
6/27/18  1:30 am PDT Update: Finally figured out I also had to edit .user.ini and set it to 256M. Works okay now. Thanks lddaly for the lead to a fix :-)
« Last Edit: June 27, 2018, 04:40:13 AM by cirrus »
The Dalles, OR USA
« Reply #4 on: June 27, 2018, 10:28:34 AM »
It seems to be working this morning.
Offline cirrus
  • Kevin Hough
« Reply #5 on: June 27, 2018, 03:44:26 PM »
Yes...working this afternoon just fine..Thanks for the work you did on the new script BTW...I really like the new MapBox api...Thanks Ken!
The Dalles, OR USA
